Question about YouTube Videos
Allegro stereo system by Zenith model MD919P
How to change needle on record player.
    Problem Solver:
  • 10 Answers
How old are you
Posted on Jan 13, 2013
Does old Zenith Allegro Console Stereo - 8 track/AM/FM/turntable, have a belt drive phono? I can see metal gears to drive the stuck turntable .
The manufacturers of such items would usually buy in such hardware as record turntables from fairly standard catalogues.
One popular brand of turntable was the BSR but the design of other brands were similar. The metal gears aren't for driving the turntable but to drive the multichange mechanism so when one record has finished playing another will drop from the stack loaded onto the extended centre spindle.
This type of turntable is driven by a synchronous motor with a multidiameter spindle via a moveable idler wheel equipped with a soft rubber tyre. Lack of maintenance causes many problems and as the rubber tyre ages it tends to harden and lose traction on the inside of the steel turntable so when the record reaches the end and the metal gears engage there is insufficient torque and everything stops.
It is for that reason many older examples have had the multichange removed or disabled.
Removing the turntable centre motif should reveal a circlip which when removed will allow the turntable to be removed for maintenance.
Jun 07, 2017 | Zenith Televison & Video
Tip
I need the manual for my Allegro Zenith dvd/vcr or the answer to why I can play...
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems and hook-up problems. The manuals are written for this purpose and they contain useful information.They also contain diagrams of setups, this make it very easy to visualize the set-up procedures. They also contain troubleshooting pages that can help you with minor problems that may occur during your set- up and operation of the unit in the system.The manual also has useful information about the the company and its services. Websites and telephone numbers that you can contact if you are having problems.You should always keep this manual handy for these reasons. I hope this help you to understand the usefulness of the manual and it helps you overcome the minor problem that one always come upon during the initial set-up procedures.
on Jun 07, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Old Zenith Allegro Console Stereo (made in England). - Turntable will not turn; tone arm does not move, even on "manual."
remove the flat rubber platen cover to expose the lock ring at center (horseshoe clip) remove this lock ring and pull the platen straight up and off , under there you should find a rubber tire and the drive motor shaft , turn unit on , you should see motor turn and then it should move rubber tire , if not , your going to need to replace it or clean it up and lube it
Jun 06, 2017 | Zenith Audio Players & Recorders
The remote control for my Zenith XBR413 is lost. Where can I find a replacement?
Model # IS 4070
AM/FM Stereo Receiver
With Phonograph and Cassette Play/Record
Serial # W288209
Power Source AC 120 V 60 Hz
78 Watts 0.65 Amps
Unswitched
AC 120V 60 Hz
200 W Max
Nov 05, 2012 | Zenith XBR413 DVD Player/Recorder and VCR...
Need manual for DVD & VDR progressive scan, Allegro by Zenith
Did you try a Google search for the product name and model number? ( Example: Zenith Allegro DVD VDR progressive scan model number xxxxxxx manual.) You should be able to find the manual on-line if you have the model number (not the serial number).
Feb 11, 2012 | Zenith Televison & Video
Need to know how to record a vhs to a dvd on a zenith allegro abv341 or where to get a manual
Manuals can be downloaded here in pdf format (Needs a pdf reader such as Adobe Reader to view the document.)
http://136.166.4.200/contents/STB/ABV341.htm
Direct link to owners manual
http://136.166.4.200/contents/STB/ABV341/ABV341_Owners_Manual.pdf
Mar 02, 2011 | Zenith ABV441 Player
Trying to find a way to get the turntable of a Zenith Allegro Console to work. We have turned to whole unit on and off. AM and FM radio plays. Turntable doesn't turn. At the bottom right of the turn...
Lift the turn table off the case and check the belt if it has one or the idler wheel that mechanically turns the table. Also check the motor to see that it rotates when you simulate a record play moving the needle carrier towards the center, The power must be on to test it. Becareful not to touch the 115 VAC line.
Oct 29, 2010 | Audio Players & Recorders
Model abv441 need a manual
I did find a manual for the abv341 manual...perhaps there something here that might help you:
https://www.manualslib.com/products/Zenith-Abv341-Series-4031192.html
Jul 02, 2017 | Allegro DVD/VCR ABV511
Zenith Allegro console stylus
I have the same model with the 8 track player, original manual, and original receipt dated 1975.
Jul 15, 2009 | Audio Players & Recorders
Need new needle casing and needle for record player part of this
I would suggest that you look at the MUSONIC web-site. They specialise in cartridges and styli and will answer any questions by e-mail.
Jan 10, 2009 | Audio Players & Recorders
YouTube Videos Logo
75 people viewed this question
Top YouTube Computers & Internet Experts
Michael Terence...
Michael Terence...
Mike
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
