Question about Pro Tools 1964 Cadillac DeVille Heater Core
Replace the heater on a 1964 cadillac deville
    Genius:
  • 1,669 Answers
WHY? Is it clogged? Is it leaking? What is the problem with it that makes you believe it is not worth fixing?
Posted on Jan 13, 2013
  • Peter Wiklund Jan 13, 2013
    It is not dense but has a a major leak
1996 cadillac deville I by passed heater coil but water is coming from somewhere else and is running on floor it's not heater coil and what ever it is its draining my radiator so car over heated
To by pass the heater coil, you must connect the two hoses going into the heater coil. Did you do this? or did you just plug one hose line? best to replace heater coil if it is leaking to get heat working in winter.
Mar 27, 2015 | 1996 Cadillac DeVille
How to replace H02 heater control circuit bank1 sensor2 on 01 cadillac deville
Normally just replace the HO2S sensor using the correct tool for the job so as not to damage the wiring to the unit as it is wired directly to the ECM unit.
Feb 09, 2014 | 2001 Cadillac DeVille
How do I remove and replace heater core in a 1993 Cadillac Coupe DeVille
With great difficulty is the answer. First get yourself into the front floor space upside down, look with lamp at heater /water pipes leading to heater. if no leaks seen, take to repair shop.
Oct 21, 2012 | 1993 Cadillac DeVille
98 caddy deville nothstar v8 how to replace heater coil have no heat and I'm loosing water somewhere
the heater core in a 1998 Cadillac is very tricky to replace.
start with getting a pressure test to determine where the exact location of the leak is, it may not be the heater core.
if you do decide to pull the dash apart to change the core make sure the battery is disconnected for at least an hour to allow the airbag system to discharge.
Oct 11, 2012 | 1998 Cadillac DeVille
Northstar engine purgeline stopped up
Is your floor wet on the passenger side up front and smell like antifreeze? If so, the heater core blew, but it's not hard to replace.
Nov 11, 2011 | 1999 Cadillac DeVille
How do i replace a heater core in a 1999 cadillac deville
Here is detailed solution on how to replace the heater core in the 1999 cadillac deville;
STEP 1 Disconnect the negative battery cable.
STEP 2. Drain and recycle the engine coolant.
STEP 3. Disconnect the heater core hoses using tool J-37097 or an equivalent.
STEP 4. Remove the right side sound insulator and the glove box module.
STEP 5 Remove the programmer shield, if equipped, and disconnect the air mix valve link.
STEP 6 Disconnect the programmer vacuum and electrical connectors.
STEP 7 Remove the heater core cover, leaving the programmer attached.
STEP 8 Remove the heater core retaining screws and the heater core.
have a nice day..
Aug 27, 2010 | 1999 Cadillac DeVille
I have a 96 deville. have replaced the blower
INADVERT Relay next to the engine compartment fuse block on drivers side i need one to
Aug 13, 2009 | 1996 Cadillac DeVille
Pro Tools 1964 Cadillac DeVille Heater Core Logo
35 people viewed this question
Top Pro Tools Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Pro Tools Heating and Cooling Expert? Answer questions, earn points and help others
