Question about PfaFF Tiptronic 2030
Hi, I have lost a small screw on the right-hand side of the needle plate. I have tried taping it but I still get a vibration, when sewing. Where can I get the right screw? Mickey
I have had a friend look in a Pfaff store in Germany but none of the machines there, had this particular little screw. My local Pfaff dealer has not been able to come up with one either. Help!
  • PfaFF Master
  • 1,564 Answers
If someone you know has a screw thread measuring device. you might be able to measure the inside threads of the hole. Otherwise perhaps a parts machine purchase is in order.
Posted on Jan 14, 2013
SewExpress
  • 41 Answers
SOURCE: Frozen Sewing Machine Arm/Pfaff Tiptronic 6270
Good morning,
A question to help determine what's happening with your machine(s).
Open the bobbin case so you can see the bobbin area. Begin by trying to turn the handwheel towards you and watch as the needle attempts to go up/down. If you cannot turn the handwheel towards you, turn it slightly backwards then forwards. Does the needle hit the bobbin case as it comes down?
If yes, your machine is out of time and will require a professional technician to repair.
If the above is not the case, there may be thread jammed behind the bobbin case or wrapped around the inner parts of the take-up lever.
Either case - a Pfaff authorized technician would be your best bet for a proper repair.
Best of luck with your machines - it's just awful to not have the at the ready for all our projects!
Happy sewing,
Kim & Linnette
Posted on Jul 31, 2008
  • 3 Answers
SOURCE: Pfaff hobbylock 794
The needles are changed by inserted the hex wrench into what looks to be holes on the front and left side where the needles go into the machine.I'm not sure what size the hex wrench is but it's pretty small. From the manual,
"Removing Needle: Unplug the machine. Turn the handwheel counterclockwise to raise the needle bar to its highest position. Loosen the needle clamp with the allen wrench and pull the needle out." and
"Inserting needle: When the neddle bar is at the highest position, insert a new needle in the needle holder, making sure that the groove of the needle faces you. Push the needle as far up as it will go and tighten the needle clamp screw." "Removing Needle: Unplug the machine. Turn the handwheel counterclockwise to raise the needle bar to its highest position. Loosen the needle clamp with the allen wrench and pull the needle out."
The machine takes DB x 1, or 1738 needles, and a size 14 needle is recommended.
Hope this helps!
Posted on Jan 13, 2009
  • 3 Answers
SOURCE: pfaff 1222 frozen 20 mins after I start using it
My mother has had a Pfaff 1222 for 40 years and loves it. Take yours to a new/different repair shop or find an authorized place for an overhaul. It's not a lemon, just poorly maintained. you have a problem the service people just haven't figured out yet.  If you have taken the same machine to the same people with the same problem more than once and they tell you it's a different cause every time, they are not competent. Also check the owner's manual for any tips.
Posted on Jan 17, 2009
  • 632 Answers
SOURCE: lost instruction manual
ebay
Posted on Jul 17, 2009
  • 255 Answers
SOURCE: I have a Pfaff 1222E sewing machine which needs a new motor
Good for you, to repair a great machine instead of buying some more modern, disposable machine!
I found a generic motor that will fit your machine at http://www.pfaffmachines.co.uk/partsDB/index.php?function=detail&recordID=185. Free delivery within the UK, but that doesn't help much, does it? There's several places in the U.S., like http://www.a1sewingmachine.com/parts.html http://www.sew4less.com/QuickSearch.php http://sewingpartsonline.com/
You'll probably need to look for a generic motor for your Pfaff, but they should be out there.
I did check eBay; they do have generic sewing machine motors, but unless you're very experienced with eBay, I'd be very careful there.
Check with your local sewing machine dealer/repair place (even if they don't carry Pfaffs). Maybe they can help.
Good luck--I wish I could be more helpful, but let me know if anything I've sent helps, ok?
Robbie
Posted on Jan 31, 2010
The wheel on the right no longer moves the needle, it spins freely. It will sewwhen using the footfeed but not by hand.
The small handle attached to the hand wheel is the problem:
1. Loosen a small screw on the front or side of the small handle. Almost all the way.
2. Tighten the small handle as if you are tightening like you are going from loading a bobbin to sewing.
3. Tighten the small screw.
Apr 19, 2015 | Sewing Machines
Why does my bobbin thread tangle around my bobbin plate
try changing the needle
Correct needle insertion is mandatory for proper use of your sewing machine.
Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle.
Place the new needle in the needle clamp with the flat side of the needle facing the back, (round needle, the groove in the needle should face away from the shaft).
