Question about Humidifiers
Where do i put the liquid fluid on the kaz safeguard 285 steam vaporizer
4 Suggested Answers
  • 123 Answers
SOURCE: Kaz 2100 Warm Steam Vaporizer was stored empty for
Chances are the rubber pump inside the unit cracked and will not work anymore. This type of unit is a "Disposable" unit and is not intended for repairs. Its cheaper to buy a new one then buy parts for this.
Hope it helps.
Posted on Jan 28, 2011
  • 40 Answers
SOURCE: Where do I add the
I believe that you just have to add it with the water in the container. Here is a video detailing the product and its use.
http://www.expotv.com/videos/reviews/11/128/VicksV-105SG10GallonWarmMistVaporizer/257785
Posted on May 20, 2011
SOURCE: steam vaporizer kaz, emites a black particules, in
This is considered normal. It's the residue left from the water vaporizing into steam. Since it's left behind in the chamber, you do not breathe it in. Other users have said that it helps keeping these minerals in the chamber and just adding water to mineralize the water in lieu of adding salt.
Posted on Oct 31, 2011
Where can i get a new water tank cap for vicks model V745A?
This is a POSSIBLE answer: I found the manual at the Vicks site, read through it, but it did not mention replacement parts at all. However, at the very end of the manual was this paragraph, which might serve as a way for you to get what you need. Quoting the manual:
If you have any questions or comments, call the Kaz Consumer Service Department at 1-800-VAPOR-1-2 or, e-mail consumerservice@kaz.com or, write to Kaz, Consumer Service
Department, P.O. Box 544, Hudson, NY 12534, explaining just how the product is operating. Specify model number. Our Consumer Service Representative will advise you how to correct the problem yourself, or will ask you to return the product for repair or replacement.
Aug 02, 2014 | Vicks Warm Mist V745A 1 Gallon Humidifier
Steam vaporizer kaz, emites a black particules, in the tank like sort of blak ink when finish using it, is there any problem with that???
Oct 05, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Kaz 2100 Warm Steam Vaporizer was stored empty for about an year. Today I filled it with water, plugged it in, waited and waited...... no results. Wouldn't start. There is no buttons to push, nothing to...
Hope it helps.
Jan 28, 2011 | Kaz 2200-6 2 Gallon Humidifier
I have a vicks hot vaporizer and the unit itself gets very very hot on the outside...it didn't used to do this, so i think it may be broken. im aftraid it will burn it is so hot.
Good day. Here is the link for the manual. Please note page four which shows your issue and some solutions. Let us know what works.
http://www.google.com/url?q=http://docs.google.com/viewer%3Fa%3Dv%26q%3Dcache:pbhjzMo9E3sJ:www.kaz.com/kaz/support/manual/%253FProductManualAction%253DrenderProductManualById%2526ProductManualId%253D5faaee9ab20669a0a26a9fb6e6bb99f8%2Bvicks%2Bvaporizer%2Bblack%2Bparticles%26hl%3Den%26gl%3Dus%26pid%3Dbl%26srcid%3DADGEEShoMFRd7NbKZtGZM-qKr0_rmMQA7bQYO-r4VBGXLFKF1WnqeeQZDdU6pMTOMcxsZMFqdAfWvECyUPTLsoW2KBMr3QBWzicSiUPyG1F8iW4Wmil0atnkfBT1ulKofnvo5HX1DBdR%26sig%3DAHIEtbS-BI2SvXCl3TTlcQduwYAGXqORQg&ei=nuZFS7_EPMiVtgf65bDrAQ&sa=X&oi=gview&resnum=2&ct=oth
Oct 18, 2010 | Vicks Warm Steam Vaporizer 1.5 Gallon...
How do I clean my humidifier?
I had the same problem. This will cause the orange reset light to turn on as well. You need to remove the reservoir and the cooling chanber. Under the reservoir there is a locking mechanism that you push to the side. You then pull off the cooling tower. Then you push the locking mechanism in the other direction and remove the steam mechanism. I found a month of build up of "gook" inside. Dump it out and use a scrouring pad to remove it. After this was done, I could smell the vapor from the medicine cup again and it ran all night on the high setting again.
Dec 16, 2008 | Vicks Warm Mist V745A 1 Gallon Humidifier
Humidifier leaves a crusty dark substance in water
SPECIAL NOTES
Discoloration/Black Particles
After use, the water residue in the bottom of the container may contain black particles, and, in
some areas the water and the bottom of container may discolor. These conditions are normal and
do not effect the purity of the steam or medicine. The container is easily cleaned with soap and
water. Rinse and dry the container after cleaning.
This was taken from the manual that comes with the humidifier...
Dec 12, 2008 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Humidifiers Logo
118 people viewed this question
Top Humidifiers Experts
Mack Baxter
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
