Question about Audiovox FPE2705 27 in. HDTV-Ready LCD Television
I can't find the part with this # L1050 HA
This part blew on my TV L1050 HA its found on one of the boards. thanks.
I have a Syntax Olevia 20HVK, we had a brown out and the tv went out. I opened the tv and found a blown fuse in the power supply, I replaced the fuse and the fuse blew again. should i just replace the...
you have shorted power transistor or mosfet on power supply that need to be replace however this need a soldering skills and electronic background if you don't have skills its better if you replace the whole power supply board.
Nov 03, 2012 | Televison & Video
42LG30 LCD watching TV last night and the colors just went wacky. seems to be to much red, brighter shows ha e the most color distortion. I tried the expert color controls to fix it but it didn't work....
The TV will need to be properly diagnosed to be sure of the problem. A defective power supply output, main board, LVDS cable connection, t-con board or t-con/LCD ribbon connection can cause video display issues.
Oct 12, 2012 | Televison & Video
Hitachi 57f500a e907 fuse blew on the power supply board, replaced e907, and it went again. Is this a problem on the power supply board or the deflection board? Where should I start looking next?
If QH01 is shorted again, then this is an indication that the FBT is already faulty causing QH01 to shorts right away and blew E907(self destruct when shorts occured on the line). 100VDC isn't causing E907 to blew, you've only got 100VDC because the FBT didn't oscillate yet. Before you replaced the FBT make sure to test all parts parallel on the B+ line like DH09, Q701, CH16, CH13, CH20. It is better to pull-out the FBT while testing the shorted/leaky parts on the board to make your reading more accurate. If you found the said parts to be in good condition, then you have to replaced the FBT.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Nov 03, 2011 | Hitachi 57F500 57" Rear Projection...
Olevia 537-b11, blue light won't come, even when power cord is replaced. Please help!!!!
Since you've already replaced the power cord and still the led light won't came on, this is an indication that the power supply board of your unit is dead. If it is not under warranty period(if so, avail it because the manufacturer will fix it for free) open the back cover and check the continuity of the fuse using the multimeter, if you found it open replaced it with the same current(ampere) ratings and then try to turn on the TV. If the replacement fuse blew again, this is an indication of more serious problem on that board. If the replacement fuse didn't resolve the issue, other parts on that board gone to malfunction as well. If this is the case, I would advice you to replaced the entire board for your convenient. The cost will almost the same rather than troubleshoot it. Check the actual part no of your board and check this LINK.
Hope I helped you.
Have a nice day!
Thanks for using fixya.
Sep 09, 2011 | Olevia LT37HVS 37 in. LCD HDTV
I blew a fuse and everything in my room, computer, playstation and the tv turned off. When i switch the fuse back on, the computer and playstation was working but the tv is not. Is there a chance that I...
Hi Jonathan,
Yes, if there's no LED light at the front panel of the TV, this is an indication that the power supply is not working (I'm assuming that you've already tried to plugged it in to other working outlet). First thing to check is the internal fuse of the TV. If you found it open, replaced it with same current(ampere) rating and try to power it on again. If the new fuse blow again this is an indication of more serious problem in the power supply. You may replaced it with a new board or seek for an assistance of a qualified TV technician to troubleshoot the board.
If you found the fuse intact, still the same problem(power supply board).
Please let me know if you need further assistance.
Hope I helped you.
Have a nice day!
Aug 20, 2011 | Televison & Video
My maxent p420142x3 has sound but no picture?
ha ha ha this problem is caused by the Y-SUS or Y sustain board (any name is used for it) if you open your tv you coud see around 4 big boards, the left is the Y-sus, if you test its two fuses you can see one of them are blown that means that your YSUS is blow it, the part is 6871QYH953A. and the price is from 35 (the fix kit) to 280. I'm sorry for my laugh but I had the same problem and found it that this model of board is LG and around 18 brands and diverse model of TVs have inside this piece of **** and all of them have the same problem sound and no image.
greetings
Jun 30, 2010 | Maxent MX-42HPM20 42 in. Plasma HDTV
It was wet under it
If you saw arcing chances are that the board is definately fried. Just be sure the board is called the power/filter board if you dont have the proper number
Apr 21, 2008 | RCA P52926 52" Rear Projection Television
KV- 32V40 Fusible resistor always blow-up
hey...glad im not the only one in this mess....thank god i have an electronics background as i my offer some help. i found that Q601/Q602 were shorted,replaced with NTE2582 transistors, but also there is another fusible resistor located next ti the transformer on the powersupply board(board G i believe)same as the other(1/4-1/2 watt .1-.15 omhs)well i thought all was well until i pluged it in and both fusible resistors and the transistors blew right away....led me to the H-OUT transistor, right next to the flyback, on the main board...sure enough it was shorted as well. that part is 2SC5148(not the NTE part #), , and will put it in after work tommorow...looks good so far and will, even with my mistake will cost several hundred dollars less than taking it to a tv shop...and thousands less that the plasma screen the wife wants....this 32inch has been good to me for 9 years, and im going to help it along for another if possible. you cant email me at kellysheros@aol.com if youd like.....thanks and good luck
Nov 06, 2006 | Sony KV-32S26 32" TV
Convergence/power off
no sundog this model has the potenthal to be a nice tv when you saw the burn't resisters that was your clue to change the stk's now that you have fixed the res problem the bad stk is telling the set to shut down replace stk,s i ALWAYS change both (buy the way in the future those are hi watt res THEY SMOKED FOR A REASON maybe you thought they were installed in the 70"s ha ha. but they smoked because the stk's one or more are bad. good luck doc
Aug 11, 2006 | Panasonic PT-51HX41 51" Rear Projection...
Audiovox FPE2705 27 in. HDTV-Ready LCD Television Logo
56 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
romy sibug
romy sibug
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
