Question about Frigidaire FEF336BC Electric Kitchen Range
Electric blanket flashing f won't stop sunbeam
  • Official Brand Answer
  • 4,342 Answers
Hello vinrocof - Please try resetting the unit by either unplugging it or flipping the breaker off. Wait approximately ten minutes and turn the unit back on. Try setting the time and if it proves to be ineffective, the unit may possibly have a faulty EOC, defective wiring harness or damaged cord. I would suggest contacting a professional to move forward accurately.
Posted on Jan 15, 2013
3 Suggested Answers
SOURCE: Sunbeam Electric Blanket blinking
I had checked the "connection" at the blanket before but after reading this I unplugged it from the wall and re-checked the plug in at the blanket. It's not flashing anymore and it seems to be working.
From Sunbeam's site:
Q: What does "FF" mean on display of my control?
A: If you have a digital control, it is designed to flash "FF" on the display to notify you that a problem may have been discovered. Gradient controls and warming throw controls use a blinking indicator light for this purpose.
Follow the instructions on the flag tag to reset the control or follow the steps below.
  • Unplug the system from wall outlet.
  • Check that the control is well connected to the module.
  • Plug the power cord into the wall outlet.
  • Set the control to "on".
If the system still does not operate, disconnect the power cord and Contact Us.
Posted on Dec 02, 2008
SOURCE: Binking light on one control of electric blanket (Sunbeam)
I'm not sure how I was registered as having a problem with an electric range; my problem was with my Sunbeam electric mattress pad.
I used one of the suggestions I read here. I unplugged the connection to the mattress pad and blew into the receptacle to clear any dust or lint from it. I reconnected everything, plugged it in, and the problem has been eliminated.
Thanks for the suggestion.
Posted on Oct 06, 2009
Why does the light keep flashing red on my sunbeam electric blanket control remote? It just keeps flashing on high I try ed unplugging from the outline and the blanket nothing works. It started doing this...
There is a problem with the blanket. Since it started doing this just after washing (as per instructions), I suspect that somehow - running it thru the washer caused the problem.
Since it is an electrical device, if allowing to air dry thoroughly doesn't let it work as expected, you should stop powering it - and use it only as a non-powered blanket or discard and replace.
Feb 03, 2015 | Miscellaneous
The 2 controls to our electric blanket are flashing "FF". What does that mean, plus there's no heat at all from it.
With the Sunbeam blankets that I have owned, FF meant that there was a bad connection somewhere. Have you tried the unplugging and replugging the Controller cord back into the blanket? Make sure it is plugged in GOOD AND TIGHT. If that part is connected as tightly as it can go, you may have a defective element.
Dec 18, 2014 | Sunbeam Pac 259 Dual Electric Blanket...
I have a fitted single Sunbeam electric blanket that has stopped working. Can it be repaired?
If it is a problem with the controls they can be replaced.If it is a break in the internal wiring then you will need to get a new blanket. Thank you
Jun 11, 2011 | Sunbeam 722510 Electric Heater
My husband and i were just recently given the queen size, dual remote heating blanket from you guys. When we try to turn on either of our remotes, it flashes F2 consistently unless unplugged. Is there...
The first link has some info about the F2 code.Apparently it used to be seen as FF but was changed.It is a power problem.It is still the same problem,which is REALLY not good.The next couple of links are forums which people also have the same problem as you.I would seriously get rid of that blanket.I saw someone mention EMF.I know exactly what EMF is and it is not an issue with this blanket at all,and is present in many things.A microwave probably has more,and still is not an issue.Anything that plugs into a wall has some form of EMF present,so do not even worry about it.
http://wiki.answers.com/Q/What_does_the_flashing_code_F2_mean_on_the_Sunbeam_Dual_Electric_Blanket
http://www.consumeraffairs.com/homeowners/sunbeam.html
http://www.complaintsboard.com/complaints/sunbeam-westpointe-amp-jc-penny039s-electric-blanket-c40368.html
http://www.complaintsboard.com/complaints/sunbeam-heating-blanket-c134216.html
Nov 28, 2010 | Sunbeam Heating & Cooling
Sunbeam Queen Size Electric Blanket Flashing F2
it means there is some sort of problem somewhere with your blanket .
Oct 08, 2009 | Kitchen Appliances - Others
Electric Blanket Control Blinks
mydual control sunbeam electric blanket blinks on one control
Dec 23, 2008 | Sunbeam 4237 / 4238 Iron with Auto...
My Sunbeam electric blanket controls blink when I plug the control cable into the blanket. I cannot turn the controls on or off.
Same problem, but now it is ok.  I emailed Sunbeam and was told that if my blanket was not plugged directly into a wall outlet it was not getting enough power and I needed to plug it into a wall outlet taking these steps:
1) Unplug from the surge protector/extension cord 2) Unplug from the blanket 3) Plug back into the blanket 4) Plug into a wall outlet
Jul 21, 2008 | Heating & Cooling
Frigidaire FEF336BC Electric Kitchen Range Logo
292 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
