Question about Philips GC 7220 Iron with Auto Shutoff
How do you remove the bottom from a GC7320 to replace power cable
GC7320
read the steps and fix it. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Jul 29, 2013 | Irons
GC7320 : my appliance has been well rinsed out, but is unable to produce steam when it starts to 'pump'. What should I do, please?
see the instruction and fix it. God bless you
Clean an iron:
My Phillips gc7320 steam iron keeps spitting out brown water what is the best way to clean the chamber
Hi joseph mc410
Go to HomeDepot,Lowes,WalMart,any hardware store,etc.
Purchase some "CLR" mix it according to the directions on the bottle and pour it in your iron and let it work...then pour it out, flush with distilled water and you should have cleaned your iron now.
Please take time to rate me
Sep 19, 2011 | Irons
Power cord on rowenta dm991 is split- needs a new one- can I do this myself?
On the end of the iron there are 2 screws - remove them; on the bottom of the end there is a small slot - put a small screw driver in the slot and pull on the end; you will find the wire that goes into the iron - get a replacement from an iron shop and you are good to go!
Dec 14, 2010 | Rowenta Ultra Professional DM991 Iron
Damaged mains cable
it is betterr to get a sealed power plug with the nylon insulation for the iron with a 15 amps rating wire and plug.
open the unit and disconnect the wire of the damaged plug, remove and replace with the new one taking care to connect each of the wires to the correct position. The lead , neutral and the ground must be double checked before you switch on.
Aug 29, 2010 | Tefal UltraGlide Easycord FV4256 Iron
Rowenta model dm 860 loose power cord
Most high end appliances (like Rowenta Irons) are made so repairs like that can be done. I haven't played with that model, but I did replace a cord on my Norelco. The torx screwdrivers you are looking for can be purchased, and are often found at either specialty electronic stores (not the average Radio Shack), automotive stores and quite readily online. They are also known as Torx Security bits or Torx Safety bits. Most appliances are made with those screws to prevent the average person from having a go at trying to fix it, but, if you feel comfortable enough with the electronics (even just to look for a loose connection), the bits are available and usually at a fairly decent price.
Jul 22, 2009 | Rowenta Irons
Removing deposits on iron plate
Try adding some CLR to the iron, fill it up with water, and run self clean. Then wipe bottom of iron with an old towel. Repeat with clean water in the iron, to rinse out the CLR and minerals.
Jun 21, 2009 | Rowenta Power Duo Iron
Shark euro-pro iron cord replacement model 4750
six screws on bottom plate two hidden under rubber feet on bottom under lower screw holes
Nov 18, 2008 | Euro-Pro Shark GI490 Iron
Light comes on, but iron will not heat up
Like what was posted before, the cause of the iron lights is on but the heaters are not hot is because either your heater connection is melted or rusted due to water seepage(steam irons). The lights power supply are tapped parallel to the heater supply thus lights is on. Solution is to dismantle the iron to replace the connectors or cables. Though not all iron is easy to dismantle
Nov 13, 2007 | Irons
How to dismantle a Tefal Aquaspeed 150
no, its not the Aquaspeed 170, but Aquaspeed 150. i succeded to unwrap the housing, but did fail in disconnecting or dismounting the power cord terminal.i could not disassemble the Iron to reach the heater. to dismantle, step 1 unscrew 3 visible screws. step 2 lift the heel cover away, by unsnapping 1 hooks at the right and one at the left side of the heel cover. i used thumnbnail to deform the heel cover for not to wear out the snap-in hooks. step 3 remove the dischalk stick (don't know the right wording in english) step 4 lift the top cover (which covers the spray jet part), 2 hooks at both left and right, use thumbnail or flat screwdriver, start at the top hook. step 5 take off the spray and steam buttons, 1 hook at the front side, 1 hook at the outer back side step 6 take off 2 screws: one keeps the upper half of the handle, the other fixes the water container at the heater plate. Attention: when unmounting the container, and turning the iron upside down, a small (4mm diam, ~10 mm length) silicone cylinder part will fall out, some kind of actor of a bimetal thermo switch in the ground plate, which probably controls water flow (not the electric thermostate) so far so good, i got my problem solved, but would like to know how to disassemble the container from the ground plate and how to replace the cable?
Apr 12, 2007 | Tefal Aquaspeed 170 Iron
Philips GC 7220 Iron with Auto Shutoff Logo
Top Philips Irons Experts
ray gallant
Are you a Philips Iron Expert? Answer questions, earn points and help others
