Question about Brother LS-2125 Mechanical Sewing Machine
Not starting even when foot pedal is pressed nothing happens. Machines light is on.
  • Brother Master
  • 1,564 Answers
Sounds like foot pedal has gone bad... find and purchase a replacement.
Posted on Jan 14, 2013
My Bernina 1300 MDC serger stopped sewing. The light comes on and the machine makes the start up noise but, when I press the foot pedal, nothing happens.The foot works with other machines.
check to see if any thread is jammed inside the right turning side wheel in the core area at times there can be thread that flies in there and may stop the main belt turning.
Apr 08, 2017 | Bernina Sewing Machines
Foot pedal will not active machine
make sure it's plugged in tightly to machine. Make sure light is on . OH, does the light come on? If the light comes on., it will indicate that you are getting power to the machine
Jun 30, 2015 | Sewing Machines
What might cause my sewing machine to not respond when the foot pedal is depressed?
make sure the plug for the foot pedal is connected securely to the machine.
could be the plug in the machine has a problem even tho the foot petal is plugged in
could be the foot petal has gone out and needs to be checked.
Jul 27, 2014 | Husqvarna Viking 1
Machine is behaving as if not getting any power, but light is on. Press foot pedal and absolutely nothing happens
There is probably a bad connection in your foot pedal. Try moving it around with your hands at the contact points while pressing to activate. If it goes when you are shifting its position then it needs to be fixed or replaced.
May 20, 2014 | Janome Sewing Machines
Foot pedal not working
Well, you are definitely getting power from the electric plug in.
Let's do some diagnostic work. Do you hear anything when you press the foot pedal? Any hum? Did you happen to leave it in bobbin winding mode?
your machine doesn't have a "sew" button for use without the pedal. So please rotate the hand wheel toward you as you press the pedal. Did the motor take over and sew?
If you know someone with a meter... have them test the pedal. (they will place probes on/in the part that plugs in which tests for shorts, etc.) If that tests ok... then we know it's something more than the pedal and it will need servicing by a Singer Tech.
Aug 27, 2012 | SINGER 7470 Sewing Machine
Janome j3-20 suddenly stopped working
I would suggest taking the machine in to be checked
Jun 07, 2012 | Janome Sewing Machines
Jones Sewing Machine - When I press the foot pedal nothing happens? The light is on so there must be power.
is the foot pedal plugged into the machine correctly?
if it is then the foot pedal needs to be checked.
May 19, 2012 | Sewing Machines
Foot pedal doesn't work when pressed
you can either have that foot pedal checked or buy a new one
sewing machine parts
sewingpartsonline.com
sew4less.com
sewusa.com
premiersewing.com
ebay
Apr 12, 2012 | Sewing Machines
My juki serger mo-634de suddenly stopped working. Lights on, wheels and parts move freely, even stitching seems to work if I turn it manually, but nothing happens when I push the pedal. No sound. ...
Hi, I have the exact same machine. it sounds like the wire from the foot pedal to the machine is broken. You would still get power from the wall to the machine to light the light, but no 'gas pedal'. You could maybe get an electrian to test the connection under the foot pedal and if the wire is damaged? or maybe the part that plugs in the machine is cracked or damaged?
Good luck! Annette
Jan 08, 2012 | Sewing Machines
White w2500 serger - nothing happens when foot pedal pressed
Sounds like it could be wiring - probably a job for a mechanic
Aug 26, 2009 | Sewing Machines
Brother LS-2125 Mechanical Sewing Machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
