Question about Classic Electronics CDR201 CD Recorder
Convert cassets to cds on classic recorder model cdr200
I have separate cassette player and I want to transfer music from cassette to cd through Classic recorder model cdr200. What is the connection?
  • 341 Answers
Connect the Play or out from the cassette and connect to the rec or in on the CD recorder using some descent RCA cables. Good luck!
Posted on Jan 20, 2013
SOURCE: will not record
the classic cdr201 will not record it will go to wait and return to cd status(blank cd etc) there is no led display of sound during this operation you can hear the audio for brief couple of seconds before it goes back to cd mode
Posted on Jan 13, 2008
Basti
  • 1447 Answers
SOURCE: need a manual or need to know how to work the recorder
Check this this might help:
Emerson
Posted on Apr 29, 2008
dnewcombe1
  • 1564 Answers
SOURCE: i have a classic cd recorder player need manual
Go to the manufacturers site and under "support" type in your model number and you will be able to download and or print the entire owners manual. The reair manual will cost a few dollars but the operators/owners manual will be free. This is all ppproviding that they are still in business. Thank you, Dana
Posted on Oct 09, 2009
SOURCE: I need to find the correct brand of recordable
Any CD-R will play, if your player is picky about the recorded discs, make sure you record it at a very low speed. 2X is optimal but very few actual recorders support such speed, try the lowest one.
Also use high quality discs like Verbatim, the best ones have a blue background on the record side.
Posted on Oct 27, 2009
SOURCE: i have a classic cdr201
you need cd-r music cd not the computer ones.
i have model cdr200 works with the ones that say music on disc.
hope that helps
Posted on Jan 28, 2010
How do I rcord from another source of input
This is not the machine that I own, so I would suggest that you find a manual specific to this one and check it out.
Sep 27, 2014 | RCA CDRW120 2-Disc CD Recorder
Instruction Manual for model 2034
there is no manual,
Tape-2-MP3 Converter/Player
Convert your cassette tapes to Audio CD or MP3 files with 3 simple steps! Connect portable cassette player/converter to PC or Mac via USB cable. Transfer by Installing provided software and simply press "RECORD" while playing the tape. Create MP3 files from transferred audio to burn to CD or import to iTunes for use on your iPod device.
USB-to-Computer Recording
Convert from cassette to digital formats directly to your PC or Mac computer via USB cable and simple Audicity® software, both included.
Feb 17, 2014 | Encore Technology Portable Cassette...
Can I record from a cassette player to the koss
should be able to go directly from tape out of cass deck to input of your koss, as long it has line level inputs (which it should). from there its play on the tape and record on the cd rcrdr. seems the simplest solution
Jan 30, 2010 | Koss CDR200 2-Disc CD Recorder
Only records Lps and CDs, but not other cassettes
there are programs on the net that will copy from tape to cd via the computer if you have a cd writer on the pc hope this helps regards Jim
May 02, 2009 | Audio Players & Recorders
I have a classic cdr201 recorder, when i go put a disc to record it says WRONG DC? i need to burn cds
hope that helps
Jan 27, 2009 | Classic Electronics CDR201 CD Recorder
CDR200
Push CD Sync...when goes into it....push record or pause....like a double tape deck.
Jul 11, 2008 | Classic Electronics CDR201 CD Recorder
Cdr200 recording
Your CD recorder has 2 sets of phono (rca) sockets on the back. You probably have the outputs connected to your amplifier & speakers. All you need to do is connect your tape deck (or any source except for a turntable) to the inputs sockets on the back of the CD deck.
You might need to switch to external or analogue recording on the recorder.
If you are going to be doing a lot of this type of recording & want it set up more permanently, it might make sense to reconfigure your hi-fi. Shout if you want help with this!
Jan 09, 2008 | Koss CDR200 2-Disc CD Recorder
KOSS CDR200
can I record from an outside source, like a casset player to cd, on the cdr200, if so, how, thankyou
Nov 25, 2007 | Koss CDR200 2-Disc CD Recorder
Koss cdr200 dual burner
I had an issue similar to this - I found if I didn't try to record from the internal player it worked ok. Does it say 'recover' when you try to record anytime? If you open the unit,you might see some capacitors on the power supply on the left hand side have leakedand the power is cutting in and out. 'Recover' usually comes up when a recording is interupted if you switch the unit off during recording.
Aug 28, 2007 | Koss CDR200 2-Disc CD Recorder
Lost the manual, can't get hooked up
You need to use an audio CDr, data or computer CDr's will not work in this machine. I don't know this specific machine, but usually you select the input, then 'rec type' eg manual,1 track or 1 disc,then press record to get into record pause,start your source,then press play on the unit to start recording. To finalize, you press finalize then either the play or rec button to start the finalize process.
May 28, 2007 | TDK DA-3826 2-Disc CD Recorder
Classic Electronics CDR201 CD Recorder Logo
181 people viewed this question
Top Classic Electronics Audio Players & Recorders Experts
Jonathon summesfield
jasbo
jasbo
Robert Rankin
Are you a Classic Electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
