Question about HP Compaq dc7600 Small Form Factor PC Desktop
Hp dc7600 PC Desktop is it compatible with MSI 8400GS 512MB PCIE TV OUT + DVI and will it work and not overheat power suply?Thanks
  •  Ilija Podoleshov
    Ilija Podoleshov Jan 13, 2013
    yes its with 240 watt power suply
  •  Ilija Podoleshov
    i will try thiss hope that wont hurt mather board or somthing
  • HP Master
  • 2,072 Answers
The problem wouldn't be overheating, the problem would does your power supply have a high enough wattage to run the card. Typically you want a power supply with at least 300-350 watts. Most store bought computers won't have a big enough power supply. Drop the card in and power up the computer. If it boots all the way your good if it doesn't, upgrade the power supply. You want hurt the computer by trying. Also when you open the tower up the wattage should be listed on the side of the power supply. There are plenty of cheap power supplies on line. Just looked on newegg.com $30 for a 500W. Search YouTube on how to install, it's pretty easy.
Posted on Jan 13, 2013
  •  Ilija Podoleshov
    thank you you were helpful regards to you
  • 5 Answers
SOURCE: Video Card upgrade
as i can c you have a power suply of 200 wats in your pc (correct me if im not right) the GeForce 9400GT is proved not to use a lot of power. but the problem is that your pc is small and it would not get enough ventilation unless you buy a separate fan try it out
Posted on Dec 14, 2009
joecoolvette
  • 5660 Answers
SOURCE: HP DC7600 green light go off when you let go off
Bad Power Supply. Weak Voltage power rail. Suggest you replace the Power Supply. Before you do, make sure you follow Anti-Static Precautions, and also clean out the inside of the computer, with a can of compressed air for computers, if it is dirty. Need to know how to open your computer case, and replace the Power Supply? State in a Comment (The Power Supply is a 200 Watt unit. It isn't the common ATX style of Power Supply. ATX power supply case size, is approximately 6 inches Long, 6 Inches Wide, and 3-1/2 inches Tall. The PSU (Power Supply Unit) that fits in your computer, is approximately 6 inches Wide, 3.75 inches Tall (3 and 3/4 inches), and 4 inches Long. Be prepared for a 'Sticker Shock' when you see the average price ) Should you want to test your Power Supply, before taking advice from a stranger, I would be happy to lead you through it. You'll need an economical Multimeter, or a power supply tester. State in a Comment if this is your intentions.
Posted on Jul 07, 2010
  • 103 Answers
SOURCE: Power supply
The Hp PWRSPLY-250W power supply would be compatible when upgrading your graphics card.
please rate me. thank you.
Posted on May 28, 2008
  • 349 Answers
SOURCE: can' started my pc
As you are getting beeps when you try to boot up, that are not in any particular sequence, the problem is not easy to diagnose .
The cheapest solution if are confident in taking the cover off your pc is to
1) if you have more than one stick of ram swap them around & try to boot up,
2) if you only have one stick, replace the ram stick
if this does not fix it ,it is a motherboard or a cpu problem
that can mean big bucks.
good luck with that
Terry
Posted on Feb 22, 2008
  • 30 Answers
SOURCE: Problem with the HP Compaq
Depending on operating system installed, check for microphone enabled in "sound" setting found in control panel. Also may have a "mute" setting in sound mixer control aplet.
-AAT
Posted on Feb 21, 2011
I wanna know what video cards will fit my DC7600 convertible minitower
Your PC has a PCI-e x16 slot available for upgrading graphics cacapabilities. Any PCI-e x16 that is not double-slot wide or that requires a pcie power plug should work. If you take a look at the images at NewEgg.com you can see which NVIDIA (Geforce) and Radeon based cards are double wide. Your PC just doesn't have the physical space for a fit. For Radeon cards 3000 series and below with the exception of not higher that an HD 3650 in the 3000 series. For NVIDIA based cards in the 7000 series and lower with a couple of exceptions. 8000 series: nothing higher than an 8600 model. 9000 series is a no go.
Your PSU is not capable of running the cards I mentioned as exceptions. Your PSU is less than 300W. Powerful video cards require more wattage and extra PCIe specific power connectors. Read the specs to ensure that the video card you are considering does not have any additional power requirements.
You can link to the cards you are considering and we will let you know if the will fit and work and why they will not if they are exceptions.
Aug 01, 2013 | HP Compaq Business dc7600 PC Desktop
Can i put Nvidia 7300 SE 512mb 64bit video card on hp dc7600sff with 240 watt power suply will it work and not burn or overheat power suply or some other part?please help
Hi.
Yes you should be able to install that card in the DC7600 as it is a low profile graphics card, however i would think about upgrading the power supply as 240 watts might be a struggle for the computer.
Regards.
Feb 02, 2013 | HP Compaq dc7600 Small Form Factor PC...
Windows 7 64 on HP DC7600
It should work..the installer itself should tell you if your system doesn`t takes win 7 64 bit
Jul 12, 2012 | HP dc7600 Small Form Factor P4 630...
VGA,Sound, of motherboard driver is installed. when i installed my video card (Inno 3d 8400GS 512mb PCIE) it works properly when i switch my pc into standby mode. it works but my computer...
Make sure that the video card is compatible with the operating system. Also make sure that all peripherals attached to the computer have been fully updated along with any other device are software. Best options is to check your computer with the manufacture website for full update.
Start>Computer>Manage>Device Manager - check for yellow exclamation mark and update device
May 31, 2011 | Computers & Internet
I want to upgrade video card for my pc(HP Pavillion a1120n) i wanted to know what kind of video card is compitible with my pc. please help thanks. ;)
From what I gather, your computer has a PCIe v1.0 slot for a video card upgrade and comes with intel on-board video. So you will need a PCIe 2.0 video card (v1.0 are no longer available and 2.0 are backwards compatible)
I assume, like most PC's, yours has a 350-450 Watt Power Supply. Check your power supply to be sure, you just can't put any video card, you are limited to the available power from the power supply. If you want a top of the line video card for gaming you will need a more powerful power supply. If all you need is better performance and better video quality (DVI/HDMI) then any sub $100 dollars card will do.
I cannot emphasize enough, check your power supply wattage capacity and the watts required by the new card before buying.
Also, do you have additional power connection from the power supply for the new card? most cards, not all, require a 6-pin PCIe power connector.
For the average user I recommend:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130395
Mar 13, 2010 | HP Pavilion a1120n (PX759AA) PC Desktop
I need a list of compatible video cards for an hp pavilion a1220n, can any one help?
I would recommend Nvidia graphics card.
It is one of the best, and compatible with your computer.
I would recommend one of the most recent models.
Check with your local computer shops and they will assist you in getting a good recent model.
Thank you for using Fixya,
Kenneth.
Feb 15, 2010 | HP Pavilion a1220n (A1220NED904AA) PC...
Video Card upgrade
Dec 14, 2009 | HP Compaq dc7600 Small Form Factor PC...
HP Compaq dc7600 Small Form Factor PC Desktop Logo
111 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
