Question about Kitchen Ranges
How do i fix the inside glass that has come out of my indesit cooker
    Genius:
  • Kitchen Ranges Master
  • 1,669 Answers
Try to find the answer here, please:
http://search.aol.com/aol/search?&s_qt=sb&q=indesit+cooker+user+manual&tb_oid=07-01-2013&s_it=amonetizetest1-ie&tb_mrud=07-01-2013&tb_uuid=20130107163427450
Posted on Jan 13, 2013
I have a indesit 90cm duel fuel cooker can some one tell me how to dimantle the oven door so i can clean in between the two pieces of glass
first you need to remove the door from the oven, Open the door fully and on the hinges you will see a little flap bit on each hinge, flip them over so they lock the hinges open.
Left the door up slightly and you will be able to remove the door.
Place the door on a soft surface handle side down and remove the screws around the edges, You will see how it is held together and be able to finish taking it apart.
When putting it back together make sure the insulating material and the rubber seals are located correctly.
Mar 06, 2012 | Indesit Kitchen Ranges
Where can i find the users manual for indesit is50e electric cooker
For Indesit IS50E Single Electric Cooker...
Check this PDF Document: indesit/_pdf/manuals/19504806702_UK
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 08, 2011 | Indesit W 123 Front Load Washer
My indesit gas cooker's igniters keep clicking
Hi yes it could be that if it only just done this leave it off you can still use the top the heat while cooking should dry it out.
Oct 10, 2009 | Jenn-Air 36 in. CCG2523 Gas Cooktop
Door glass shattered 3 hours after cooking
Hi there folks It also happened to me, so after ringing rangemaster they said it can happen due to faults in the glass, unfortunately my warranity had run out and they wanted t charge a fortune to repair. so i had a look inside the door my self which is only four screws on the sides to remove the outer skin to find it was a single piece of ordinary toughend glass about 300mm x 300mm fixed in place with six clips like the ones you find one those glass picture frames, i got a new piece from me local glass merchants for less than £10 and it took only mins to fix job done, I hope this help someone and it my save you quite a bit of cash Cheers folks Markbricky
May 31, 2009 | Rangemaster Toledo 110 (Dual Fuel) Dual...
The problem is with the glass. They apparently did not use a strong enough tempered glass during manaufacture. I would call the company and tell them what has happened. They should replace it. It must have been a design flaw or something else. They should make it good. They may want to make a recall.
Feb 25, 2009 | Ovens
Indesit gas cooker, odd smell
Indesit Cucina cooker
My tenant is complaining of burnt metal or burnt rubber smells when the oven is hot, it is perfectly clean and only two years old
Nov 26, 2008 | Indesit K344GX Gas Kitchen Range
Cooker hood not working
Check power from the wall.
Check power in the wiring coming into the hood.
Check to see wiring is not broken.
Feb 18, 2008 | Kitchen Ranges
Cooker
HI THERE SKI IS THE GLASS DOOR PANEL THE INSIDE DOOR GLASS OR THE OUTER DOOR GLASS PANEL AND IS IT THE MAIN OR TOP OVEN.
THE GLASS PANELS INTERNALLY ARE HEAT BONDED IN THE FACTORY AND CANNOT BE REPAIRED YOU WILL NEED A NEW DOOR GLASS.
IF INTERNAL ONE COME AWAY THEN U WILL HAVE TO HAVE A COMPLETE INNER PANEL.
Feb 13, 2008 | Ovens
Indesit cooker hood
indesit hi 591 cooker hood bulb blew replaced it hood not working at all now
Oct 17, 2007 | Kitchen Ranges
Kitchen Ranges Logo
51 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
