USING SyncMaster S19B300 monitor with laptob HP Mini it gives a very wide screen Please advice how to adjust the picture on the monitor
SOURCE: Samsung LCD Monitor SyncMaster 203B
Hi this is the way how to examine
what's wrong with your LCD monitors. After you turned it on and the screen
blacked out or stopped working, you have to check that if you can see the image on the screen or
not by shining a flashlight into the screen, not directly but find the best
angle to the screen and take a look very closely. If you can see the icons or
any image, there will be a minor problem. This is because of the lamps inside
screen. Some of them were broken and it is very easy to replace. If you cannot
see anything on the screen, there'll be some problems with inverter board. If you
have soldering tool and want to fix it by yourself, check the caps first. It
may cause this problem. Some caps might show leaking or burn spot on the board
because of too high temp. If you don't have soldering tool, you better go get a
technician to do so.
Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
SOURCE: Blank screen
Well....that my friends, you've got a busted backlight inverter. Need to replaced a new one... Have a nice day!
SOURCE: Samsung SyncMaster 920nw - Resolution problem
please try to check / use the display adapter device (like nvidia if this is installed in your PC) settings control panel instead of the System->Preference->Screen Resolution option then you can obtain the desired graphics display. best regards
SOURCE: syncmaster 913v not optimum mode
I just resolved this problem for my SyncMaster 913N.
It seems to be a known issue, however it can take quite some time for the problem to occur. In my case about 3,5 years, so well out of warranty.
Short term solution: unplug your monitor from power. The switch on the front is not good enough. Pull the plug and leave it for an hour or so (all night if you can). Good chance the monitor will work next time you power it up.
The problem will is likely to come back..
Permant fix requires some basic soldering as per this video:
I just managed it and it has been ages since I soldered a resistor so you may very well be able to do it. I spent $25 on tool and part and saved me from buying a new monitor.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
