Question about SanDisk Sansa Fuse MP3 Player
Won't charge when plugged in to USB
    Habit-Forming:
    Scholar:
  • 60 Answers
Often the problem is the USB cable or the plug.
Make sure the USB cable is plugged in firmly, all the way on both ends. If it still does not charge, try using a different USB port on the computer or laptop. If that fails to solve the problem then get a new USB cable.
If none of the above solves your problem then your device is defective.
Posted on Jan 21, 2013
I barely got this camera. It wouldn't turn on so I
What make and model camera?
Not all USB ports put out enough current to charge a battery. If you're connecting through a hub, try bypassing it and connecting directly. If you have another USB port, try that.
Apr 26, 2013 | Cameras
Nikon s6300 won't turn on
Coolpix Cameras are tricky to use with chargers. I will assume your USB Charger EH-69P is 100 - 240V 50/60 Hz so it CAN work in many places around the world with an adapter. Do not go over 240V or you could damage it.
These cameras like to have the power supply connected when it is on to charge - meaning if you have it connected and you plug the charger in the wall it will NOT charge. So if you plug the charger in the wall first and then plug the cable in the camera it will work. The camera is actually ON when it charges and I never REMOVE the memory card when it is ON.
When you have a dead battery. Plug the camera in and make sure the ON LED lights and the Charge LED flashes. Then don't mess with it. Let it charge completely (Charge LED stops flashing and is OFF) and then unplug it. It will turn off. Then later you can turn it on.
May 08, 2017 | Nikon COOLPIX Cameras
My Coleman Xtreme won't charge. Help!
Hello, my camera is doing the same thing, did you ever find out what the problem is and how to bypass this
Mar 01, 2013 | Coleman C5wp-bk Xtreme C5wp 12mp 33ft....
I put a sdcard in the mp3 player & it still won't hold a charge or save pictures that I take, why?
If you charge the MP3 player using the USB cable and the battery will not charge up then the battery is worn out and needs replacing.
Jan 01, 2013 | Audio Players & Recorders
My Nokia E73 won't charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Sep 15, 2012 | Nokia E73 Mode Cell Phone
Usb connection notification, what does it mean, won't go away
it is telling you the cord is plugged in and it is asking what it is plugged in to
Aug 01, 2012 | Motorola Mobility CITRUS Smartphone
My onxy mp3 player won't charge despite being plugged into my USB port for hours
If the MP3 player battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jul 13, 2011 | Mach Speed TRIO Onyx MP3 Player
Computer isn't recognizing my Samsung PL120- Instructions have read that if you connect the camera via USB the program should automatically install. It doesn't. If i look under removable devices...
Use a card reader. Since your computer has a USB port, you can get a card reader that reads SDHC cards. This is exactly how I do it on my computer.
Jul 07, 2011 | Samsung PL120 Digital Camera
My blackberry 7105t won't switch on even battery is ok. i even tried charging it with different charger and connecting it to pc yet nothing happen--blank screen & led light not lit.
Hi there. It sounds like the USB connector has broken off the phones motherboard. You can order a replacement part from www.cnn.cn and replace it yourself. You're looking for the USB charging port. If you're not comfortable taking apart the phone and soldering, your best bet is a new phone. Alex
Jun 30, 2011 | Cell Phones
Dear HTC, my phone is not charging properly & not showing any display regarding the charging
replace the battery- sounds like it's completely shot. If it still doesn't try- use a micro usb cable attached to a PC- if it still won't charge/come on- the charge board is gone, and you will likely need to replace the phone
Jun 22, 2011 | HTC Touch P3450 Smartphone
Open Questions:
SanDisk Sansa Fuse  MP3 Player Logo
73 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
