Question about Mitsubishi VS-5059 50" Rear Projection Television
Dark Picture to no picture
My Mitsubishi VS-5059 will turn on and power up correctly and displays a darkened image, but after about 20 minutes, it will fade to black (no image), although the audio will still work fine. I have tried adjusting the settings (brightness/contrast/etc.) but they all have little to no effect on the quality of the picture. I am looking for a way to fix this problem as well as an estimated cost of repair. I was told that if my set is over 10 years old it isn't worth repairing, but I received this 50" TV for free, and I am not about to just throw it away! Any advice or sugestions?
    Scholar:
  • 150 Answers
Probably has some bad solder connections in the deflection/ power supply area, if you dont know about electronics, might call a repairman and put a few hundred $ into it or junk it, also it is not HD, just FYI
Posted on Jul 09, 2007
SOURCE:
Mitsubishi VS-55609 distorted Picture Flickers
This is a convergence problem and not really a DIY Many amateurs try it to save money but end up spending more on it than a professional. There are dozens on here that managed to fix it for a day or two only to have it fail again.
cost of fix about $300.
Please rate my help++++Thanks for using FIXYA
Mar 24, 2010 | Mitsubishi VS-5059 50" Rear Projection...
No picture, no pwr at color guns, no sound, pwr light on
Push in the menu and input buttons on the set and hold them in for 8 seconds together and see if the led blinks a two digit code, then let me know what happens.
Apr 05, 2008 | Mitsubishi VS-5059 50" Rear Projection...
Dark at start up, lines on top
Replace Capacitors in the 9V regulator circuit..100uf 16V & 47uf 50V..May be listed as C2P04 & C2P05
Nov 07, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-55609
Can anyone tell me where the horizontal driver xformer is on the VS-5059?
Oct 23, 2007 | Mitsubishi VS-5059 50" Rear Projection...
Sony warms up - picture slowly becomes dark
You are losing screen voltage or whats called the boast voltage most likely. This is probably being caused by a bad capacitor in the sweep power supply. You will need to get a service manual as well as use an ESR type capacitor meter to find the bad capacitor(s). Good Luck
Jun 05, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Mitsubishi VS-5059 Problem(S)
These sets are very hard to fix.however you can go to www.samsphotofact.com and buy a schematic for that set.and your trouble will be over it will cost you abut $40.00 US.Good luck
Jan 14, 2007 | Mitsubishi VS-5059 50" Rear Projection...
Mitsubishi VS-5059 50 in. Proj. Televsion
If still under warranty or if you have no electronic repair experience you should take the set back to the shop or to a repair person. Some of the solutions described below can be dangerous, TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages. This should not be an expensive job at most repair shops. Could be something as simple as cracked, cold, defective solder joints around and near the vertical output chip, could be a faulty chip and other components in and around the vertical deflection circuitry, or a faulty vertical drive signal from the jungle circuits, or worst case a faulty deflection yoke. Take your television to a shop right away for a proper and safe repair. Do not keep the television looking at the red horizontal line.... you can easily damage or burn the CRT phosphors. Good luck
May 27, 2006 | Mitsubishi VS-5059 50" Rear Projection...
Screen goes dark
I thught I answered this one but if you disconnet the sensor it should brighten up the picture If it dosent then its part of the brightness curcuit and must be replace. As I remeber thewre are severall models that you could simply disconnect. Or there should be an auto brightness feature in the main menu picture ajustment to simply disable or shut it off. Good luck
Apr 22, 2006 | Mitsubishi The Big Easy TV
Televison & Video Logo
87 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
