Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
Every year works for a while then gives symtoms of a bad t-stat
I have a coleman model DGAT056BDD furnace 1996 year it was installed in the past 12 years have replaced t-stat at least 6 times the one that i have now has lasted the longest im getting a flashing code 5 but i have lost my list of codes im getting the same symtoms as usual it ignintes pre heats and then the flame blows out if i reset it will work and heat up but when its time start back up it will attempt to work about to 3 to 5 times then cut and it flashes 5 times until reset again.
  • 1 more comment
  • grubirwin Jan 26, 2009
    i have a coleman model DGAT056BDD furnace 1996 year it was installed in the past 12 years have replaced t-stat at least 6 times the one that i have now has lasted the longest im getting a flashing code 5 but i have lost my list of codes im getting the same symtoms as usual it ignintes pre heats and then the flame blows out if i reset it will work and heat up but when its time start back up it will attempt to work about to 3 to 5 times then cut and it flashes 5 times until reset again.
  • grubirwin Jan 28, 2009
    i have a coleman model DGAT056BDD furnace 1996 year it was installed in the past 12 years have replaced t-stat at least 6 times the one that i have now has lasted the longest im getting a flashing code 5 but i have lost my list of codes im getting the same symtoms as usual it ignintes pre heats and then the flame blows out if i reset it will work and heat up but when its time start back up it will attempt to work about to 3 to 5 times then cut and it flashes 5 times until reset again. i found list of codes and 5 flashes says that the gas valve is energized with no call for heat.is there anything i can ck in the wiring
  • grubirwin Feb 06, 2009
    another expert posted a comment and gave me a website to go to that might help and now the comment is gone if the person could please post that website again thank you
  • 19,396 Answers
  • 744 Answers
Hello sir.... first try to turn power off to heater then watch operation. if it has a combustion blower motor it will come on, then after that next you should see the hot surface / or spark ignitor try to light pilot. Also on the door panel or controler you should be able to find out what it means when the light flashes three times.
thank u
Posted on Feb 08, 2009
  • 716 Answers
Replace The Thermostat With A Higher Quality One But Yeah Its Definitely The Thermostat. I Replaced Mine Twice In One Year So I Went To An Heating,Venting And Cooling Repair Center And Ordered The One Made Especially For My Unit From The Original Manufacturer. Its Been 3 years now and its still working every time.
Thanks For Using Fixya.com
Sincerely,
Michael Scott
Posted on Jan 28, 2009
    President:
  • 1,990 Answers
Welcome to Fixya! Have you Tried taking a Can of Compressed air and Lightly Blowing out the Igniter???? I have to do this every Year with my Heaters and they Work just Fine.
Posted on Jan 26, 2009
    Brigadier General:
  • 5,158 Answers
Flash Code:
No light = No power or open fuse
Steady green = Control has power
1 = Ignition failure
2 = Centrifugal switch shorted
3 = Centrifugal switch stuck open
4 = Limit switch cycling
5 = Gas valve energized with no call for heat
6 = Wrong polarity wired to furnace
these appearently are for that furnace
Posted on Jan 23, 2009
  • 4,472 Answers
Http://www.centraltrailer.com/furnace/cts_style_crest/style_pdf/dgat_bdd_parts.pdf
this link should help you, it sounds like the booster gasket. If you need further assistance let me know, also please take a moment to accept and rate my solution accordingly.
Thank you,
Lee
    President:
  • 2,976 Answers
Your thermocouple is not getting even heat and it's shutting the gas valve. Check for drafts in the furnace area.
    President:
  • 2,559 Answers
Just clean your flame sensor with a piece of steel wool
We are having an issue with our furnace. It reaches temperature, clicks off, clicks back on, clicks off. It happens intermittently. We can't tell if the problem in with the furnace or the thermostat.
