Question about Intel D865GBF Motherboard
Intel 865gv motherboard hanging problame
My Intel motherboard with intel 3.0gh proccessor, 512mb RAM is hanging problame after Assambel in Cabinet but, after remove from cabinet & start to openly it is working properly.
so, i need Exact Solution about it.
Tanks&Regards,
AJAY PAWAR (Syatem Admin)
    Problem Solver:
  • 9 Answers
Just your bolt screw have a conductor when u bolt in the motherboard to avoid grounding in the cabinet...
Posted on Jan 23, 2009
I have pc p4 3.06 intel processor and i hav now DDR1 RAM in my pc can i use ddr2 ram by removing ddr1 ram will my motherboard support ddr2 ram
Sorry but you cannot interchange ddr1 for ddr2. They are different kinds of RAM, and your chipset (865GV) can only accept ddr1. If you want to use ddr2, or even ddr3 then upgrade to a newer motherboard.
Mar 09, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Mother board is hang while formatting.Intel PENTIUM-4 865GV CHIP MOTHER BOARD Motherboard
kindly clean the ram and if there is more then 1 ram in motherboard removed that and try installing with single ram. also check the fan is working fine and .the heatsink in not too heat. chek the media cd also .
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 23, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Audio Drivers
You should be able to find the drivers at
http://downloadcenter.intel.com/default.aspx?iid=gg_support-EN_01+home_downloadctr
You need to know the chipset and the board designation. The board model should be obvious on your motherboard. Also the chipset drivers may be specific to your Operating System.
Jul 24, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard: RAM IS NOT WORKING. SUPPORTING RAM REQUIRED, CAN Y...
*********** supports DDR1 type Ram, you can easily get it from the market. Just ask the retailer to give you the DDR1 Ram, they will ask you how much memory of Ram you want. There are 256Mb, 512Mb, 1gb, 2gb, etc.. the more the better and this motherboard supports upto 2 gb, but some newer make of this motherboard miht have been changed.
May 17, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Window instolation bootig files for hanging
Refix your RAM also check your hardisk is properly detected in bios .
Load optimal defaults settings in bios.
Aslo try with other bootable disk some times disk corruptation create this problem.
Jul 23, 2009 | Intel Motherboard
PC TAKING CUT OFF AT UNSCHEDULE TIMING BUT GREEN LIGHT OF CPU ON
re assambel ur cpu
pick out ur pro , ram and battery cell from motherboar and clean ur pro fan properly with air. and re insert all after 5 mint
and then start ur pc then it is ok
if not then chk without ram on ur pc is it beep if yes then clean ram and re insert it then start if not then change ram moduel with new one.
Jul 02, 2009 | Intel Computers & Internet
About intel 865 motherboard
i have intel 865 motheboard but it's restart or hang after one hour & when it restart automatically getting display problem please help me
Aug 20, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Pc hangs up oftenly or show blank screen
Set your C Drive as Master and other all Drives as Slave
I Think this will slove your problem
Try IT
Mar 07, 2008 | Intel D845GVSR Motherboard
Memory Support
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
88
Nov 17, 2007 | Intel D845GVSR Motherboard
Intel D865GBF Motherboard Logo
81 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
