Question about Bunn Dual® (20900.0011)
Bunn Dual only heating to 180-185F
I have a Bunn Dual 120/208 brewer and after the heating elements turn off the water temperature is only at approximately 180-185F and the green ready lights don't turn on. This model is from 2003 and I recently bought it used. Everything else seems to be working fine except the water temperature seems to be a bit low. If I have read online correctly, the temperature should be about 200-205 in the tank and about 195 (+/- 5 degrees) coming out the spray heads. I put a thermometer directly into the tank and verified it's only at 180-185. Any ideas what's causing this? The temp probe in the tank has some light green corrosion on it but it doesn't seem too bad. The thermostat control knob is also turned completely on. Any input would be appreciated!
  • 24 Answers
Is there scale buildup on the heating element? Can you check the voltage of heating elements. They should read in the 208v range. If all checks out then I would change out the thermostat.
Posted on Jun 05, 2014
3 Suggested Answers
EsWorld
  • 1618 Answers
SOURCE: Bunn CWTF15-APS Unable to hold 195 at the brew head
Yes it is possible to go the the next larger element.
Yes if the machine was plumbed there would be a difference in the way it brewed the water temp. if you look at the end hose in the pan from the solenoid, it takes a while for it to pour out 3liters.
Try using a different sprayhead(if yo;u are using a 6 hole try getting a 5 hole. That will constrain the flow of water a little more allowing the element more time the heat the water.
Posted on May 16, 2009
Corey_allen8
  • 23 Answers
SOURCE: Inave a Bunn VLPF coffee brewer, water is leaking
THe most likely answer is that the tube that leads to the sprayhead is clogged with lime. You will need to remove the spray head wich is located above the brew basket and make sure the holes are not clogged with lime. Use a wire brush to clear them. In the field I would use a deliming spring but you may need to go to a lowes or home depot to find a tool you can use to clear the tube wich is what the spray head screws onto or just goole deliming spring and try to order one off line. It is a long flecible very tightly wound dpring about 14 inches in length or so. www.midstaebeverage.com
Posted on Nov 16, 2010
Commercial bunn brewer is making loud buzzing sound
see the next steps and fix it yourself. God bless you
  1. Unplug the unit from the electrical receptacle.
  2. Remove the pot and basket. Remove or tape closed the water reservoir lid.
  3. Turn the appliance over and remove all screws that secure the case halves. Lift off the case to expose the heating element and controls.
  4. Inspect the control cavity to determine if the solution is simple: disconnected wire, debris, etc. If so, fix, reassemble, and test. Otherwise, continue with the next step.
  5. Use a DVOM to test the heating elements and the switch, thermostat, and timer
  6. Replace any defective parts or decide to replace the appliance, as appropriate.
  7. Reassemble the appliance and reinstall the pot and basket.
  8. Fill the water reservoir approximately half full, then plug in and turn on the coffee maker to test its operation.
Oct 15, 2012 | BrewWISE Bunn 33500.0000 Dual Soft Heat...
It only makes 1/2 pot when I pour the water in after sitting over night some times it takes 2 pot of water or more to make a full pot
I recommend slowly pouring in about a half a pot of cold water without coffee in the filter basket 5 or so minutes before you brew in the morning. There are 2 good reasons to do this-
1. Overnight you are having some evaporation due to the fact that your Bunn brewer has a reservoir that keeps a couple of pots worth of water at brewing temperature... a better temp than most "home" model brewers. This will top off the reservoir and you will not "short pot" except for the amount that the grounds themselves hold back.
2. Also overnight, due to the fact that the water is kept hot, the oxygen can dissipate from the water in the tank. Topping off with fresh water will mean a fresher first pot.
The Bunn brewers have a low wattage/keep warm heater so the actual heating element isn't doing all of the work over those long periods... it only kicks on when the temperature in the reservoir drops considerably (like after brewing). Be sure to let the brewer heat back up before brewing (you will hear it stop heating)
Hope this helps.
Oct 28, 2010 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
On a Bunn VPR why is the water boiling out the top of holding tank?
This brewer has a dial type thermostat inside the top lid. I believe a small counter-clockwise turn (about 1/16 turn) should lower the maximum heating of the brewer. If the brewer is old you may need to replace the thermostat AND the High Limit thermostat... the small "button type" device on the top of the tank with wire to and from the heating element.
Oct 19, 2010 | Bunn VPR Coffee Maker
My friend gave me a Bunn thermal home coffee maker and I don't know how to make it work and can't seem to find directions on line?
Depending on which maker and how old it is it may have a switch for the heating element. The BUNN brewers have a reservoir inside that needs to be topped off BEFORE energizing the heating element/plugging it in. This usually will require about 3 pots being poured through until water starts to flow from the filter basket. (Have a pot in place to catch the water) Then it is safe to plug in your machine. After it heats up (about 20 minutes) you can load your grounds and pour through a pot of COLD water and voila... coffee.
