Question about Kenmore Washing Machines
Kenmore elite model #795.71052.012 just lost power and won't turn on
We checked and it's not the breaker or the cord. We reseated cables and no change. We bought it new about 9 months ago and have not had any problelms until now.
SOURCE: Kenmore Elite HE3t model 42922
After the complete wash cycle is finished, the clothes are still soaking wet sometimes. This is not an every load problem.
Posted on Oct 02, 2008
SOURCE: Kenmore elite top loader washer won't start.
Actually I didn't need a solution. The unit would not start. It was like no power was coming in. The outlet was good and usually if there is a power failute the unit flashes PF. Well I walked by in a couple hours later and and touched the start button and it worked. Got two loads of wash in. It must
have a loose connection or a dirty connector, but I'll wait until it happens again
Thanks
Posted on Jun 24, 2009
  • 51 Answers
SOURCE: kenmore elite calypso wash motion top loader won t
Unplug the unit and let it sit unplugged for 30 minutes. There is a power filter on the AC input line and sometimes power surges can cause it to need to bleed off the voltage from capacitors. There is a test procedure to see if the filter needs to be replaced but so far every time this has happened to our Calpyso, we pull the plug for a bit and the washer recovers.
There isn't enough space on this text box to post the removal & replacement procedure for the line filter, but you can find it at www.pcappliancerepair.com and look up the part # on the Sears Parts Direct site for your model # specifically.
Posted on Oct 03, 2009
SOURCE: Kenmore Elite HE5t Power and Errors
f 28 means what after the washer runs for 2 minutes and quits then says F28
Posted on Sep 03, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore washer has smoke smell, now won't turn on
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 25, 2010
Electronic panel not displaying on Kenmore elite Model 630.1395
It might be that the panel itself is bad or there are no power going to the board. Try disconnecting the power by either unplugging the cord or turn the breaker off for phew minutes then tuned back on. Good Luck!
Oct 15, 2013 | Kenmore Dishwashers
Kenmore elite 10654606300 won't turn on
Do you have power at the outlet? If you do, your breaker trip as soon as you plug the unit in? If you have power to the unit and your breaker is not tripping, inspect the wires from the power cord to make sure rodents have not chewed the wires. If everything else looks good then you have a bad cntrl board PART NUMBER: 2252116
Mar 25, 2013 | Kenmore Refrigerators
My kenmore elite dryer model 110 63032102 won't turn on
Check the door switch. Push it by hand and you should hear it click. If no click is heard, replace the door switch with this part.
If the switch is OK, then the only other problem will be with the thermal fuse located on the rear of the machine. Here is a link to that part.
Oct 15, 2012 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
see this causes and fix it. God bless you
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
You: Model #11047532601 Kenmore Residential washer doesn't turn on wath could be the cause???
see the following steps: use the common sense God bless you see the diagram.
1. No power to the washer
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
2. Lid switch
The washing machine may not function if the lid switch is defective. The switch is usually located near the door. Replace if found defective.
Aug 01, 2012 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 Dryer PF on control panel,
HI, there may have been a slight power failure within the home breaker unit or the dryer may have lost power to the control for some sort of reason.
I recommend a thorough inspection of the terminal block on the back side of this unit. make sure the power cord is attached tightly and the wall outlet is secure and holding the power cord correctly. if everything looks great with the terminal block and the power cord is plugged in the outlet correctly, simply unplug this unit for 5 minutes to reset the control. after the 5 minutes are up, plug the unit in once more and the PF alert should reset.
Make sure the breaker box in your home is working properly. (the actual breaker switch for the dryer must be in the on position)
Apr 26, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Washing Machines Logo
95 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
