Question about Hitachi 53UDX10B 53" Rear Projection Television
Hitachi Ultravision 53"- went blank
My kids hooked up their new Sony WII and after a while blank. The kids said they heard it pop when it blacked out. I moved the plug to an outlet and the on light will turn on just for a few seconds, but no pic or sound. Is there a quick fix for this? or do I need to call a repair man? Any advice would help.... Arlene
  • Anonymous Jan 30, 2008
    we didn't have a problem with the tv until we hooked up the wii.. now we have a double green and red screen
    Scholar:
  • 150 Answers
If it popped, it may have done one of 2 things, the convergence amps may have gone out, or there may be something in the horizontal output section that is shorted, either way call the repairman.
Posted on Jul 09, 2007
SOURCE:
Hitachi ultravision digital tv
Probably a dry joint in the line timebase section if a tube type TV.
Aug 07, 2017 | Televison & Video
We are trying to hook up our wii console how do you get it to work. TV says invaild scan freq.
You have to hook it up to a standard Yellow/Red/White RCA jack. If it doesn't work on one, try another. Make sure you're on the proper input you hooked it up to on the T.V. If this doesn't work, try hooking it up to a different T.V. to rule out the Wii as the problem. Try hooking up a DVD player to the same RCA jack as the Wii was on the Hitachi. After all of these troubleshooting methods, you should be able to get your Wii properly hooked up.
Jun 24, 2011 | Hitachi UltraVision UT47V702 47 in. LCD TV
The picture just went off we heard a pop then no pic. We have sound . It is 6 years old appr.
It is the bulb, fuze, power board, or video processing board. Only the bulb or a fuze is user replaceable. All others you should seek out a qualified service tech.
Mar 20, 2011 | Hitachi UltraVision CineForm 55VG825 55"...
Green bulb-or lamp on ultravision hitachi 57uwx20b does not work how much to replace?
On a projection television you will have to replace all three(red,blue,green) projection guns in a matched set, the reason is if you replace just the green gun, your picture will be over saturated with green light making your picture look green,because the new gun will be alot brighter than the red and blue guns.
With that said, repair will cost approx.$400+, I've heard up to$600. Good luck !
Jan 09, 2010 | Hitachi 53UDX10B 53" Rear Projection...
TV Exploded
Sounds like the DLP lamp failed. You can decipher the Hitachi flashing red light. That should help to be sure.
The DLP lamp replacement is fairly straightforward and can be done with minimal tools
Sep 10, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Can I upgrade my tv
You can't. Either it came with them or not,.....yours didn't. It's like wanting to make a black & white tv into a color t.v. Although I used to get that all the time.....It's just a tube you pop in!!!! Sorry, the set has to be designed in the first place with that.
Dec 23, 2008 | Hitachi 53UWX10B 53" Rear Projection...
All of a sudden ...no sound
The Time Warner support walked me through getting my SAP turned off on the CABLE BOX.
Nov 06, 2008 | Hitachi 53SBX01B 53" Rear Projection...
Problems with my 50 inch hitachi ultravision projection screen tv
check the solder around the area of the vertical IC. solder is either cracked or else cold. Cold solder appears as dull. Resolder anything that isnt shiny.
May 20, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
64 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
