Question about Home
Eljer lavatory sink faucet leak
Stem
  • 979 Answers
Check washers. They probably are worn out.
Posted on Jan 30, 2013
Leaking faucet
Remove the handles. See if the chrome slip nuts holding the stems in are corroded. If they are, the cartridges may not be fully seated or the o -rings that seal around the cartridges may need to be replaced. If either of these is the case you can tell for sure by turning the stems to the on position with the handles removed and looking for water seeping around the cartridge. If none of the above is the cause then check to see if the aerator (screen on the spout) is loose or corroded sending a light spray back towards the faucet body that looks like a leak. If this is the case remove and clean the aerator, then reinstall it making sure not to cross thread it. If none of the above, replace the faucet. Be sure to call Delta first before replacing because they have a lifetime warranty and you just might get your faucet for free!
Apr 05, 2013 | Delta Faucet Delta 2530-24 Innovations...
Delta 2555-216 Victorian Double-Handle Centerset Lavatory Faucet with Metal I have a slow drip in bathroom sink and do not know how to remove the stem to get at the washer in the Victorian listed above.
If you notice right below the handle,there should be a small opening where ,by using an allen wrench you should be able to remove handle giving access to the stem retaining nut ......CAUTION... be sure cutoff valve is turned off(both hot and cold cutoffs.... under lavatory sink before removing..........unscrew retaining nut and remove stem.....hope that helps......
Sep 01, 2011 | Delta 2555-216 Victorian Double-Handle...
I have a Moen Villeta lever lavatory faucet, model # 4721 that is hard to shut off properly. Technically, it doesn't leak but will drip unless you consciously press down hard enough. We have 3 other...
take the knob/handle off, shut the water to the faucet of, unscrew stem, examine and compare with the other working faucet stems, it may need a new stem(cartridge) or a faucet washer. Possible the retainer nut is/was loose. hope this helps Tim
May 29, 2011 | Plumbing
One of the handles on my Kohler faucet does not turn (at all). The model is very similar to the Kohler Memoirs centerset faucet I've noticed that the other bathroom faucet (dual sinks) is beginning to be...
Removing the faucet stems and coating them( inside and out) with plumber's silicone lubricant should solve the problem. If the stem is too corroded, you may need to replace the stem.
Sep 08, 2010 | Kohler Memoirs Centerset Lavatory Faucet...
Balancing valves replaced but showerhead still leaking
If the faucet dribbles from the spout one of the valves leaks. the way to find out wich one is to turn off one of the angle stops under the sink and if the problem goes away that side is the culprit, if not it is the other side and you may need a new stem.
Jun 27, 2010 | Kohler Fort© Widespread Lavatory Faucet...
My wife turned on the hot water facute in the kitchen when she went to turn it off i will not turn off i took off the knob the nut was a little loose tightened it up still leaks is there a way to repair...
Turn the water off at the shut under the sink and open both faucets to drain line. Remove faucet handle and stem and look inside. There's probably something jamming the stem from turning. Remove that and reassemble.
Feb 21, 2010 | Delta Faucet DELTA/PEERLESS FAUCET CO....
Leaking Delta kitchen faucet dual handle
Pry the hot/cold button off the top of the handle. Make sure the water is turned off below the sink.
Under the button should be screws. Remove the screws. Pry the handle off. Remove the stems by lifting then out.
That should give you access to the washers you need to change.
Apr 25, 2009 | Delta Faucet DELTA/PEERLESS FAUCET CO....
Replace inside stem on hot water Eljer shower faucet
Sounds like you might need a gear puller -- hardware stores would have them -- or auto parts.
Spray with contact cleaner wd-40 first, then install puller, depress ring and crank away at the puller.
Apr 21, 2009 | Home
Home Logo
23 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
