It's a Sylvania tv model LD195SSX Not sure how it happened just one day a DVD got stuck in it and the screen started flashing red green blue black white grey over and over how can I get it to stop th
  • 4 Answers
Mabye the disc isint fitted for that type
Posted on Jan 13, 2013
SOURCE: DVD plays only in black and white
Hey, I had this problem on Thanksgiving Day, trying to watch a dvd on my mother's HDTV. You should be able to hook up most standard dvd players to hdtvs. First you have 3 cords, mine were red, yellow, and white. The connections go as follows:
HDTV:
Audio| Component. The white cord should be in a white audio slot. The yellow cord should be in a yellow component slot (video) and the red cord should be in a red video component slot labeled Pr/Cr. Make sure you match the component numbers. For instance, if you want to use component one, then hook all of the cords into the slots for component one. Most hdtvs have multiple component hookups ( think multiple "channels" for your game system, dvd player, etc) so it's important that the corresponding cords go to the correct component slots.
DVD:
Match the yellow and white cords to the appropriately colored slots. The red cord should go into the slot labeled component video out Cr/Pr. Not the red audio out. This worked for me. Hope this helps.
Posted on Nov 29, 2008
tvservice306
  • 458 Answers
SOURCE: red blue green lines down my lcd tv screen
HP-R4252 NOT LCD TV
IF LCD TV has vertical lines try cleaning T-con board to lcd panel cable or replaced t-con board
Posted on Sep 04, 2009
vinnyq
  • 157 Answers
SOURCE: My wii connection is black and white
You are connecting it into the wrong input. The Wii comes with a RCA cables that should go into the Video (composite) input that has yellow, red, and white. The component input will not work with the RCA cable input. Plug your Wii into Video1 and you should get the right colors. There should be another HDMI on the side of your TV, there are inputs located both on the back and side of the TV for your convience.
Posted on Oct 10, 2009
SOURCE: Issue with LG Plasma tv model # DU-42PX12X
Another "same probelm"
My set has encountered this magical 50/50 split screen and it seems to be quite a problem since I am not the only one researching this issue. LG was of no use because of course it is just out of warranty. Any solutions on fixing this or am I out of money in buying a new plasma?
Posted on Nov 10, 2009
SOURCE: Sylvania LC320SLX always on with changing color
when i push power the green light flashes a about 3 to 4 times then turns off
Posted on Jun 03, 2010
My flat screen Sylvania TV is flashing different colors what's wrong
Better late than never. The problem is that your TV is in the service mode. There are many ways this can happen. But, lets just get down to fixin this! With the original remote and the TV on. If the TV will not shut off, do this. Press the left cursor button on the remote, followed with pressing the right cursor. Power off the TV with remote, or press off button on TV.
Secondly, your TV will power on and off. But you have flashing colors. Do this. With the original remote and TV on. Press the up cursor button, on the remote, followed with pressing the down cursor. Power off TV with remote, or press off power of TV. Thanks for asking me, Matt of Martins TV Repair.
Jan 20, 2016 | Sylvania Televison & Video
How to remove bezel on LD195ssx
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Disassemble procedure to many popular brand TVs and other devices are given in detail with illustrations.
Oct 24, 2014 | Sylvania Televison & Video
Screen only flashes colors, no controls function
remove power from the set and any box being used with it, after a while power both back up, a box or the set can cause this issue.
Dec 18, 2012 | Sylvania 32" Lcd Hdtv Dvd Combo - 720p...
Flashing 3 colors red, green and blue to turn it off I had to unplug it. Trying to switching from TV to DVD. This have happened before. I don't have a remote but the service man reset it some how
Download the user manual to your TV. It will have all details about how to reset it to factory default. A factory default set should be done now. To download its user manual, click here.
Jun 21, 2012 | Sylvania LD320SSX LCD TV
Sylvania 730SVD flat screen with built in dvd... Can't eject dvd inside and when turned on the digital words show up and keep flashing black gray green red... The remote won't even work..
Try resetting the TV by disconnecting it from the mains outlet for 1/2 hour, then connect to the main outlet and switch on the TV.
Feb 03, 2012 | Televison & Video
19 inch slyvania tv/dvd combo turn on play button stays on and the the tv goes to red green yellow and blue screen and won't do anything else
I have been having just about the same problem with mine, i can watch the tv for about 20 min and then the dvd player comes on by itself then it goes to red, green, yellow, and black and white, i've tried resetting the dvd player to default but it hasn't helped mine.When i try to turn it off it automaticly comes back on so i have to unplug it.If i find a way to make mine work right i will send you a message to let you know so you can try it on yours. I've had mine just over a year and i don't have a warrenty anymore.
Aug 08, 2011 | Sylvania LD195SSX 19 in. LCD TV
SONY DVD PLAYER DVP-SR200P BUT IT ONLY SHOW IN BLACK AND WHITE ?
You have posted this in the Panasonic DMR-ES30VS section.
Please note which product section you are in before posting your question.
For the Sony DVP-SR200P there could be multiple reasons for it only showing in B&W.
Was this a recent problem, is this a new hook-up, has it always been this way?
  1. In the setup menu there is a setting for Custom Picture Mode.
    Could someone have turned the color down?
    You can go to the setup menu and "Reset" the player to the factory settings.
  2. How is this connected to your TV?
    Check all cables to make sure they are plugged in, test each one by unplugging it, and then plug it back in fully.
    If you are using a composite cable (1 cable yellow plug), be sure you have plugged it in from yellow to yellow.
    If you are using the component (3 cables red-green-blue plugs) hook-up, be sure you are using cables only designed for component hook-up, and have plugged them in correctly, red to red, green to green, blue to blue (Be sure you've plugged the red cable into the red video not red audio).
    Are the cables in good condition?
    No breaks, loose connectors, they weren't smashed under a piece of furniture?
    Have you tried a different set of cables?
  3. Test the DVD player on another TV.
    Does the same thing happen?
    Did you "Reset" the DVD player?
    Maybe the DVD player is bad?
  4. Find another DVD player and test it with your TV.
    Does it work OK, or is it black and white too?
    Maybe the connectors on the TV are bad?
    Is there a custom setting on the TV for that connection?
    On some TVs you can adjust the settings for each input (INPUT 1, INPUT 2, ....) maybe the color setting is turned down?
There are may possibilities, but these are some of the basic things to check.
Best wishes,
-Greg-
Sep 13, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
DVD's play in black and white
anytime you connect componet signal (green red and blue)to regular video inputs (yellow) end will have same effect. make sure that if you are using component signal from dvd player you have to connected to component input in the set.
component signal will use green red and blue for video and red and white for sound.
Jul 01, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
96 people viewed this question
Top Televison & Video Experts
Electro Med Services...
