TVs plugged in but it will not come on - Televison & Video
  • 3 Answers
Have u checked the fuse in the plug
Posted on Jan 13, 2013
My TVS Victor GLX 125 is missing at slow speeds also the VTI indication light is blinking. Why?
Hi, Arun and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Spark plugs in bad condition or partially fouled.
4. Spark plug cables in bad condition and leaking check for spark leakage in the dark.
5. Spark plug gap too close or too wide.
6. Faulty ignition coil, module, and or sensor.
7. Loose, dirty, or corroded ignition module connector at crankcase.
8. Faulty CKP sensor.
9. Intake air leak.
10. Water, dirt, or rust in the fuel system, carburetor and/or filter.
11. Fuel tank vent system plugged or carburetor vent line closed off.
12. Vacuum line from intake manifold to fuel valve is broken, cracked, pinched, or missing.
13. Carburetor controls misadjusted.
14. Damaged carburetor.
15. Incorrect valve timing.
16. Weak or broken valve springs.
17. Damaged intake or exhaust valve.
18. Check for engine trouble codes
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
TVS Victo GLX 125 Long Term Ownership Team BHP
TVS Victor GLX 125 2007
http://www.tvsmotor.com/pdf/Manuals-Scooty-Zest-110.pdf
Shop at TVS Victor glx Parts And Accessories Online Store safexbikes com
http://fullmanuals24.com/brand/tvs
Sep 18, 2016 | Motorcycles
Where is spark plug in tvs scooty pep plus?
The SPARK PLUG is located under the seat beneath the Storage Space
Oct 04, 2013 | 2011 TVS Scooty Pep Plus
Can't turn on my Argosy HV372T when it's not plugged in my computer
for tvs blueray players you have to have a flashdrive some tvs bluerays will only reed a flashdrive that is 8gb or under
Nov 07, 2012 | Argosy Hv372t 3.5 Usb 2.0 Multimedia...
I have color on all but 1 TV station. That staion has color on other TV's in my house. Any sugestions?
Ur tvs in ur house it is getting a paid tvs incomming broadcasting tv signals like a cables or a satalites dishes companies?Yes,than that incomming broadcasting wire that plug into ur tv Ant. input port hole might have some kind of signals interference at that channel frequencies,call ur cables tvs or satalites tvs companies providers for an answers and get their field Tech. to come out and check it out.If all ur tvs in the house are analoge tvs and u are using a DTV signal through a DTV converter box to getting a Free over the air DTV air to recieving tv broadcasting tv channels stations only than tries it with another antenna signals sources like a better antenna design like a portable digital antena or good roof antenna should solved this problems.
Oct 03, 2011 | Philips Magnavox 20MS3442 20" TV
We have a Westinghouse 26inch flatscreen TV, that we brought with us 3 years ago from California. It is probably 5 years old. It just died. Looking for a local TV repair shop around Bacoor, Cavite, or...
Yes,tv it is repairables,"NOT" repairable only,if tvs causes by human or object by hitting it screen only.No,if tvs are only damages are to the tvs LCD screen panel itself hitting it by an object or human the tvs,Tvs LCD screen panel itself are not repairable,most tvs,basicly are 90% of it.It is repairable,10% are not worth repairing because of the tvs beyond of the prices of the new tvs or parts are nearly impossible to buy as a refurbish components or as a whole pcb boards.Ur tv now have LED power light indication flashes or dead completely only?Yes.Power supply board are the main causes and problems.That the board where a/c power cord plug into it.U can take things aparts and put it back together basicly?Yes.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv power supply board for the replacement.Or Local tvs shops are common on ur telephone yellow pages book and internet yellow pages searches.
May 31, 2011 | Westinghouse 26" LCD Flat-Panel HDTV
Hooking up a dvd player
If the three cables are yellow, white, and red, then the red doesn't need to be plugged in. The yellow is for the video signal, the white is for one sound signal, and the red is just for a second sound signal (not necessarily important). Everything will work fine if the red cable isn't plugged in at all.
Apr 01, 2010 | Emerson SpongeBob SquarePants TV
How to connect it
Well, you don't give much to go on...
Assuming you have a newer system, it should come with a video cable of some sort and a power cable of some sort. On every console I know of, they both have easy-to-find ports on the back to plug in to. The power cable goes into the wall socket and the video cable goes to your tv. Nowadays, video game systems have either AV cables (red, yellow, and white) or component cables (red, blue, and green) that ship with them. Old systems like the NES may come with an old RF connection (the one that is reminiscent of a cable connection--witht the screw thing on the end). Old tvs may not have AV inputs for the RYW or RGB connections. These will require an RF converter.
Any recent tvs have RYW inputs. They are generally on the back, or on flat tvs on the side, and they are usually color coded to match the type of wires that go into them. Mono tvs have only a white (sound) and a yellow (video). Stereo tvs have a red (right sound) in addition to these. High-def tvs have component inputs as well for higher quality. If you have an xbox 360, find the RGB cables and then find the color coded component inputs on your tv. Then also plug in the red and white sound jacks. make sure your xbox cable is switched to the component setting. This is a little switch that is on the connector where the cable meets the xbox.
This is the gemeral way to hook up a video game system, Anything else will require more details.
Jul 29, 2008 | Video Game Consoles & Games
Audiovox 9"Twin portable dvd players model pvs72901
You seem to be missing the Screen Power/Audio/Video Connector cords. The green colored player is the main one and the other will feed off it however with the two lighter adapters they will work seperately. Currently my wife and I have one in her car and the other in mine unfortuantly once the car is shut off the dvd player resarts from the begining a minor inconvience but the picture quality is not bad.
Feb 26, 2008 | Televison & Video
No color on Sony TV, all other tvs are great
check the av cables in back of your tv and also check the wires connected up to the xbox 60 it's self
Sep 01, 2007 | Microsoft Xbox 360 Console
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
