Question about Craftsman 10" Radial Arm Saw Table Electronic Controlled 2.5hp 1ph 120vac
Broken wire, electronic reader is not reading all the measerements
Hi just an update to my problem the heater is hot but now the gauge moves to qauter way up but its running on choke and revving at 1200 ec se engine 2001 thanks
You have air in the coolant system. An uncovered sensor (air pocket around the sensor) will read cold, telling the computer to idle the engine at a higher speed. Bleed the air out and idle should return to normal.
Possible your sensor is bad or wiring from it to ECM is defective, i.e. broken or shorted wire.
Try bleeding the air out first, then check the wiring and/or replace the sensor if the idle does not return to normal.
Jun 06, 2015 | 2001 Ford Focus
Code E1 on Kenmore dryer
The electronic control detected the thermistor is open. It's either the wire harness connecting the thermistor and electronic control is broken or the connection is loose or the thermistor is indeed open. Measure the resistance of the thermistor then if it reads open or the harness of broken. Refer to the detailed troubleshooting of this error code in the link provided below.
Troubleshooting of Error Code E1 on Kenmore Elite and Whirlpool Duet Dryers
Oct 08, 2010 | Kenmore Elite HE4 Electric Dryer
Code reader was reading miss in #5.changed coil pack now reads random miss fire
Recheck the ignition module, The module is what the coil pack sits on and the wire harness may be damaged due to corrosion or broken wires. At worst, the module is bad it self and needs to be replaced. Good luck and hope this helps.
Oct 28, 2009 | 1999 Pontiac Grand Am GT
Were trying to see how Air Flow Censor works? My truck sputts when i start it. Has a hard time starting. Do you have a diagram of the truck?
an air flow senser works by measering the resistance of a heated wire. the more air that passes through it the cooler the wire becomes therefore changeing the resistance. this change is sent to the ecm which interpets it and adjust settings accordingly. this only takes millasecounts.as for a diagram you should be able to buy an after market repair manual at most auto parts stores
Oct 16, 2009 | 1998 Dodge Ram 1500 4WD
My ps2 is broken. It dosen't play games it only plays movies. If anyone cn help me I would be happy to here from them.
Ps2's and Ps3's have separate readers for Dvd/Cd and games. Your game disk reader is likely broken or covered with something that prevents it from reading. Or, your "legal game reader" is broken and can't read the Ps2 certified bands on the disk. Yes, such a device exists to prevent copying and selling games.
Sep 17, 2009 | Sony PlayStation 2 (PS2) Console
Samsung CI-14Y42ZS
could be a dry joint, or a fualty amplifier the Ic no usualy starts with TDA or check the ic the nearest 2 the speaker wires on mainboard..could be a faulty speaker measer your speakers should get a reading between 6 and 8 OHMS thank you
Dec 05, 2008 | Samsung Televison & Video
I have a PDF document that reads error file. It won't open.
will the PDF reader read other PDF's? if so then the PDF you trying to read has become corrupt
best regards
Nov 17, 2008 | Computers & Internet
Craftsman 10" Radial Arm Saw Table Electronic Controlled 2.5hp 1ph 120vac Logo
27 people viewed this question
Top Craftsman Saws Experts
Craig Butler
Craig Butler
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
