Question about Watts Onan Portable Generator - 5000 , Model# 6500
Installing a starter battery on onan 6500 homesite
4 Suggested Answers
  • 202 Answers
SOURCE: my onan 6500 gen cranks slow and won't start new
Your solenoid might be bad or your starter motor might need new carbon brushes. If you can take out the starter motor and see if you can manually rotate it, if it is not to hard to turn it, if hard to turn manually your starter might have something bad inside. A bad bearing or bushing. One more thing try this while cranking try to tap the starter motor.
Posted on Apr 01, 2010
SOURCE: Need battery for Onan 6500 Generator
I have searched but cannot actually find what type male of battery it uses, other than it is a Lead Acid Battery. Now with lead Acid batteries, it is the actual Capacity, in Both Amperage output, and Physical capacity. So based upon that ANY 12 V DC Wet Cell battery of the SAME Physical size, and CURRENT capacity will work. Look on the actual battery itself, it WILL/Should have identifying marks written on it. Get one the same, it is NOT all that critical.
Posted on May 23, 2010
Testimonial: "This helps alot..The manual did not give specs on the battery. All I could find was 14L-A2 "
roadtech7
  • 297 Answers
SOURCE: I have a 1997 onan emerald series GenSet 6500 I
Have you replaced the solinoid too? If not, maybe the solinoid is staying engaged, which keeps your starter, well starting. If the starter stays energised the flywheel WILL tear up the starter gear.
hope this helps
Posted on Nov 04, 2010
Onan genarator will not crank
If it wont crank, check to see if the solenoid on the starter pulls in, the starter and solenoid are one unit, it sounds like an internal starter contact, if you have 12V going to it. Assuming the battery is good. When you press and hold the stop button does the fuel pump pump prime? if so control board has power
Mar 24, 2014 | Onan Generator, 6500W, LP Vapor
I have a 1997 onan emerald series GenSet 6500 I have been thru 4 starters it keeps breaking the drive gear assmbly WHAT CAN I DO PLEASE ITS ALREADY COST ME 400.00
hope this helps
Nov 04, 2010 | Watts Onan Portable Generator - 5000 ,...
May 23, 2010 | Watts Onan Portable Generator - 5000 ,...
My onan 6500 gen cranks slow and won't start new batterys and clean cables 12.5 v on one side of soleniod and 7.5 v on other
Mar 15, 2010 | Watts Onan Portable Generator - 4000 ,...
Onan With Missing Parts
Mike, the red and white spade connectors coming out of the AVR attach to the brushes--anode/cathode... red+ left, white = right
Jan 28, 2010 | RTO Cummins Onan HomeSite Power 2400
I need an onan generater wiring diagram
Many times these generators are sold at camper/ motor home dealers some already installed in their units. It's an outside chance but they may have access to a manual. Also if generator has 1-800# call it.they may can help as well. Hope this helped God Bless
Sep 18, 2009 | RTO Cummins Onan HomeSite Power 5500
Watts Onan Portable Generator - 5000 , Model# 6500 Logo
102 people viewed this question
Top Watts Electrical Supplies Experts
Jim London
Jim London
Ottoniel
Joseph Hoffmann
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