Also, due to the reservoir you will want to not shut off or unplug your brewer... then it will be ready to brew next time.
Sep 20, 2010 | Bunn 10 Cup Home Coffee Brewer
I have a bunn coffee maker that when it brews the first pot is hot after that the next one is not. It is the coffee maker that has two warmers on top. i didnt know if would be the heating element or...
While this brewer does have a reservoir that keeps a couple of pots worth of water hot for brewing you can get a cooler second pot if you brew directly after. You should hear the brewer heating up after brewing. Try waiting until it is back to temperature before re-brewing. If that heating takes more than a few (3-4) minutes then you probably have a problem with the heating element and the water is only being heated by the "keep warm" heater.
Sep 13, 2010 | Bunn VPR Coffee Maker
Bunn VPR Series Coffee Maker will NOT dispense the water into the coffee pot?
This machine has a reservoir that holds about 2.5 pots and keeps them at brewing temperature. Therefore you should pour in 3 pots (with a pot in place under the filter basket) until water flows from the basket. Then, and ONLY then, it is safe to plug in the brewer. If you plug in the brewer BEFORE filling the reservoir you will burn up the heating element and will have to have it replaced.
After the initial filling and heat up (about 20 minutes) you are ready to pour through a pot of COLD water through and brew.
Sep 10, 2010 | Bunn VPR Coffee Maker
Slow recovery on bunn o matic for next cycle
You could have scale building up on the heating element and thermostat probe. try running a 1/3 white vinigar - 2/3 water mix into the brewer, let it heat up completely, then run several pots of clear water through the unit. keep pouring water through it until the vinigar smell is out of the water,
Jan 05, 2009 | Bunn-O-Matic Coffee Brewer GRW8
Bunn pour omtic 3 burner commerical coffe maker model 666L (pin # 658) Coffee maker will not brew red light comes on and flickers followed th set up insturctions still nothing, even put a pot of vinegar...
I'm going to presume that your brewer is a VPS series pour-over brewer. This problem can be caused by several things, so I'll list the most common ones.
1) The on/off switch for the lower warmer could be burnt out.This switch also operates the heating element.
2) The high limit thermostat quite offen blows on the older VPS brewers. this is a small unit held down to the top of the tank and has 2 wires voming to it.
3) Look for burnt-off wires. These models sometimes burn off wires on the top of the heating element.
4) If none of these work, then your problem will be your heating element itself.
Parts for these models are readily available from your local Bunn repair shop.
Dec 31, 2008 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
I have an older Bunn-o-matic with 2 extra warmers on each side. The water is supplied automatically to the machine but is not heating up, despite my turning the heat knob all the way up. The warmers are...
Here are some possible causes ,the hi temp cut out ,thermostat, or heating element are bad .a continuity tester can determine whitch one .Also you could have a burnt off wire . The reason the water is still luke warm is a electic warming jacket that bunn put around the water tank to limit the therostat cycles during off peak usage very fixable hope this helps
Dec 29, 2008 | Bunn -O-Matic Corp. 2 Warmer Auto Brewer...
Coffee is coming out weak. Feels hot. could this be a thermomitor problem
To check the water temperature you need to run a pot with the sprayhead removed. Most Bunnomatics have two forms of heating. The primary heat source is the heater element. It's job is to heat water to the temperature set by Bunn factory technicians. The second heat source is what is called a "keep warm heater". This heater is always on and keeps the water temperature at about 180 degrees. This saves on long heating times while the coffee brewer isn't being used. Now, if the main heating element goes out the brewer is still gonna send about 180 water to the brewbasket. By the time is gets from the air gap in the brewbasket to the grounds and filter it looses about 10 degrees. Coffee (regardless of what that non expert said that burned herself when she put the coffee between her legs says) is brewed at between 190 to 205 degrees for a good cup of coffee. With lawsuits I think alot of restaurants have taken the brew temp down to about 193. So your coffee maybe hot but if it is only using the blanket heater it won't be hot enough to make a good cup of coffee. So check the temperature by using a good electronic thermometer purchased at most hardware stores. If the temp is good start looking elsewhere. The first place is after you brew a pot of coffee do you have a "star" pattern in the used grounds, you should. If not remove the filter basket and run a pot of water into the pot. You may have to get a pan that will fit under it to catch the water if it doesn't drop into the brewer's decanter. You don't wanna make a watery mess. It is imperative that all the holes in the sprayhead are clear of grounds and water is running, not dribbling from them. A clean brewbasket and sprayhead are everything to taste. Also the temp must be above 190deg and It shouldn't take more than three minutes from the time you finish pouring the water in the top until you basically have a full pot (not counting some small dripping at the end). Love your brewer, Rick in Indy9d10981.jpg
Aug 05, 2008 | Bunn GR10 Coffee Maker
Bunn Dual® (20900.0011) Logo
47 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
