Question about Pioneer VSX-D488 Receiver
Help please when i power the reciever on it says power off and then shuts off automatically. any help would be appreciated!---tom---
  • 20 Answers
The very FIRST thing to check is to make certain ALL of your speakers have an IMPEDENCE of 8 OHMS. Virtually all speakers of even modest quality will include this specification on a label on the back of the speaker. You CANNOT run more than (2) TWO speakers with 4 OHMs impedence on ANY amplifier (technical discussion too long!) [NOTE: Your Pioneer unit has an internal overload protection system to prevent permanent damage. However, you cannot re-set these systems yourself. Your dealer or authorized HK service center must do this.] But, before you take it in for service, there is one more "test": check for shorted and/or mis-connected/disconnected speaker cables/wires. Visually inspect connections at the receiver and speakers first. You might find something obvious! If everything looks okay, then disconnect ALL of the speakers; and reconnect and test them one at a time (at relatively low volume.) For example, reconnect the left front speaker, test the system; THEN add the right front, test the system,and so on, ADDING one more speaker each time - FIRST MAKING SURE EACH OF THEM HAS AN IMPEDENCE OF AT LEAST 8 OHMS! IF there is a short (or bad speaker) this will help isolate it. Hopefully one of these "fixes" will work for you. GOOD LUCK!
Posted on Jul 18, 2007
Kenwood vr606 reciever shutting off subwoofer and centre speaker simultaneously after few minutes/seconds of powering on. WHat's the cause?
The receiver's out put sections are grouped in pairs. Front left and right in one output, rear left and right in second output, and center channel and sub output on the third. Sounds like a semiconductor or semiconductors have gone bad in the center & sub output.
Nov 19, 2015 | Kenwood VR-606 Receiver
I have the Tom Tom ONE (Build 2000) Tom Tom Palermo (if this Info Screen info is helpful). This Tom Tom HAS NO RESET PIN HOLE (Thanks a lot Tom Tom). I instaled included Tom Tom Home software, went to...
My thanks to the gentleman who posted the link to Tom Tom's solutions link. Although I had been there previously months ago when I first encountered this problem, there had been at that time, no instructions from them on how to properly reset the One that does not have a reset pin hole. That was in March. There are now such instructions.
The key to resetting such a Tom Tom GPS device lies in plugging your One into your computer, which automatically launches Tom Tom Home software (please remember, you have to have Home software installed on your computer already). After doing this:
1. When Home launches, go to Manage My Device Folder (p.2) and click it to open it.
2. You will see a folder-style window which lists all of the items that are your device. Select the folder tab: 'Items on device.' Then Deselect Applications. Click OK when promted. The Applications software will be deleted from your Tom Tom One.
3. IMPORTANT! Then clcik the other folder tab 'Items on computer.' Do the same here by deselcting to uninstal software on your computer as well. Click OK when promted.
4. If you do not get an automatic dialog box indicating that you need new application software installed, return to p.1 and select the folder 'Update My Device.' Follow the instructions as prompted and Tom Tom will both download new computer Home software as well as new software to the One device.
That should do it.
I will tell you that it took me three passes at this process. So it's not a breeze. But in the end it finally worked. And my One, which had been down since March is once again finally up and running with new software and as well as I remember it working.
Hope this helps others.
Tom
Sep 20, 2009 | Tomtom ONE GPS Receiver
The reciever just shuts down
The manual suggests disconnecting inputs and outputs and power, letting it sit for an hour, then plugging it back in and turning volume to max to see if it still shuts off. If it does, the problem is with the unit. If it doesn't, the problem is elsewhere.
Judging from some other sites, this is a common problem. If you take it to a dealer, suggest they check the AC input. Before anything else, make sure that there are no stray wires on your speakers connecting the positive and negative clips, which will cause a short and activate the amp protection.
I had the same problem with an Onky502 and replaced it today with an Onkyo606. It worked fine for an hour then started shutting off automatically. I'm following the manual and letting it cool off now for an hour, and meantime I'll check my speakers.
Dec 30, 2008 | Onkyo TX-DS777
Tom tom one version 2.2
Try this.
Run TTH without your unit connected.
Click on update my device (or any other process that you need TTH to perform).
You will then be prompted to connect and turn on the tomtom.
Connect and power up the device, if it asks you if you want to connect to computer, select yes (it does not always ask).
Feb 16, 2008 | Tomtom ONE GPS Receiver
The screen shows an error and says "Device not Present.Please verify."
DO YOU HAVE TOM TOM HOME INSTALLED ON YOUR COMPUTER??
LET ME KNOW
I HAVE A 910 ALSO I CAN HELP YOU
Dec 08, 2007 | Tomtom GO 910
Battery
need new batteries.
Jul 24, 2007 | Tomtom GO 300 GPS Receiver
Should I just Buy a new one?
You have a bad power supply or the audio output circuit has a short in it. You are correct by saying its probably betterv off getting a new unit. Most likly cost you more then a brand new shiny unit would . Good Luck PS Please do not forget to rate this thread
Dec 10, 2006 | Yamaha HTR-5740 Receiver
HP5550
my hp5550 when i plug it in some times it start's to boot then it will go to the setup screen telling me to tap crosshair to set it up then it shuts down. it will not charg up the battery. or it will not power up at all
Sep 08, 2005 | HP iPAQ H5550 Pocket PC
78 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