Push the needle all the way up as far as it will go. Then tighten the needle clamp screw.
try rethreading the machine top
Jun 10, 2012 | Brother Sewing Machines
Need to remove needle plate
Remove the presser foot and needle. Press the feed-dog drop button on the right-hand end of the machine, so that the feed-dogs drop below the needle plate. Press the back right-hand-side of the needle plate firmly and the front left side should pop up. You can then lift the plate out to clean underneath etc. When replacing, put the hole in the plate over the locating lug at the front-right corner and make sure the right-hand-side of the plate is down first, before pressing the left-hand side down into the grey surround. Be careful not to use excess force if it wont go, otherwise you could break the retaining spring. When done, dont forget to press the feed-dog drop button again and rotate the handwheel once, so that the feed-dogs come back up again.'
Hope that helps
Jan 27, 2012 | Bernina Artista 180
How do I drop the feed dog on a singer sewing machine 8280
They do not drop.
The accessories with this model include a darning plate, which is a plastic shield that snaps over the feed dogs.
If you cannot find the darning plate, poke a hole for the needle in the center of an index card and tape it over the feed dogs with blue painter's tape (does not leave a residue) and set the stitch length to zero.
Be sure to use a darning foot and lower the presser foot.
Mar 11, 2010 | Singer 8280 Mechanical Sewing Machine
Problem w/ metal plate over bobbin
try and find the screw dude... either that or try taping it down i know it's not an ideal solution but it's a quick fix until you can replace the screw
Mar 07, 2010 | Sewing Machines
Needle breaks because it hits the area around the bobbin.
Here are a few things to check. You may have checked some of these already but it may be worth checking again.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but check your manual), make sure that it goes all the way into the holder, and that the screw is securely tightened.
If there doesn’t seem to be a problem with your needle, try the following:
* Check your pressure foot
Make sure it’s attached securely.
* Change your pressure foot
Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins
A needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew
You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate
Make sure it's securely in position.
* Change your needle plate
If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics, switch to a needle plate with a wider hole.
* Check the position of your needle
Sewing machines with zigzag capability allow you to adjust the position of your needle – right,left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
I hope this helps.
Dec 30, 2009 | Sewing Machines
Keep breaking needles
Here are some solutions to try.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
* Check your pressure foot and make sure it’s attached securely.
* Change your pressure foot Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins a needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew. You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate and make sure it's securely in position.
* Change your needle plate. If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle – right, left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
Hope this helps.
Sep 20, 2009 | Singer 132QRFB Mechanical Sewing Machine
My PE 100 keeps breaking needles, they are striking something during use.
    Here are some things to try.
    * Your broken needles may have been too thin for your fabric. Make sure your replacement needle
    is appropriate for the weight and type of your fabric and thread. You may also need a thicker needle if you’re sewing through bulky layers of fabric.
    If this doesn’t seem to be the problem
    I hope this helps.
Sep 11, 2009 | Brother Sewing Machines
Singer 7442 - Needle hitting bottom
FIRST DETERMIN NEEDLE BAR POSITION TURN STITCH REGULATOR TO LARGEST STITCH, THEN TURN HAND WHEEL TIL' NEEDLE IS ABOUT TO ENTER NEEDLE PLATE.
AT THIS POINT THE FEED DOGS SHOULD BE JUST AT OR JUST UNDER PLATE. IF SO NEEDLE BAR IS, IN CORRECT POSITION,AND TIMING WILL BE SET AT THE HOOK.
TO SET TIME REMOVE NEEDLE PLATE TURN HAND WHEEL SO NEEDLE IS IN LOWEST POSITION. USING A SMALL RULE RAISE NEEDLE BAR 3/32 OF AN INCH ( OR 3 MM FOR A METRIC RULE) .HOOK POINT SHOULD BE IN CENTER OF NEEDLES WIDTH. LOOSEN THE 2 SHAFT SCREWS
SLIGHTLY,TURN HOOK TIL CENTER OF NEEDLE. TIGHTEN SCREWS. IF NEEDLE BAR IS OUT OF TIME. BRING HOOK TO CENTER OF NEEDLE AND LOOSEN SCREW IN LEFT COVER. RAISE OR LOWER NEEDLE BAR TO SET 3/32OF AN INCH. THE 3/32 MUST BE VERY VERY CLOSE.
Nov 26, 2007 | Singer 7442 Mechanical Sewing Machine
Needle continues to hit plate
Sounds like the needle is not inserted correctly, take it out and make sure it is in the right spot and the right way around, (has Flat on one side)
Aug 18, 2006 | Bernina Artista 180
Sewing Machines Logo
Top PfaFF Sewing Machines Experts
SewTechWayne
SewTechWayne
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
