Question about RCA Televison & Video
Rca p60920 rear projection tv will not power on
Tv will not power on either by remote or on control panel
    Top Expert:
  • RCA Master
  • 34,148 Answers
Likely power supply failure
Posted on Jan 13, 2013
My RCA 52" HDTV Rear Projection TV Model #MM52110JX1 will not turn on. Neither the remote, nor the front panel switch will turn on the TV. When you press the power button on the remote, the red indicator...
you must check the light indicator if how many times does it blink which tell the main problem or the error code of the tv. either the power supply doesn't work normally or the lamp need replacement.
Sep 23, 2013 | RCA D52W19 52" Rear Projection Television
Have a proscan ps50700 that wont show the picture, will turn on but turns itself right back off. what could it be
TV Doesn't Turn On
  • Your RCA rear projection TV may not turn on from time to time for several reasons. First, check that the power cord is plugged into a working power outlet. Check that the outlet is receiving electricity by plugging a different device into the outlet. If the other device doesn't work, you may need to replace a fuse or reset a circuit breaker in your home.
    If you tried using the remote control to turn on the TV, press the "Power" button on the front of the TV. You may have a problem with the remote control if the TV turns on.
    If you tried using the front control panels and haven't tried the remote, press the "Power" button on the remote control. The television controls are blocked if the TV turns on with the remote. To unlock the controls, open the "Parental Control" menu and remove the check mark next to "Front Panel Block."
    Finally, your TV may be performing a diagnostic check. These checks are used to find any errors in your TV. Wait a few minutes before trying to turn on the TV again.
TV Turns Off By Itself
  • You may find that your RCA TV turns off by itself on occasion. This is often because the "Sleep Timer" feature was enabled. This feature allows you to place a timer on the television that will turn it off after a specific amount of time has passed. The feature allows you to save on your energy bill and extend the life of your television.
    If the "Sleep Timer" wasn't set, the television may have detected a power surge in your home and shut off automatically to protect the components of the television. Wait at least 30 seconds before turning the TV on again.
    Finally, if you suspect the television is turning off for a reason other than a power surge, unplug the television and let it sit for at least 10 minutes. This will clear any errors in the television. After 10 minutes, plug the television back into the outlet and resume normal use.
  • Blank Screen
  • A blank screen on an RCA rear projection television is usually caused by a loose connection or an incorrect setting. Check that the coaxial connection on the back of the television is secure or, if you're using an external device such as a DVD player, the video cables are secure. Press the "Ant/Cable" button to switch between tuners if you are watching television, or the "Input" button to switch between input channels if you're watching something from an external device.
Apr 21, 2012 | Proscan PS60690 60" Rear Projection...
My rca p52960 tv will not turn on at all. What can
I would disconect the front control panel you can do it by opening the back of the unit on top of the light box there is a couple plugs just unplug the one going to the front panel then try to turn it on with the remote
Jan 25, 2010 | RCA P52960 52" Rear Projection Television
Mr rca rear projection tv just came on last night on it's own. i can now only power it on by the front power button. tv has no response to any other buttons on front console and no response to remote.
hi,you need to replace the front control panel, 1 or more of the tact switches have failed, if your proficient at solder work you can replace the switches, if not replace the small board behind the front buttons, available from any local tv shop just bring them the complete model # of your tv, gl, video-tek
Jun 04, 2009 | RCA P52921 52" Rear Projection Television
When powered up-TV continually changes channels---RCA P52937SG MFG 2003
look at the control board circuit -are there and signs of heat damage if so replace board
May 02, 2009 | RCA P52937 52" Rear Projection Television
Front panel
Either replace front panel board or all contact switches on that board the one with vol- vol+ ch- ch+ power, menu.
Dec 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA P46731at
I guess you mean by remote and the front panel button? I had that problem and I took off the top rear panel and moved my front control panel circuit board to the left just a little. This is looking from the back side. I guess the buttons were no longer lining up and the infrared sensor may have been blocked preventing the remote from controlling the tv. I also unpluged and then reinstalled the control panel wiring harness. It was blue and is right behind the middle picture tube. I hope this may help someone if not you.
May 24, 2008 | RCA P46924 46" Rear Projection Television
Verify that you don't have a stuck channel up button on the panel. Next check the solder connections on the IR receiver (3 pins). Also check the +5 supply for excessive ripple. Any of these can cause odd behavior. Let me know how you make out.
Dan
May 02, 2008 | RCA P52937 52" Rear Projection Television
Control Panel does not respond to remote control
make sure it's not your remote first!!! try another one or get a generic one. i f your remote is good you will be able to see a black plastic in the front of the tv usually by the panel controls that is the infred receiver and it would have to be replaced
Dec 04, 2007 | RCA P52937 52" Rear Projection Television
Crazy menu, comes on periodically without using remote
believe it or noT: try replacing all of the switches on the control panel (((power button switch,menu button switch, etc...)))
Oct 27, 2006 | RCA HD52W56 52" Rear Projection HDTV
Televison & Video Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
