I have asus RT.N53 router, i want to portforward for freephoneline and magicjack,but when check mesage chow port not open
  • 317 Answers
SOURCE: my RCA router needs to be port fowarded
Go to this page: http://www.portforward.com/routers.htm Find your router on this list and it will give you a detailed description on how to port forward.
Posted on Aug 23, 2007
  • 50 Answers
SOURCE: portforwarding on Linksys WAG200G wireless modem/router
Bind the IP address to that port UDP or TCP (or both..your preference) #5060 in the forwarding section of your router. check the box to enable it. Click APPLY or OK or NEXT...wait for changes.
Posted on Mar 10, 2009
jsbasrao
  • 54 Answers
SOURCE: how do i portforward a hauwei echolife hg520s router for bitcomet
Plz follow the step by step instructions given in below tutorial:
http://www.portforward.com/english/routers/port_forwarding/Huawei/EchoLife-HG520s/BitComet.htm
Thanks for contacting Fixya.
PLZ GIVE RATING BY CLICK ON YES or NO.
Posted on Mar 22, 2009
beeveez
  • 167 Answers
SOURCE: need help portforwarding a linksys wrt 160 n wireless router for
Try to use the DMZ, and if this does not work well it needs to update the firmware on it.
Posted on May 07, 2009
oyya
  • 36 Answers
SOURCE: Router portforwarding
Use the below website to configure your port forwarding
http://portforward.com/
Choose your modem type and application that u want to do port forwarding..
Posted on Aug 18, 2009
Testimonial: "Very useful link.. thanks a lot..."
DO I NEED A SEPAREATE MODEM TO USE THE ASUS RT-AC68U WIRELESS ROUTER ? THANKS ROB
connect an ethernet cable from the "lan" ethernet port on the modem to the "wan" ethernet port on the router. assuming your modem is already connect to your ISP then it should be pretty much plug and play. check out the picture, just dont pay attention to the second router
Aug 13, 2014 | ASUS RT-AC68U Dual-band Wireless-AC1900...
Make nat open for rt-n66r
Use portforward dot com. Enter your model and use the instructions.
Jan 26, 2013 | ASUS Rt-n66u Dual-band Wireless-n900...
Rt n53 asus slow wifi
So, If you have internet connection speed problem with your wireless try with the following steps,
1.) Reset the wireless router by using the power switch on it or by unplugging it and plugging it back in.
2.)Place the wireless router in an ideal location. The higher it is, the better, but don't put it near metal objects.
3.)Get as close as possible to the router with whatever device you're trying to connect.
4.)Keep the router and your connecting device away from other electronics. You should especially keep away from phones, fax machines and microwaves. etc.,
5.)Adjust the Wifi antenna if it has one.
6.)Change the router's channel, especially if other wireless routers are nearby.
Following these steps would give you stable internet connection and also increased speed in connection. You can check your internet speed from www.ScanMySpeed.Com before and after following these steps.
Nov 18, 2012 | ASUS Rtn53 - Rt-n53 Wireless Router - Ieee...
Replaced flaky router with new Asus RT N53 Wireless Router Wireless devices work but how do I reconnect static devices?
Hello try downloading the manual from here:
http://www.asus.com/Networks/Wireless_Routers/RTN53/#download
Select your windows
Select manual
And click on global for download
Unzip the file before you can read it.
Good luck
You will need a pdf reader (Adobe)
Nov 12, 2012 | ASUS RT-N53 Dual-Band Multimedia...
Forward ports in linksys wrt45g so magicjack will work
Check this link it has the step by step instruction on how to do a port forwarding on your linksys router , this is just a sample so what you need to do is just replace the value for the port number of your magicjack... http://portforward.com/english/routers/port_forwarding/Linksys/WRT54G/Lingo_VoIP.htm
Hope that helps..........
Oct 05, 2008 | Enterasys Distributed Forwarding Engine...
Problem open a series of ports ASUS WL-500W
Hello!
You should try to add a port range like this 7777:8000
Hope this helps!
Oct 01, 2008 | ASUS WL-500W Router (WL500W)
Unable to input a HYPHEN in portrange
With this particular router you will need to treat the port range field as the port field. You will just have to forward single ports at a time. Which will be fine. In case you need more reference see the link below.
http://www.portforward.com/english/routers/port_forwarding/Asus/WL-520G/WL-520Gindex.htm
Hope this helps!
Jan 10, 2008 | ASUS WIRELESS ROUTER |WL-520G - RT...
Open Questions:
Computers & Internet Logo
1,047 people viewed this question
David Payne
David Payne
