Question about HP IPAQ Computers & Internet
Sdhc driver for wce 4.20
H2200 series
Can i change the colour on the number screen
try to uninstall and then reinstall the aurdio drivers
Aug 25, 2014 | Honeywell 6500LP82211E0H : DOLPHIN 6500...
My SDHC card is no longer recognized. It is not locked and it works on other computers.
The first step is to make sure your laptop is virus free. witch its a good possibility. if that is not the problem then you will have to system restore to a date before the problem started. if that dose not work neither, then the only thing left to try is to reinstall the driver of the motherboard or to reinstall the windows. if none of that work then it means the reader could be busted
Oct 29, 2013 | Toshiba Satellite L500 Series Notebook
Gun fires, leaves good indentation, no nail. WCE working properly, took head apart to look for jam but nothing in there and am using compatible nails. Also oiled it but no luck. Was working fine doing...
Remove nails and use thin tool to push driver all the way up to top of cylinder. If the gun fires one nail then skips, the driver is not returning to top of cylinder. If no nails fire, then nails are not feeding into proper position. Driver must return to top to allow nails to feed into position. Most common problems are bent driver, worn piston oring and bad batch of nails(head too large). Good luck
Jan 14, 2011 | Campbell Hausfeld 2-in 18 Gauge Brad...
When ever i turn my IPAQ H2200 on,it doesnt come on and when i try to place it on charge and on it,it comes on for a sec and goes off and i get the feedback.."Hp Invent Start" then it goes off,if i take...
Your battery is bad change it. Remove the battery and look at it to see if you see a bubble in the center of it if it's there means the battery has reached it's life time
Aug 25, 2010 | HP iPAQ H2200 Pocket PC
I just bought a new memory card-4 gb SD-K046. It says that the memory card is full but it is not. I have only used this memory card to scan pictures. I uploaded these pictures onto my camera and deleted...
The following information lists the type and maximum storage capacity of the memory card that each type of camera accepts.
EASYSHARE CX-, DX-, LS-Series Cameras accept:
DX3500, DX3600, DX3900: CF memory cards up to 1 GB
LS755: xD memory cards only
All other CX, DX, LS: SD memory cards up to 1 GB
EASYSHARE C-Series Cameras accept:
C300, C310, C315, C330, CD33, CW330, C530, CD40, CD50: SD memory cards up to 1 GB
C340, C360, C433, C503, C533, C603, C633, C643, C663, C703, C743, C875: SD memory cards up to 2 GB
CD43: xD memory cards only
All other C-Series Cameras: SDHC and SDHC UHS-1 memory cards up to 32 GB
EASYSHARE M-Series Cameras accept:
M590, M583, M577 TOUCH, M5370 TOUCH: MicroSD and MicroSDHC memory cards up to 32 GB
All other M-Series Cameras: SD, SDHC, SDHC UHS-1 memory cards up to 32 GB
EASYSHARE P-Series Cameras accept:
P850, P880: SD memory cards up to 2 GB
P712: SD or SDHC memory cards up to 4 GB
EASYSHARE SLICE Digital Camera accepts:
MicroSD and MicroSDHC memory cards up to 32 GB.
EASYSHARE V-Series Cameras accept:
V1233, V1253, V1073, V1273: SDHC, SDHC UHS-1 memory cards up to 32 GB
All other V-Series Cameras: SD memory cards up to 2 GB
EASYSHARE Z-Series Cameras accept:
Z610, Z650, Z700, Z710, Z730, Z740, Z760, Z7590: SD memory cards up to 2 GB
All other Z-Series Cameras, including MAX: SDHC and SDHC UHS-1 memory cards up to 32 GB
FUNSAVER FD-Series Cameras accept:
SD and SDHC memory cards up to 32 GB
EASYSHARE ONE Camera accepts:
SD and SDHC memory cards up to 1 GB
Notes:
Most KODAK Digital Cameras are compatible with SD, SD/MMC, and/or SDHC memory cards.
Most current KODAK Digital Cameras are compatible with SDHC UHS-1 memory cards.
All KODAK Digital Cameras that are compatible with SDHC and SDHC UHS-1 memory cards use cards with Speed Class up to Class 10.
MicroSD and MicroSDHC cards with SD adapters can also be used in cameras that use SD or SDHC cards if the storage capacity criteria above is followed.
KODAK Digital Cameras are not compatible with SDXC memory cards.
reference: http://www.kodak.com/global/mul/service/index.html?reqURL=http://support.en.kodak.com/app/home/src/gosupport
http://support.en.kodak.com/app/answers/list/p/2/selected/true
Phone Number for Kodak is:
800-235-6325
or try get human below for more info on support:
http://gethuman.com/phone-number/Kodak/
Jun 11, 2010 | Computers & Internet
I have lost Dg865GBF intel Express Installer cd
The intel website under the support area will have the drivers/bios available for download. You go to www.intel.com click on support and then lookup your board model #. Hope this helps & please take a moment to rate this solution. Thanks.
Mar 08, 2009 | Intel Desktop Board D865GBF (MBIND865GBF)...
Connecting wirelessly via my laptop
i have a spectrum24 la4137 wireless card.but when i insert into my HP IPAQ H2200.I KEEP GETTING THE MESSAGE.it does not recognise the network card.-KENNY.
May 15, 2008 | HP iPAQ H2200 Pocket PC
Computers & Internet Logo
26 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
