Question about Samsung LA32B450 32 in. TV
When turn on the picture appeer one seconde and dissappeer to black screen sound okk
Power supply incloud inverter bn44-00289a
4 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: sound but no picture when tv is turn on i get a
The 24vdc may be bad due to bad caps, or it senses short circuits in the backlight inverter board and goes into shutdown.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make a kit for you.
Posted on Aug 14, 2010
SOURCE: I have a Samsung ln
I have a 46" Samsung LNT4665 with the same problem. Originally had the power supply replaced but 1 day later I have this problem. Auth. repair shop says it's likely inverter, but apparently can't be replaced separately, must be replaced with panel ($700 , and labour on top) might as well buy a new TV.
Any suggestions? I have seen the inverter sold separetly on some websites, anybody try replacing that part?
Posted on Oct 24, 2010
SuperTech-11
  • 1591 Answers
SOURCE: When I turn my tv
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both. In your case, it could be either.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom (look for discoloration of the circuit board around the base of the capacitor) need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the unit will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and/or inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are SURE it's only doing supply output ripple filtering,
and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
Backlight related video here:
http://www.youtube.com/watch?v=6XoF6QZ1dmw&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors, amplifiers, computer power supplies and motherboards, and other electronic equipment.
The parts are cheap, and skill required is minimal.
A great parts source is Digi-Key, and you can order the parts online at www.digikey.com
They typically cost under a dollar a piece plus a flat shipping rate.
The parts usually arrive one business day later.
If you watch the third video, you will see that even someone with no soldering experience can perform these repairs as demonstrated by the woman in the video.
Posted on Jul 27, 2011
Tv has no picture but has sound
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Dec 01, 2015 | Televison & Video
Proscan 32LB30QD TURN ON SOUND BUT NO PICTURE
Sounds like a bad inverter thats what powers up the backlights so you can see the picture on the screen. usually its about 85% of the times the inverter if you have pefect audio and remote functions but a black screen in a LCD modeel TV. You can get the inverter board from www.tvrepairworld.com
Jan 12, 2013 | Proscan 32LA30Q Television
When I turn my TV on there is sound, but, the picture vanishes after a couple of seconds. Why?
The backlight inverter is what powers the screen to "light up." You will need to check your power supply for the proper voltages going to the backlight inverter. If those all check out ok, then you need to replace your inverter to get your image back. You can find a new inverter by searching "inverter + model number of your tv.
Please rate if this helped :)
Apr 04, 2011 | LG Televison & Video
My Westinghouse SK-32H540S pictures shuts off after 10 seconds. the sound stays on but no picture. is it the troubleshoot? i tried unpluging everything and repluging it and still the same thing happens...
This problems are the tv 1 or 2 long LCD inverter boards are dead.These 1 or 2 long LCD inverter boards provide the tv LCD screen pannel a backlight to produce a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes 1 or 2 long LCD inverter boards for the replacement.
Mar 24, 2011 | Westinghouse SK-32H540S 32 in. LCD TV
Shows picture for a second when i press button than goes dark
Issues with back light:
Please do not attempt to diagnose if no competent.
Do at your own risk.
Check for 24 Volts power to the inverter board
No Power---Check Power Supply
Power Present---
Verify status voltage 3v to 5v on inverter board harness (plug)
Replace Inverter Board
Feb 11, 2010 | Tatung V30DMTT 29.6 in. LCD Television
Black screen but get sound. picture flashes every
This sounds like a power supply issue. TVs operate on DC current and therefore must have a power supply board to invert AC house current to DC as well as regulate the DC current supplied. Heat is created by this process and therefore certain components on power supply boards are prone to failure due to repeated overheating. I would suspect capacitors on the power supply board are failing so they are only able to store enough power to allow the video board to work every 30 seconds and then it shuts off again. You can replace the whole board but I have repaired these before for a few dollars and some soldering.
Nov 29, 2009 | Sony KDS-55A2020 55" Television
I have 2 ViewSonic N2750w and and they both have black screens
i have repaired several n3750w viewsonics .. that may be similar to the 2750 .. in my case all the failures were caused by the same faulty part in the power supply .. the power supply has a 48 volt supply at about 7 amps .. the design uses a syncronous rectifier .. these are normally not used in supplies with that high a voltage out .. syncronous rectifiers make sense when the output voltage is low .. like 3 or 5 volts .. the parts are designed for that range .. but in this supply an IC is over stressed and fails frequently .. you might hear a chirping sound as the supply cycles thru an overload condition .. i modified the power supply to eliminate the syncronous rectifier and replaced it with a single shottky diode .. dissapation goes up slightly but reliability goes up a lot .. i have written an article on this. if anyone needs it i will try to find it . ..
Jun 05, 2009 | ViewSonic N2750w 27 in. HD-Ready LCD...
Sanyo ce32ldy1b lcd 160gb black screen with sound
It sounds like you have a power supply problem, this powers the inverter! Where you just replaced the inverter, we could assume it is good! Look for some bad caps (capacitors) on the power supply board. They will look bulged on the top an may be a little leaky (brownish stain). The power supply can fail on some output and be good on others. Was the back light inverter new? If all else fails, see if you can return the back light inverter and get another! I hope this is helpful!!
Mar 01, 2009 | Sanyo DP32746 32 in. LCD Television
Loss of picture
change your inverter
Sep 17, 2008 | Polaroid TLA-01911C TV
Samsung LA32B450 32 in. TV Logo
43 people viewed this question
Jerry Greenberg
Jerry Greenberg
