My yarvik Tab469 wont charge on the main or the laptop
My Tab wont charge by iether the mains or by plugging it into the laptop as it says u can do thing. When i press the poer button it comes up with acourstion sign on the battery
ArnWuLF
  • 55 Answers
SOURCE: DELL INSPIRON 6400 BATTERY CHARGE PROBLEM
The battery has 5 small dots in it. Those are there for no reason. Those are actually LED lights. There's a button you can press. If we number the lights 1-2-3-4-5 with 1 being closest to the button, check the lights when you press the button. If 1-3-5 are lit, that means that you have a dead battery and needs to be replaced. Other than that, you're battery might still be working but nearing the end of its life. Goto support.dell.com -> drivers and downloads -> enter your service tag or system type -> download Dell Quickset. Once Quickset is installed, it will diagnose your battery automatically and let you know if your battery already needs a replacement. It is just sad that batteries are covered with a separate 1-year warranty only. You can also go to www.dellbatteryprogram.com and check if your battery was part of the Dell Battery Recall Program.
Posted on Nov 25, 2008
SOURCE: Advent 7113 doesn't detect mains
It is highly posible that the jack in your laptop where you plug the main dapter is making a false contcat due to a problem in the welding of its connectors to the main board or to corrosion. Check if the rentral plug is not loose or if the plugs seems to be loose when you plug it.
If it is so, you need some expert technician to solve the problem by re weilding it or replacing it.
Posted on Jan 27, 2009
  • 21 Answers
SOURCE: laptop will not turn on, mains adaptor box green led light flashs
Sounds like the power jack is damaged or faulty.
Posted on Feb 06, 2009
  • 36 Answers
SOURCE: Laptop battery wont charge?
It could be the battery needs replacing ... it shows that the battery is charging but it doesn't keep the charge .....
Posted on May 23, 2009
SOURCE: my eee pc charger wont charge my laptop...
we had a similar problem the ac jack socket burnt out so we got a replacement part from ebay and my husband put it in and hey presto it works it cost 6 pounds for the part whereas a company to fix it wanted 100
Posted on Jul 19, 2009
Have got yarvik tablet which wont hold conection to skywifi anytips please
I bought 3 of these and found a different fault on all of them all sent back
keep off YARVIKS
Dec 30, 2012 | Tablets & eReaders
The battery on my c650 laptop has a charging problem
Your battery may not be securely in the laptop.
You may also need to purchase a new laptop battery.
I would go to ebay or amazon to find a decent priced laptop battery.
Aug 26, 2012 | Toshiba Computers & Internet
Advent t1600 wont start, it used to start with the mains plugged in was told it was the battery but wont even power up in mains mode now
First try using a different ac adapter/power cord.If after trying that it won't power up it only leaves the power board where the power button is located may be bad or the power jack where the ac adapter/power cord plugs into the laptop may be bad.Alot of the time when the ac adapter/power cord gets weak or stops working at all will cause it to not charge or not turn on even plugged in.
Oct 27, 2011 | Advent Netbook
It wont run of the mains, it will charge the battery and then run but once i start up it runs of the battery even if plugged in to mains
The power supply adapter needs to be checked to make sure it is putting out the full rated power under load.
Feb 14, 2011 | Acer TravelMate 2702WLMi Notebook
My hp pavillion dv 6000 does not want to turn on iether with battery or power cord
sounds like the mainboard is gone -- how did this occur ?
i'd like to help you --what si the S/N on the back of the unit ? i can get a mainboard cost for you
Nov 02, 2010 | HP Pavilion dv6000z Notebook
Acer 5920 works only on battery power not mains
hi there
i read your report. OK 1. check plug in connection on the computer to c if its lose. If it's not lose simply try a new power cord. thank you for writing to fix ya.
Best Regards Richard
Nov 30, 2009 | Washing Machines
Laptop wont charge at all, or turn on
hey friend . .
this indicates that your battery is finished just go and buy new or
the battery need a repair . . . its charged is over . .
Oct 06, 2009 | Computers & Internet
Laptop Wont boot up even plugged into mains!
If it was on a rug you might have experienced a static electrical shock to the system.
May 06, 2009 | Computers & Internet
Labtop wont start up
Hi I am a laptop technician, and it sounds like you have a power problem.
Try removing the main battery and starting the laptop on the mains cable only. If the laptop starts fine then you probably have a problem with either the battery or the power board in the laptop.
If the laptop doesn't start when doing this, remove the mains power lead from the laptop and put the main battery back on the laptop. Try starting the laptop off the main battery only and if the laptop starts normally then you most likely have a broken/loose socket that the power lead plugs into in the back of the laptop (a very common problem) or the power board in the laptop is faulty. If the laptop doesn't start or goes off very shortly after pressing the power button it could just be that the battery is flat as a broken power socket on the laptop often stops the main battery from charging.
I hope this helps.
Jan 03, 2009 | Acer Aspire 5315 Notebook
Battery wont work
The battery is dead and it won't charge or hold its charge (all rechargeable batteries have a finite number of charge and discharge cycles). You need to buy a new battery, or just use the laptop connected to the mains supply.
Oct 29, 2008 | HP Compaq Evo Notebook N600c
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
