Question about Electric Currie EZIP 500 Scooter
Ezip e-900 wiring diagram
I have a ezip e-900 , that all the wiring was cut off it, i need a wiring diagram for it .
Where is fuse located on ezip 1000
There is a fuse in front of the battery area that is covered by a metal cover plate. There are two screws on the top of the L-shaped cover which might be hard to unscrew. Exercise patience, use penetrating fluid(s), & try not to de-form the screw head. Otherwise, you shall probably have to cut them off to get the plate off & work the screws out with pliers.
Dec 28, 2013 | Ezip Currie 1000 Electric Scooter, Black
2 wires broke off in the power switch on the handlebars
Have a look at the user manual wiring diagram on the Currie web site. The power switch is in the battery + line. if the wires broke off then you should be able to see from where if you look closely at the switch connectors.
Aug 29, 2013 | Ezip The E-450 Scooter
Ezip 500 won't run : new batteries fully charged but it still shows low battery light...what else could be wrong
i'm having the same problem. checked fuses and both are good. going through the wiring harness to look for shorts. have a bad feeling the micro controller died, that is the little plastic box with metal fins on it under the seat post behind the batteries ******* to the frame. i can bypass the micro-controller and connect one 12 volt battery directly to motor and runs full speed. somehow it is wired with 2 - 12 volt batteries in series to give 24 volts and them the processor cuts back down to 12 volts to run the motor. not sure why this is engineered this way? still working the problem. what sucks so far is that the micro controller is encased in resin so it is virtually non repairable.
* Update added.
Found these wiring harness for sale online scooter stores and on ebay. I replaced mine with some intermediate level adapting the harness to my model scooter and this includes some soldering and wire splicing changing power connector heads off old harnedd to new harness to fit bike. Works great.
Jan 02, 2013 | UPG New Replacement Batteries 4 EZIP E Zip...
1998 Honda CBR 900 RR wiring diagram
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
1998 Honda CBR 900 RR wiring diagram Google Search
Honda Motorcycle Wiring Diagrams
Honda CBR900RR Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda CBR900RR Fire Blade Owner Manual
Dec 06, 2012 | 1998 Honda CBR 900 RR Fireblade
Need wiring diagram cbr 900 rr 97
Need wiring diagram cbr 900 rr 97 Google Search
Jul 07, 2012 | 1997 Honda CBR 900 RR Fireblade
Need free wiring diagram for yamaha xj 900
Hi, Magslbw for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
1992 Yamaha XJ 900 wiring diagram Google Search
Yamaha Motorcycle Wiring Diagrams
Yamaha 95 XJ900S Service Manual
OEM parts for Yamaha
Yamaha Diversion 900 Owner Manual
Nov 17, 2010 | 1992 Yamaha XJ 900 F
1998 Honda CBR 900 RR Fireblade wiring diagram
Hi, Barnstorm13 for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
1998 Honda CBR 900 RR Fireblade wiring diagram Google Search
Sep 12, 2010 | 1998 Honda CBR 900 RR Fireblade
95 rf 900 cdi
Go to this site and you can download a free PDF service manual.
www.carlsalter.com/motorcycle-manuals.asp The manual for your bike is there. It covers 1994 to 1997 bikes. Normally there is a wiring diagram in the back of repair manuals. Other than that, the wires should be color coded. Just match up the colors.
Go to the site below where you can see a parts diagram for your specific bike. You will select the actual brand, year, model, etc., once you go to the site. Part numbers and prices are also shown. You can order parts from this site. In the event no price is shown on a particular part, the part is not in stock. www.babbittsonline.com/pages/parts/viewbybrandand/parts.aspx
Top rating for this answer? Thanks!
May 04, 2009 | 1994 Suzuki RF 900 R
Replacing power cord
I replace one on my U6439-900. I took the back cover off and had to cut the wires and put new wire nuts on. Then I secured them really well with electricians tape. Might help to even put on a zip tie around the wiring. Hope that helps.
Jul 18, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Electric Currie EZIP 500 Scooter Logo
185 people viewed this question
Top Electric Toys Experts
Robert A. Watson
Robert A. Watson
Tom Chichester
 Russ Hill
Russ Hill
Are you an Electric Toy Expert? Answer questions, earn points and help others
