Question about Blenders
Kenmore blender 3042527
My 3042527 blender will not turn on... light comes on and it makes a "click' noise but it wont run. i put it away clean and working...took it out and it wont turn on???????
2 Suggested Answers
SOURCE: Kitchenaid Blender Classic
Same thing happened to me. Opened it up and along the red wire to the motor is a bass fuse. Went to the hardware store and then I replaced it. Works fine.
Posted on May 14, 2009
Tip
The best way to clean your blender
I used to hate using my blender. I could make great smoothies or hearty soups but after I was done, I hated to clean it. The blender would be covered in small seeds or other small pieces of food that were stuck on. Plus, I'd be terrified of the cutting myself on the sharp blade (even when the blender was unplugged.)
So here is what you do:
1. Boil enough water to fill the blender.
2. Put a few drops of soap in the blender and plug it in.
3. Pour the boiling water over the soap in the blender, cover it and turn on.
You can let the blender run for two minutes, until it is clean or until all the little pieces are removed from the sides.
4. Rinse out with water and repeat if necessary.
And there you have it, using a blender just became a little easier.. since the cleanup is no longer a hassle.
on Dec 26, 2013 | Blenders
Kitchenaid blender motor loud hum not working
Can you check it without the beaker on? It could be the blade seizing up, how free does it turn by hand?
Dec 02, 2012 | KitchenAid KSB560 5 Speed Blender
Ninja blender blade wont turn with food in container.
make sure blade is pressed tightly onto shaft... should click into indent. if not then you need a new blade piece.- stripped
Aug 18, 2012 | Blenders
Kitchenaid ksb465 electrical noise.
Arcing at the brushes is normal although if worn down enough, they can skip since their travel is limited to avoid damaging the copper commutator.Look at the brush guides closely; the simple spring that supplies a little tension to the brushes will 'bottom out' on a slot in the guide once the brushes get too short.
The skipping might be due to the type of speed regulator that is used; an older type was mechanical and didn't regulate well at low speeds.
Dec 30, 2011 | KitchenAid KSB465ER 4Speed Blender
How do i get the bottom off the blender jar?
The best way that I've found to remove the bottom from the blender jar is to put the blender jar back on the blender base (make sure it locks in place) and then turn the jar to the right. You'll feel the jar detaching from the base. Once it's loosened up, remove from the base and finish turning the bottom, manually. Before I found this method, I had tried everything to get the plastic bottom detached from the jar. Without removing the bottom, there's no way to clean it properly and rather than be unsafe I'd need to throw the whole works in the trash. But the method I've described above works every time!
Aug 13, 2011 | Jenn-Air JBL800 Work Top Blender
GE single serve blender 898679--need replacement plastic gasket for grinding jar. I am told by Walmart, where I purchased it, that I need to return it. I don't want to return it. The blade chewed up the...
I had the same issue. i took the gasket from the other blade to use with the blade i use everyday. one trick is, don't remove that gasket to clean it but make sure it stays in there. Just soak it and scrub it good, to make sure it stays seated in there.
If the gasket comes loose while you are grinding, the lid will come loose in the base and sometimes causes you to not be able to get the jar from the base. you have to turn the jar the opposite direction to get the lid to tighten up, then you can remove the jar from the base.
I am trying to get replacement jars since those plastic nobbies that run the blender have broken off. It is down to one of 3 nobbies, so it can't be run anymore. I mght just have to buy a brand new blender but it seems so wasteful.
Mar 15, 2011 | GE Blenders
My blender base has become discoloured with a sort of green mouldy streaks, how do i clean
If you remove the blinder base where the blades are you can put it all in the dishwasher. To do this grab the handle on the pitcher then unscrew the plastic base from the glass. make sure that you look how it comes apart first. then put in the dishwasher to clean. Then reassemble the way you took apart.
Jan 11, 2011 | Oster 12-Speed Brushed Nickel Blender...
Cuisinart BFP-703CH Chrome Blender does not start
I had the exact same problem with my Cuisinart bfp-703ch blender. When I plug it in, the lights come on but the motor wouldn't run. After reading some posts I almost decided to throw it away. But my brain started to itch and I gave it a shot anyway. I eventually found the problem to be with the Thermal fuse. If you overload/overheat the blender, this fuse is going to blow off.
To replace it, I opened the bottom panel and followed the wires that come from the circuit. Once of those wires eventually will lead to the thermal fuse. It may help you if you unscrew the circuit board. Then I detached the fuse with pliers, got a replacement thermal fuse from Radioshack and connected it back on. I also had to solder it to make sure the connection is more robust. And Voila!!! my motor started working again.
Apr 15, 2009 | Cuisinart BFP-703CH Chrome Blender
Apr 12, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Blenders Logo
87 people viewed this question
Top Blenders Experts
eyecam
Are you a Blender Expert? Answer questions, earn points and help others
