Question about Canon imageRUNNER 400S Copier
How to configure IP address on Canon IR400 Printer Please give me step by step details for setting up printer.
  • santhikishor Feb 28, 2009
    i cannot ping my ir400 printer. i dont know how to configure my ir 400 network setting.
  • Carlos Perez
    Carlos Perez May 11, 2010
    additional functions.... system settings.... ip config ??
RESTART THE MACHINE AND PRESS PRINT BUTTON ON THE TOP OF THE PANNEL AND IT WILL SHOW WAIT... AFTER THAT A SCREEN APPEARE LIKE (DO U WANT TO ENTER SETUP AND OPTION APPEARS YES / NO PRESS YES IMMEDEATELY) THEN U SELECT NETWORK SETUP AND TCP/IP SETUO
Posted on Mar 03, 2009
  • zmarzouk Dec 06, 2010
    Right on, this was very helpful
    Thanks
How connect a tcp ip printer.
Hi Kumar,
You can modify or change port in the printer driver to connect it through LAN cable. Please notice whether you use static or dynamic ip address. Please follow below step.
In the following step we will modify your existing USB connection. Check it out!
Step:
  • Open printer driver list.
  • Right click on the printer drive name (e.g Canon IR2270).
  • Select Properties.
  • Click Ports tab.
  • Click Add Port, then select Standard TCP/IP Port.
  • Click New Port.
  • Click Next on add port wizard menu.
  • Type IP Address (for static ip setting) or Printer Name (DHCP), then click Next (computer will search the printer).
  • When the printer has been found, finish the wizard.
  • Close Add Port menu.
  • Now you have new port represented by IP Address or Printer Name (with checked box active) in port list .
  • Click Apply.
Bingo! Now your printer ready to print via LAN. Sometimes printing right after setting this new port not always succeed. Don't be panic. Restart both of printer and the computer.
Next time you want to connect the printer via USB port so you change port back to USB. Just simply check on the check box next to USB Port in port list and click apply. You may need to restart both printer and computer too :)
Have a nice day!
Printer Clinic
Jan 13, 2014 | Canon iR2270
Tip
Steps to Configure Static IP Address for Epson Wireless Printer
The IP address is a specific number allocated to a device, which is connected to your PC network. If you require configuring a static IP address for your Epson printer, it can be possible by using the network configuration menu that you can access via the Internet browser on a connected system. To do that, it's necessary to know your printer's existing IP address. If you have a password protected the device, then you must know the username and password credentials to access your Epson printer network configuration menu. You can call at the Epson Printer tech support phone number and get expert's assistance to do that in a proper way.
Find Epson Printer's IP Address
    1.Click the 'Windows Start' button and choose the 'Control Panel' on any system connected to the similar network as your Epson printer.
    2.Double-click the 'Printers and Faxes' option and then find the Epson printer that you want to configure a static IP address for in the printer list.
    3.Right-click on the Epson printer from the list and choose the 'Properties' option.
    4.Click the 'Ports' tab and find the printer to configure a static IP address. Click on the printer to select it.
    5.Click on the vertical bar between Description and Port and shift it to the right to expand the Port column. Find the Epson printer's IP address under the 'Port' column, which is a series of numbers divided by, resembles and periods 192.168.1.2.
      1.Open up your favorite Internet browser on the system connected to the similar network connection as your printer for which you need to set up a static IP address.
      2.Input the printer's IP address into your browser address bar. Click the 'Enter' button.
      3.Enter your printer login information. If it's not password-protected, enter 'admin' text into the 'Username' box and leave the password field vacant. Click the 'OK' button, followed by the 'IP Configuration' tab to sign into the Epson wireless printer settings page.
      4.Find the 'IP Address Configuration' or 'TCP/IP' section and adjust the value from 'Auto' to 'Manual' or 'Static.'
      5.Input the static IP address that you need to allocate to the Epson wireless printer into the provided boxes. It forces the network to assign the selected IP address to the Epson printer every time it tries to connect to the computer.
      6.Click the 'Save' button to apply the settings and close the browser.
      Additional Tips:
      Configuring a static IP address for the Epson wireless printer is not a complicated process if you are a tech-savvy user. However, if you can't set static IP address for your printer even after following these steps, you must avail the help and guidance of technicians that can be possible via the Epson technical support phone number. They will assist you step-by-step to configure IP address of your printer in an efficient manner.
