Question about Frigidaire GLEF396 Electric Kitchen Range
Could this be a control switch problem or a short in the wireing ?
I have a Frigidaire Gallery Model # GLEF396ASA. When i turn on left front surface element control knob,left front surface element just gets warm after about 5 to 10 mins. it gets red then goes right back to warm then after 5 to 10 mins. gets red again. When i turn on Bridge surface element control knob,left front surface element and Bridge surface element gets red then goes right back to warm. Left back control knob and left back surface element work ok. Other side knobs and surface elements work ok. Thanks!
  • William Ferriell Jan 15, 2013
    Do you thank replacing left hole element will fix problem ?
Frigidaire oven warming light stays on when not using it
Hi waynepaige - Try resetting the unit by either unplugging it or flipping the household circuit breaker. Wait approximately ten minutes and turn on the oven. Is the warming light still on? An experienced service technician may need to further evaluate this issue if it was not resolved with the power reset. In this case, your unit may possibly be experiencing a communication problem with the EOC (Electronic Oven Control), faulty light switch, or a potential wiring failure.
Apr 12, 2013 | Frigidaire 30 in. Electric Gallery Series...
Could this be a User Interface,Board 316239500 part problem? or a Electronic Control Board part problem?
Normally, the E.O.C. (electronic oven control) only controls power the ehe bake/broil side for the oven. Doesn't control power to the element. If you have already replaced the infinite switch to that eye, the element itself could be faulty. There is a sensor inside the element that is supposed to communicate with the infinite switch to determine the proper cycling temp for what you selected.
Jan 31, 2013 | Frigidaire GLEF396 Electric Kitchen Range
Frigidaire Gallery washer motor runs only counterclockwise
Hello there and welcome to fixya
this is due to reverse polarity that is caused by the machines electrical cord has been installed backwards or the plug in on the wall is wired backwards
So what you are going to want to do is first remove the cover that the plug in on the machine and look at the wiring and it should be marked what color or wire goes where IF it is a 3 wire only switch the 2 outside wires meaning the one on the left will be switched with the wire on the right ok the middle wire is the ground wire and does not need to be switched,
IF it only has 2 wired simply swith the position of the 2 wires by putting the one that is on the left on the terminal on the right and the place the terminal on the right on the left ok
Hope this helps
Best regards
Mar 16, 2012 | Frigidaire Washing Machines
0ne of the surface units does not heat. Frigidaire Electric Range
HI, You will need to change the burner switch. When the element shorted, it took out the switch also. If you need help with part#, please let me know
May 17, 2009 | Kitchen Ranges
Gas Dryer blowing cool air and will not heat up.
Look inside door and get the model number for me. Could be igniter, gas solenoids or temp control switch inside. Let me know, Thanks Sea Breeze
Mar 19, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Washer will turn on but will not spin
ck door switch had one today tech sheet if needed is behind bottom panel left side wall in envelope if gives test procedure ..switch most likely but still could be control bd issue
Jul 31, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire GLEF396 Electric Kitchen Range Logo
47 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
