Question about Euro-Pro Shark SC-505 Handheld Steam Vacuum
No steam coming out
I don't have a SC-505 but a SC-500.My unit was working fine until one day it fell on the floor. After that time, no steam was coming out of it. The water becomes hot, I can hear it. The light becomes green, the cap is hot but no steam is coming out of the nozzle when I depress the handle. One time when I unscrewed the cap, about 15 minutes after it was not working, a lot of steam came out. I don't know what to do. Can it be doctored or do I need to throw it away? Thanks for your help.
  • pmoorhead May 11, 2010
    i have a sc-505 steamer but can't get it to make steam. when i fill it and plug it in ,it heats but no steam comes out, i get a tiny drop of liquid but then nothing. i can remove the cap which is not hot and no steam comes out, but water is scalding. i have descaled with vinegar solution a couple of times, no luck. i have also replaced red seal in cap. now all it does is heat water and nothing comes out when i depress trigger. would be glad if someone could help.
  • 3 Answers
The fall might have damaged or moved the trigger so that it does not depress the valve on boiler.
Try removing the screws which hold the handle together. The cap needs to be removed to allow the handle to separate.
Once the handle is apart check the trigger piece looking for any broken parts.
Posted on Sep 16, 2008
Can I add vinegar to the water and steam clean laminate flooring?
Unless Shark says water only I don't think that would be a problem. All the vinegar will do is remove any grease on the floor and perhaps remove some bad odor. I rinse my hair with vinegar water every day after shampoo and conditioner. Only then do I consider my baby fine hair clean!
Jun 07, 2015 | Shark Steam Mop S3202 Floor Cleaner
Haan sI70 unit gets hot but no steam is generated, so not hot enough. Anything I can do?
It sounds like the internal temp thermostat is detecting that its hot enough when its not, and cutting the power as its supposed to, but too early. It may not be worth time/effort/money changing this part, in case its a problem with another part. Its a bit desperate but you could turn it off and half fill it with cold water then shake it vigorously to see if washing the internal surfaces impoves things.
Dec 15, 2013 | Haan SI70 Multi Sanitizing Floor Steam Mop...
Is there a trigger handle to turn off and on
no betty, stupid bit of kit imo, no operating switch, just on/off at the switch, which heats the water up. i measured 500ml of water heated using my kettle, put the top on, switched on, and waited. first time the steam didn't come out of the nozzle, so i removed the end and cleaned the nozzle with water, blew down the end from the big end, and replaced it, steam came out. big grumble though, the steam coming out is not that warm, don't advise you to, but i directed against my fingers, it's only hot at the exit of the pointing bit, used it to try and clean floor tiles and grout, complete waste of time. i wouldn't advise anyone to buy one.
Dec 11, 2011 | Tristar SB Steam Buggy Vacuum
I need the attachments
I have attachments for the SC 505 Euro-Pro Shark Portable Steam Cleaner. My cap broke off of the water tank and I can't find one to replace it so I'm trying to sell off the pieces. Email me at rbvasanj@yahoo.com and let me know which ones you want. This is what I have. We can work out a price.
1. Nylon Detail Brush (x2)
2. Angle Concentrator/Brush Adapter
3.Extension Tubes (x2)
4.Window Squeegee
5.Floor Brush
6. Filling Flask
7. Shoulder Strap
May 05, 2011 | Euro-Pro Shark SC-505 Handheld Steam...
Trigger not working correctly
You might need to de-scale the unit to free the stuck valve.
Keep the unit unplugged.
Fill the unit with a vingar and water (filtered or distilled is best).
Screw the cap back on and place the unit in a sink upside down to allow the vingar and water to reach the valve.
After a few minutes press down the trigger several time to work the solution into the valve.
Hope this helps.
Sep 15, 2008 | Euro-Pro Shark SC-505 Handheld Steam...
Where do I find replacement parts to my SC-505?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=83390&thid=752335
Posted by deh127 on Jul 07, 2008
My dog ate thought the hose coming right from the steamer. I need to get a new hose and I never got the attachment that cleans the floor where can I get that? I only got the hose and then attachments that would clean a grill.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The best place to get the added attachments for the Euro-Pro Shark SC-505 Handheld Steam Vacuum is to contact the Shark / Fantom factory manufacturer of which I will list below and this is a specialty vacuum and most local vacuum cleaner dealers do not have the parts but can order them for you if they are connected with Shark / Fantom. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.sharkvac.com/ Customer Tech Support 1-800-798-7398
These are the other brands that use the same tech support line
Shark / Euro-Pro / Infinity / Bravetti / and Fantom
Hours are Monday thru Saturday from 9:00 AM to 6:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 07, 2008 | Euro-Pro Shark SC-505 Handheld Steam...
Euro-pro shark steam cleanercs618hd
I am looking for an operator's manual for the Euro-Pro Schar SC-505 Handheld Steam Cleaner.
Any ideas?
May 26, 2008 | Euro-Pro Shark SC-505 Handheld Steam...
Steam will not eject
Same issue with my model. Heated up but would not produce... I called it SED (Scunci Erectile Disfunction) My doctor prescribed him some lube, and it worked! Now days Im happy to say we share a heathy steamy relationship!
Say goodbye to SED forever with the help from lube! All you have to do is open up the unit, locate the circular brass colored button, apply a squirt of lube (wd-40), create a decent amount of pressure and play with the little button until you notice smooth in-out motions. Put the unit back together and BAM you two will be back to a hot and steamy relationship, just like you had when you first met! ;)
Apr 19, 2008 | Scunci 52001 Handheld Steam Vacuum
Steam shark model sc 505 uk
THE FILL CAP ON MY SC505 IS JAMMED. CAN NOT REMOVE THE CAP. WHAT ARE MY OPTIONS.
Aug 14, 2007 | Euro-Pro Shark SC-505 Handheld Steam...
Euro-Pro Shark SC-505 Handheld Steam Vacuum Logo
388 people viewed this question
Top Euro-Pro Vacuums Experts
 Tony C
Tony C
Level 1 Expert
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