      Source: http://bit.ly/2lJLWxS
configure static ip address for epson wireless printer-yxa4stq55mknsqg0b4p2yanw-2-0.jpg
on Feb 15, 2017 | Epson Office Equipment & Supplies
How to update a new ip address in order to get my printer print?
I think IP address is not a problem in your printer. You just need to check if the printer driver is install to make your printer work...
IP address is only use to connect the computer to the internet not to connect with the printer. If you have a printer connect to other computer you really need to configure the IP of both the pc to connect each other...
Router will automatically assign IP address of those computer connected to a routers. If you still not connect
Please don't hesitate to ask again and I will give you the step by step to configure your IP address unless your connect with static IP
Sep 20, 2011 | Xerox Phaser 6125 Laser Printer
How to configure ip address in ir400 machine, not computer
press the system button .go to set up option. go to network setting configure the IP address and sub net mask.
Jul 07, 2011 | Canon imageRUNNER 400S Copier
How do i set up my wireless canon printer to my laptop? I keep getting messages saying can't find the printer.
Difficulty: Moderately Easy
Instructions
Things You'll Need: · Wireless print server
· USB printer
· Ethernet cable
· Computer
1. Step 1
Obtain a wireless print server that is compatible with both your wireless network and your printer. While the printer’s documentation may not explicitly say that it is compatible with a print sever, many are compatible, and this can be verified by checking the website of the print server’s manufacturer. If you have a multifunction printer, only the print function will work with most wireless print servers, though a few have recently added support for scanning and the printer’s other functions.
Step 2 Read all of the documentation that came with the wireless print server. The manual will detail the specifics of the installation routine.
Step 3 Connect the printer to the wireless print server via the USB cable. Connect the print server’s Ac adapter and turn the unit on.
Step 4 Connect an Ethernet cable between the wireless print server and your computer. This will be used for the initial setup only.
Step 5 Insert the CD supplied with the print server into your CD-Rom drive. Start the software if it does not start automatically. The application will walk you through the installation process, which includes setting the unit’s IP address, setting an access password, configuring it to connect to the wireless network, installing the drivers that allow the print server to use the printer and installing the print drivers on your computers.
Step 6 Choose how your print server will be addressed. Most units are set up to use dynamic addressing by default, which means that your wireless router will assign an IP address to it. This allows the server to be easily installed on the network, but it also means that the IP address of the printer may change over time. The other option is to assign a static IP address to your print server. This option is more reliable, because the print server will always use the same IP address, making it easier for the computers to find the printer and easier to access the print server’s online configuration application. If your router has the IP address of 192.168.0.1, for instance, set the print server to something like 192.168.0.2 or 192.168.0.3, as long as another device does not use that address.
Step 7
Set a password to be used to access the unit’s online configuration application.
Step 8 Configure the print server to access your wireless network. Give it the same SSID network name as your router and set it to use the same wireless channel. If encryption is used on the router, enable encryption on the print server, and enter the encryption key or password.
Step 9 Follow the instructions given by the print server’s software for installing printer drivers on the unit.
Step 10
Disconnect the Ethernet cable and allow the unit to connect via the wireless network.
Step 11 Install the printing drivers on each computer that will use the printer.
Step 12 Access the print server’s online configuration application to verify all settings by entering the IP address of the unit into a web browser, using the “http://192.168.0.2” format. Enter the administrator name and password.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 21, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Pspcl drivers for ir400 machine
press the option switch
in screen press function
press print pages
print configuration page
see the ip address & install the printer on this ip
in your computer networks use tcp\ip is smaller than machine ip if machines ip is 192.168.1.33
computers ip is 192.168.1.32
Aug 15, 2009 | Canon imageRUNNER 400S Copier
Setting Ip address on canon c3220 imagerunner.
Is the Canon connected with a cable that's connected to an active port. You can try to Fixed IP hold down 1 & 7 When you power up the machine, make the necessary network configurations and see if pings back with a reply.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 06, 2009 | Canon imageRUNNER C3220 Printer
How to i configure the ip address in cannon ir400
configure your printer ip address 192.168.1.1and then configure your pc ip address 192.168.1.30
then ping 192.168.1.1 on run command. if no error is display then your printer is configure with PC.
if any problem call me after 7pm
Jun 05, 2009 | Canon imageRUNNER 400S Copier
Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Feb 01, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Canon imageRUNNER 400S Copier Logo
5,670 people viewed this question
old marine
old marine
