My packard bell new 95 powers up for a second then shuts down but if you contiunly press the start button it runs perfect
    Problem Solver:
  • 15 Answers
It may be a problem with the power button.
Posted on Jan 14, 2013
4 Suggested Answers
knotbeerdan
  • 413 Answers
SOURCE: laptop doesn't work on battery after charging
If you are planning to open the notebook make sure the cpu cooler is mounted flush and has the most possible amount of contact with the cpu for heat transfer. I don't know about yours but normally in bios you can set a fatal temperature shutdown. Try to look up what cpu you have (when you open the case) and see if maybe the temperature is set too low. Then you would be able to reset the temperature to something higher if possible and this would solve the overheating shutdown problem.
Posted on Jan 02, 2009
  • 17 Answers
SOURCE: Packard bell easynote R1935 won't start at all
need more info
Posted on Jun 04, 2009
suxia
  • 142 Answers
SOURCE: Dead Packard Bell Easynote SJ51, won't power up
Try to reset CMOS sometimes BIOS saves incorrect parameter (especially when overclocking) It must have 3v clockstyle battery into motherboard. If you arent familiar to disassambling and then assambling laptops it will be better do this someone experienced. Take it off 10 minutes to reset CMOS and then return back. Take off ram clean its gilden pins vith dry clothes or naplin and put back.
Posted on Jul 29, 2009
How i unlock my keyboard. lts packard bell easynote TE11 BZ
Hello
Does the whole keyboard not work or only some keys?
Try the following shut down the computer , disconnect the power cable and remove the battery from underneath then press power button for about 20 seconds then reconnect the battery and the mains power and switch on the laptop again.
Did you spill any liquid on the keyboard?
Jan 23, 2015 | Packard Bell Computers & Internet
Press start button laptop just buzzes
Has it been dropped, or is there any kind of holes that something could have lodged into it? Otherwise it sounds like the battery needs to be replaced, as it is not getting enough power.
Your local Electronics store may be able to check your battery out for you, but I would suggest calling first to make sure there is no charge for the visit.
Why are you holding down the power button? That can ruin the button.
Does this help? Let us know.
Ponder/Meditate/Pray for Peace.
Mary Oliveau { hugs }
Jan 27, 2014 | Packard Bell Computers & Internet
Packard bell laptop wont power up.
You need to check your charger first. Use a voltmeter to make sure that the output matches the prescribed output.
Oct 01, 2013 | Packard Bell Computers & Internet
How to restart!/reboot a packard Bell laptop?
Hi bjrnariverse,
Hold in the Power button for 10 seconds, this will cold shutdown the laptop. Then simply start it up again by pressing the Power button.
Kind Regards :-)
JEDEMEYER1
* If you found this solution helpful, please rate it
Jul 21, 2011 | Computers & Internet
My packard bell imedia will not boot, when i press on button it goes red instead of blue and the shuts off after 2 seconds
i'd say your not passing the post test....if you hear a beep when you start your pc it should boot to windows screen if you dont hear beep you could have a loose cpu fan open up pc and make sure the fan is secure if not try tightening it can be tricky either that or it could be your power supply i wouldnt attempt fixing that if not sure what your doing..or try turning off your pc plug it out disconnect all periphals and press in the on button and hold for 2 minutes then try and boot
Aug 05, 2010 | Packard Bell iMedia 6826 (P481000502) PC...
Packard bell easy note tj65 will not power up
the short cable running from the power button to the main board has probably snapped where it passes over the RH hinge. remove the screen surround to gain access to the power on switch area and check. it would seem to be a common fault with the packard bell
Mar 07, 2010 | Acer Computers & Internet
Shuts itself down
helo,, you must change the power supply,, it has the problem
Mar 28, 2009 | Computers & Internet
Start up on my new laptop stopped half way through
hold the power button for aproximately 8 seconds so that it shuts down, reinsert the power cable and restart it .
Mar 16, 2009 | Packard Bell iMedia 6826 (P481000502) PC...
Laptop doesn't work on battery after charging
Jan 02, 2009 | Computers & Internet
Computers & Internet Logo
209 people viewed this question
David Payne
David Payne