An intermittent problem can take patience and time. Process of elimination too. If you are unfamiliar with servicing and repairing a gas furnace, you may want to leave that chore to a professional. Now, what exactly is coming back on after the set temp is reached? Blower only or is it firing the furnace also. My experience says it's just the blower. This is caused by... Furnace overheating, then shutting down, then bringing blower on to cool it down. Probably not your scenario. It's possible the control board is acting up. Highly possible that you have a high temp limit with a loose connection, or needs to be replaced. Schematic will call it HS or LS, something like that and it should have 2-6 of em. Possible that the G wire from the t-stat is shorting to R, and bringing the fan on. Try posting more info? Model & serial number. Fan cycling or furnace? Have you checked new t-stat installer configuration? Hope this helps! And work safe
Oct 31, 2017 | Heating & Cooling
Coleman furnace. Why no heat?
Oil or gas? What model t-stat? Any recent events like household power isues, t-stat replacement (or needs/replaced batteries), basement flood, home renovation? To state the obvious, it's either not receiving a call for heat (controls,wiring) or not sending (t-stat or wire).
Apr 09, 2016 | Heating & Cooling
How do I wire a Coleman Evcon 3500A916 furnace Model
Wiring Diagram for a Coleman Furnace - RV-Coach Online
www.rv-coach.com > Discussion Forum > RV - Insurance
... Furnace, Mark, 9-12-07. Need wiring diagram for coleman furnace Model # 7700B856 .... Amanda, 11-10-11. I need a wiring diagram for a Coleman evconpresidential model 7956c856 ... Need wireing diagram for coleman 3500a916 ... More results from www.rv-coach.com
FURNACE Diagram & Parts List for Model eb15b Coleman ...
Dec 22, 2015 | Coleman Heating & Cooling
We have a Coleman Electric Furnace Serial # AOL6042086, Model # AHP36C3XH21A and the fan runs constantly, will not shut off. We have replaced the thermostat and just replaced the control board. We h
I wish I was a furnace expert but I will give a push in the right direction. When a gas/electric fan runs it has two speeds. When you turn on the FAN ON switch it should run at the slower speed. If it doesn't turn on or turn off again when you turn it back you have a wiring problem or a thermostat problem. Make sure the thermostat is compatible with your unit and wired properly (on both ends). The other time the fan runs is "in session" when heat or cooling is applied to the system. It should run until the system finishes the cycle then a bit more (30 seconds or 1 minute) to blow the treated air completely through the ducts. If it doesn't stop then you may have a bad fan time delay or relay. Check parts for your model and various appliance repair site online.
Nov 25, 2014 | Coleman Mobile Modular Home Electric...
Coleman evcon furnace
Sounds like it isn't getting a call for heat. If you have a digital thermostat it could be the problem. I have seen them look like they are working but burn out. A simple way to check is take the stat off the wall. There is 2 wires. It's low voltage so don't worry about shock. Touch and hold them together. If it fires up change the t stat. On a . 2 wire it makes no difference which goes to W or R
Oct 16, 2013 | Heating & Cooling
Install automatic ignition system for a coleman furnace
For sure turn off the power at the breaker!! Now as far as the new board, usually the new board will be a new modified replacement, the wiring will be different from the original. It is very important to follow the installation instruction that come with the new board, if you go step by step, it will be ok. Just don't be surprised when you find that the new one is not exact. It is all in the name of improvement, follow the install manuals, step by step. As a 30 year Heating and cooling tech, it was very worrisome when they started doing this, but as long as you have a board that matches the brand and model of your furnace, it will be ok.
Good Luck,
Paul Gibson
Mar 31, 2010 | Coleman Heating & Cooling
My coleman furnace DGAA090BDTA pressure air
If its a High Eff. Furnace, does it have a two pipe or
single pipe system?
Jan 02, 2010 | Heating & Cooling
Burner flame going out on windy days on Coleman Evcon LP furnace
This sounds like a bad heat exchanger. It is possible that you do not see the crack because the crack is closed when the heat exchanger is cold (or room temp). Allow the furnace to heat up, this will allow the expansion of the crack. Turn the power off and examine the heat exchanger while it is still hot.
Mar 31, 2009 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
284 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
