Question about MSI MS-U135DX-1679ZA Netbook
My msi laptop is hangs when if i open it.. i cant. use any key even the enter key to open the windows
  • MSI Master
  • 27,725 Answers
Laptop Hanging Problems Laptop hang issues can be a frustrating issue for the user and a tedious problem for a technician. The variety of causes for this event are staggering, but many can be diagnosed in a few simple steps. Peripheral Issues USB drives, inserted before boot, will cause a hang. Remove all such devices and media (such as CDs and floppy disks) before booting your laptop. b> Software Causes Press "F8" at boot and press "Last Known Good Configuration" to take your laptop to a previous working boot. Starting your laptop in "Safe Mode" by pressing "F8" at boot will help you check for software causes for a hanging laptop. By turning off unnecessary processes, this mode allows you to run anti-spyware and antivirus software to clear malware that hinders performance. Perform a check disk by right-clicking on your "C Drive" found in "My Computer." At the "Properties" link, press the "Tools" tab to schedule error checking. Reboot your laptop and let it perform this check. Hardware Causes Verify that your RAM is seated correctly by removing it carefully from under its access door on the bottom of your laptop and reinserting it. Do not touch its gold contact points, as this may damage the memory. Download the hard drive manufacturer's diagnostic software to test the integrity of the hard disk. If you have access, run a professional hardware diagnostic suite to check the motherboard and CPU. Boot with the battery removed to verify that there is not an issue with power conflicts. b> Final Considerations Checking the "Event Viewer from Administrative Tools" located in "Control Panel" (XP only) can also shed light on potential causes. Performing a repair installation of Windows can address missing files, registry errors and corrupted system files without damaging your data. This process requires your original Windows disks but is often quite useful. Press windows button and in the search type msconfig go to startup tab and uncheck those you dont want to start. scroll to the bottom toolbar bottom of screen right click you can select task manager applications also processes you will see whats running on your computer and ticking over you might have a virus http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html microsoft security essentials your operating system must be registered Win7/Vista/XP 64 bit http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7 if you see something running that you does not need to be running select end now then you might you might uninstall that particular program and some unnecessary programs you should also check leads from motherboard to hard drive for secure dust free connections click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start tick in both boxes this will schedule to on restart do not have any input while chkdsk utility is in progress any might damage your computer also you might download and use this registry cleaner it is totally free to use http://download.cnet.com/ccleaner/ then defragment your hard drive adding more ram is the best way of speeding up a computer If youre not sure if a module is right for your system use the Crucial Memory Advisor tool for a list of guaranteed compatible modules
you should always ask for a guarantee on compatibility before purchasing any ram and buy working pairs if possible you might have to many programs running at the same time putting to much strain on the CPU central processing unit
try uninstalling a few unnecessary programs This tool deletes unnecessary or temporary files on your hard disk so you can increase the amount of storage space you have. Delete the files using Disk Cleanup If you want to reduce the number of unnecessary files on your hard disk to free up disk space and help your computer run faster, use Disk Cleanup. It removes temporary files, empties the Recycle Bin, and removes a variety of system files and other items that you no longer need. Open Disk Cleanup by clicking start all programs accessories system tools and then clicking Disk Cleanup. In the Disk Cleanup Options dialog box, choose whether you want to clean up your own files only or all of the files on the computer. If you are prompted for an administrator password or confirmation, type the password or provide confirmation. If the Disk Cleanup Drive Selection dialog box appears, select the hard disk drive that you want to clean up, and then click OK. Click the Disk Cleanup tab, and then select the check boxes for the files you want to delete. When you finish selecting the files you want to delete, click OK, and then click Delete files to confirm the operation. Disk Cleanup proceeds to remove all unnecessary files from your computer. This tool deletes unnecessary or temporary files on your hard disk so you can increase the amount of storage space you have. Delete the files using Disk Cleanup If you want to reduce the number of unnecessary files on your hard disk to free up disk space and help your computer run faster, use Disk Cleanup. It removes temporary files, empties the Recycle Bin, and removes a variety of system files and other items that you no longer need. Watch the demo (1:00) this should speed up your computer Hope this helps.
Posted on Jan 14, 2013
Msi u180 unknown password
try removing the cmos battery on the laptop motherbord which will reset the laptop to factory defaults , if it is windows password u can format and reinstall windows .
Mar 15, 2014 | Computers & Internet
Msi mini laptop
your master boot record MBR is damaged and your harddisk looks missing or blank to boot up. run cd and go to command prompt.
In black window were :>chkdsk c: /f then press enter. type as shown from prompt with space between k c and : /...
Aug 18, 2013 | MSI Wind Computers & Internet
My Acer Aspire 5732Z laptop hangs up on the Acer logo starup screen every thing stopped even cant enter the the bios hitting f2 or many other i tried
Remove ALL media, DVD, CD, USB. Unplug, remove battery, plug in, reboot. Try a system restore/recovery. At boot tap ALT+F-10 repeatedly.
Jan 25, 2013 | Acer Aspire Computers & Internet
Why my msi always hang
please explain when does it hang? when installing a software?
if so,you need to download this patch
For XP
http://www.microsoft.com/en-us/download/details.aspx?id=2653
For Vista
http://support.microsoft.com/kb/981669
or you can just do a windows update
Aug 26, 2012 | MSI Computers & Internet
Why my msi netbook always hang
For XP
For Vista
I cant open my dell inspiron N4010. always hangs p when opening... how to restore it.. even pressing the boot options and enter set up still keep on hanging.. what to do please..??thnx
this is software problem i.e windows try to reinstall your windows and format all the partition this is usually occours by viruses . it takes hours at startup and at launching any app.
for backup your files reboot your computer and press f8 key and run computer in safe mode copy all the important files on your flash drive
Aug 11, 2012 | Dell Inspiron N4010 Notebook
Wifi crashes my Windows 7
TRY TO UPDATE YOUR BIOS http://www.msi.com/service/bios-note/
Dec 30, 2011 | Computers & Internet
I cant access internet exp. from my laptop even with good signal
Access the preferred network settings (if you are using the Windows wireless setup - right click on the wireless icon + view available wireless networks + preferred networks) for your machine and edit the listing for your wireless network, you'll need to uncheck the box that says something to the effect of "an authentication key is provided for me" and enter your security key in the boxes provided.
If it still fails - you may want to remove your network from the preferred listing and add it manually, making sure that the authentication is turned off as described and with your security key entered twice.
Feb 23, 2009 | IBM ThinkPad R50e Notebook
MSI MS-7142 motherboard problem
try cleaning CMOS with cmos jumpers or just remove your battery of motherboard for 10 seconds (previously unplug power from PC.)
Jan 31, 2008 | MSI K8MM-V Motherboard
MSI MS-U135DX-1679ZA Netbook Logo
51 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
