Question about Hotpoint WMA76 Front Load Washer
Extremely noisy on spin cycle
My WMA76 is extremely noisey on a spin cycle only. The problem is getting far too loud. It is only when there is a load inside (no clothes-no noise) I would of thought drum bearing at fault, but im no convinced as its quiet as a mouse with no load! I have checked the 2 hanging springs are attached to chassis, also 2 damper legs under drum to chassis, and now im baffled!!
The noise has got worse over last few months.
Any suggestions please???
  • Hotpoint Master
  • 3,463 Answers
I would agree with your initial diagnosis that it is the main drum bearings that is the source of the noise.,
try and spin the drum by hand, if it feels rough, or grinding then it is the bearings, also try lifting the drum up and down, if you can feel movement, again it confirms bearing failure..
If you are not sure, remove the belt and try it again, this is done from the rear, remove the lower panel and slip belt off. this will give you the opportunity to make sure the noise is not from the motor.
If the bearings have gone, it is a major repair, and I would not recommend a DIY repair, as it is a complete strip down.
If the m/c is less than 5 years old, you may be able to get it put right under the Hotpoint 5 year part guarantee, you pay for labour, about £90.00, you would have to check with Hotpoint.
Plz rate my solution.
Thanks.
Posted on Jan 23, 2009
It is most likely the weight on the top of the washing machine that has come lose. I had this problem when I first bought my machine and called an engineer out on warranty. he took the top panel of the washing machnine off, fastened the nuts on the the weight that stops the machine from jumping on a spin cylce and the machine was quiet again. It is a job that is easily done and doesn't need an engineer providing you can use a screwdriver to take the panel off at the top and use a spanner to fasten the nuts for the weight. ;-)
Posted on Sep 29, 2009
My WMA76s is extremely noisey on a spin cycle only. The problem is getting far too loud. It is only when there is a load inside (no clothes-no noise) Is drum bearing at fault? I only ask as its quiet as a...
if this is a front load washer you broke the spider gear from using to much detergent.it eats at the gear and unfortunitly it's cheaper to replace it than to fix it.if it's a top load washer it sounds like the tranny is bad,model number is no good,can't look up your machine
Jan 23, 2011 | Hotpoint Washing Machines
When on a fast spin it is extremely loud, too loud...
Water in bearings causes rust, and rust in bearings creates noise...This is the most likely reason for the noisy spin....Check for any slop in inner drum....Bearings and seals and likely the shaft probably need to be replaced....Quite a big and complex job....Good luck....Nomess
May 18, 2010 | Washing Machines
Nextra is shaking itself to bits and extremely
sounds like the bearing has gone possibly taken out the drum support to shaking could also be one of the wieghts has worked loose.
Mar 15, 2010 | Hoover Nextra HNF 3157 Front Load Washer
LG washer WM2032HS that is extremely noisy now!
If the machine is noisey when spinning it means the seal at the back of the bowl has failed,Letting water past & into the bearings,It is a large job as the whole bowl assembly needs to come out to repair it,Sorry for the bad news,Kind Regards.
Jul 30, 2009 | Washing Machines
Ariston Margarita 2000 NOISY spin cycle....
Remove drum drive belt, and spin drum by hand, if there is any resistance,. or it feels rough or noisy, the the main bearigs have probably failed.
If it is o/k then check motor for worn or noisy bearings,
Please rate my solution.
Thanks.
Jul 24, 2009 | Ariston Technologies Ariston AWD12 Front...
Very Noisy Operation
you will have to access the bottom of the agitator from the back of the machine. Either you have loose bolts or else you agitator bearings are shot
Jan 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
NAV6800AWW - noisy
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Nov 04, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Hotpoint wma76 front load very noisy on spin cycle
If the machine is only noisy during the spin cycle then it is probably not the bearings, more likely it is probably the same issue I had. There is a large weight attached to the top of the drum, in my case it was loose. A simple fix, remove the lid and tighten the three bolts. The lid is removed using a T20 star key, you can buy these at places like Homebase or B&Q (about £7.50 for a set of 10 different sizes). There are two little plastic lugs on the side of the lid, the screws are behind these, remove them and then pull the lid forward and up. The weight is obvious, it looks like an odd shaped brick and is bolted down with three bolts. In my case the front one was loose.
Oct 13, 2008 | Hotpoint WMA76 Front Load Washer
How to replace drum bearing for hotpoint aquarius+ wf740
My machine is just over 3 years old and although there is no play in the rear drum bearing it is very noisey on spin.
It gets progessively loud the faster the spin speed.
Jun 18, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint ultima wt960 washing machine noisy on spin
Bearings faulty or another fault this model suffers from is the concrete balance weight retaining bolts shake loose, if it is the bolts tighten up as soo as possible. Regards Advisor
Aug 21, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WMA76 Front Load Washer Logo
373 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
