I have AUSU M2N-E Motherboard and running Windows vista and Have 6 channel home theater connected with SPDIF cable. but mother board not showing 6 channel suppport
  • 1 more comment
  • Jose Velazquez
    Jose Velazquez May 11, 2010
    What you are need of is an audio program with SPDIF support this will configure your digital output to allow PCM audio passthrough. Is the sound integrated or on a sound card?
  • Mike Davidson
    Mike Davidson May 11, 2010
    I guess you are only using the on board sound and not a sound card?
    Is that is the case, it will not work because the MB does not support it.
    Pls let me know.
  • Misterixas May 11, 2010
    What do you mean by "motherboard not showing 6 channel support"?
    Have you correctly connected your home theater via coaxial SPDIF cable?
    Have you correctly installed your motherboard drivers from given drivers CD?
    Have you checked "Enable SPDIF out" or similar in your sound card options menu?
    Have you changed input/source on your home theater menu?
    Problem Solver:
  • 21 Answers
You need to install the software from the maker of the sound chip to get that panel looks like its ADI AD1988 and its 6 plugs but 8 ch i dont have one of there boards to test it on but i beleve this is your link http://drivers.softpedia.com/get/SOUND-CARD/OTHER-SOUNDCARDS/Analog-Devices-Adi-AD1988-510035010-whql.shtml
Posted on Sep 21, 2009
While connecting web cam to computer (mother board ASUS M2N-E SLI) the message of the system Excess of throughput of USB contrller
The camera needs more power than what the USB socket can deliver - 6 watts. Since a webcam normally uses less than 0.5 watts then either the cable or or the camera itself are defective.
Time for a new one.
Jul 03, 2011 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
I have a ASUS M2N MX mother board and i lost my driver copy i installed windows7 in that but no sound output produced what will ido plz teill me
It doesn't appear that Asus supports Windows 7 with this motherboard, only Vista. The available Vista drivers are available here. Often Vista drivers will work on 7, so just select your architecture, 32-bit or 64-bit and download.
You can also try downloading this driver, which is which is said to work with the on-board audio.
I hope this helps
Ray
May 12, 2011 | ASUS M2N-MX Motherboard
Is there a chip set for windows vista home premium 32 bit. When I bought my computer I had Vista installed on it and my computer constantly crashed. I had a guy fix my computer, said there was no chipsets...
The chipset (nForce 500) is soldered on the motherboard, it can't be changed. The problems you encountered were probably caused by bad drivers. If you choose to reinstall Vista don't use the driver's disk that came with the pc, get the latest ones from here
http://www.nvidia.com/Download/index5.aspx?lang=en-us
But if you have the money you should buy Windows 7 , it's much better than Vista.
Apr 16, 2010 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Asus m2n-mx audio driver for windows 7
Go to asus website.. if dont have for windows 7 use vista drivers. if W7 prompts warning just ignore and continue install..
Nov 22, 2009 | ASUS M2N-MX Motherboard
I have asus m2n-mx mother board amd 3600+... i have tried installing vista n windows7 in both i can run for some time later i get a blue screen is there any specific driver to be installed to stop this...
Yes, you are right, It is possible that your motherboard cannot support Vista O.S.. Reinstalling Windows XP
O.S. will prove it. If XP works, you 100% right.
Nov 14, 2009 | ASUS M2N-MX Motherboard
ASUS M2N-MX SE Plus mother board windows 2003 audio drivers
It is better to install   windows xp..  because   2003  is not supportting  latest mother boards.
only windows xp  will solve that problem
thank u.....
Nov 19, 2008 | ASUS M2N-MX Motherboard
Local area connection, no internet connection
My guess is the LAN port on your motherboard is bad. The simple solution would be to add a PCI ethernet card and disable the one on your motherboard in device manager.
Jun 18, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
No signal to monitor when booting.
(1) Remove memory from mother board and start the system if you happen to listen long beep then RAM is not working properly.
(2) Clean RAM conducting area on mother board with clean cotton cloth, put one peice of RAM and test and check the othe peice also, if working you could any sign display . Before doing all these check mother board any LED is glowing if so your SMPS is working after you turn on UPS.
(3) Check for all proper connection for all cables. Have you connected video cable of monitor to mother board VGA (it will not work because it is disabled as soon as you installed XFX GeForce 8800 GT), your viedo output only will come through XFX GeForce 8800 GT VGA port.
(4) If propelm persits Deassmble complete the system and reassmble & do n't connect HDD, DVD, floppy. Cehck with bare mother baord, processor, RAM (put one picese at a time) by connecting viedo cable of monitor
Apr 19, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
