Question about Handspring Visor Pro Handheld
Visor will Not Turn On
A friend gave me a hand-me-down Visor, one of a pair of used ones that a friend had given her. I don't have all the details, but she said it was running, then went blank. She tried resetting it with a paper clip, and it stayed blank. I have not been able to get it to turn on, either. I've tried both a hard and a soft reset. It has a square battery at the top of the case. This is different from an online manual, which shows a pair of AAA batteries being used. I don't know if the square one is rechargeable. It says "InnoPak/2V". I left it in the cradle plugged in overnight, still won't turn on. Contrast button area does not do anything.
I have a Visor Platinum that has started doing the same.  In my case, two things have helped in the past.  (1) Mine has a built-in lithium battery pack.  The first time the problem happened -- the battery was dead -- I cleaned its contacts and where it mates into the PDA with some rubbing alcohol and a cotton swab and recharged.  (2) Second time it crashed, the problem was with one of the programs that I had installed (some freeware).  The program would cause the PDA to hang during and alarm and make it stay ON till the battery ran down too far.  Solution was to not install the add ons.  To wake the PDA the second time, I placed it on the charger for a minute, took it off and immediately tried the different resets.  Tried the entire process 10-15 times and finally managed to wake up the PDA.  Once awake, let it finish charging before you do anything.  It might prompt you to set the date/time etc, but just wait till it is done charging otherwise it will go back into its coma.
Posted on Oct 25, 2007
SOURCE:
I have lost the user guide for my hands free super tooth visor go R60. How do I get it into pairing mode?
Hold the green button down for about 5-10 seconds until the light flashes blue and red alternatively. When it does this it means the device is ready for pairing mode. On your phone, on the bluetooth setting, set yoru phone to be discoverable. It should find the visor and if it ask for a passcode enter 0000 (four zeroes). this should do it.
hope this helps.
May 05, 2011 | Cell Phones
Tip
IPhone bluetooth to Blackberry VM605 visor speaker
Couldn't get them to pair... then tried this: On the VM-605, Press the FM key (left hand side) and the Volume key Right Hand side for 4 seconds. After 4 seconds the the VM-605 says "In Pairing Mode", you can there search for the device on your Blackberry in Blurtooth mode and it will allow you to pair using the default key of 4 x zeros
on Jun 29, 2010 | Cell Phones
I have lost my instructions for my Supertooth Visor Go Model No. BHSTLGO and I need to pair it with my new mobile phone?
With the Supertooth switched off, press and hold (for 5 secs) the on/accept button. The lights will flash intermittently.
Then set your mobile phone to search for pairing on Bluetooth. When asked for a code type 0000 (4x zero)
Then the set will be paired.
I have just been given one for christmas and have just done it with my iPhone. Easy as peasy !!
Nov 20, 2010 | Handspring Visor Prism Handheld
Turn on the bluetooth
Turn the bluetooth car kit off, by pressing the MFB for some seconds. Now, press and hold the MFB until the blue and red leds blink simultaneously. Then, if your phone's bluetooth radio is off, turn it on, and make it search for other devices (check your phone's user manual for further details). When the Visor Drive is shown, select it to be paired, and if a pairing code is requested, enter '0000'.
Hope it works for you.
Cheers! Carlos
Apr 22, 2010 | Handspring Visor Prism Handheld
What is the pairing code for a pama visor mounted
Hello Give this a go
Sunvisor range
PNG8......8888
PNG9......8888
PNG10....8888
PNG11....8888
All The Best Jon Bodley.
Sep 21, 2009 | Cell Phones
Seal handsfree not pairing
with the phone's bluetooth active
press button to turn the seal device
press blue button on seal device
on phone, select pair new device
when the seal device is found, use code 0000 to pair the phone to the device..
next time you connect, turn on the phones bluetooth and the seal device. press blue button on seal device. it should automatically pair.
Sep 15, 2009 | Handspring Visor Prism Handheld
I am trying to pair Visor Blade,Supertooth-Lite with mobile phone
Try holding down the green button release the mike then enter 0000 the phone should then pair. This worked for me so I hope it will work for you.
Mar 16, 2009 | Cell Phones
Nokia 6300 will not bluetooth my visorlite hands free kit
Hi
I had the same problem go to this web address you will find a manual for a similar model.
http://www.mobilefun.co.uk/graphics/misc/btvisorl.pdf
Just hold down the green dial button on the speaker open the speaker slide to power on the unit hold the green phone button down for two to three seconds the light will flash from blue/red continuosly and then pair it from your phones bluetooth menu.
The 6300 is def compatable with the visor lite 1.60 My firmware on the phone is 7.21.
Regards
Steven
Jan 24, 2008 | Nokia 6300 Cellular Phone
Handspring Visor Pro Handheld Logo
251 people viewed this question
Top Handspring Computers & Internet Experts
Anthony Ward
Anthony Ward
Ekse
Marvin
Marvin
Are you a Handspring Computer and Internet Expert? Answer questions, earn points and help others
