Medion PC MT 6 ATX SW & Power Led Green cables
I do have an Medion PC MT 6 which does not boot. The two sets of wires are not connected ATX SW Green & Black Power Led Green & White On the motherboard is 8 pins connector, but I don't know where to connect each of "ATX SW" and "Power Led" labeled cables.
  • 34 Answers
SOURCE: Problem with power connections on emachine T2596
Take a peek at this link,
http://www.duxcw.com/faq/mb/frontpanel.htm
it may assist you in your problem
Posted on Dec 17, 2008
  • 357 Answers
SOURCE: ATX-SW Motherboard?
The manufacturer website should have what you need.
You also might need to know what chipset is on the board as well.
If it is the AMD board, go to www.amd.com
I hope this helps.
Good Luck.
Posted on Feb 26, 2009
  • 357 Answers
SOURCE: a GeForce7050M-M (V2.0)computer motherboard front
You may have the pins reversed.
Good Luck.
the logos1
  • 8 Answers
SOURCE: I have a hp compaq dc 7100, the power supply is
i prety sure there is no way to do that. you might be better off just going to fries or radio shack or some other electronics store and buying a new one, there is no way to change a 20 pin to a 24 pin srry the best pf luck to you. plus i trying to fix my own problem right now
Posted on Apr 01, 2009
  • 255 Answers
SOURCE: Power Button wire to mother board power led power
There are may motherboards, but most have writing on them as to what is suppose to plug where. For example, for the power switch, the lettering might be "Pwr" or "Power" or "Pwr sw". The pins are usually together and should fit the plug on the end of the wire.
Posted on Nov 25, 2009
How to connect on/off switch to motherboard
depending on what motherboard you have the pins of the power will be a around 4 pairs and 1 pin missing. im just going by memory i may no be correct but im on the correct path. okay on your mother board you will have pins open on that hub there shuld be small white letters written onto it it should be abbrebiated. PWR or simply power
connect the pins on the corresponding ones and you should be good to go
Sep 20, 2014 | Medion Computers & Internet
Medion PC MT 5 type MEDMT79
Fuse in the plug?
Sounds like a good design...........
[Since I do not know, is this an indication that the power cord's plug, on the surge protector side; has a fuse in it? ]
So what is the method to check a fuse?
Is it the preferred method to eyeball it?
No
A multimeter set to OHM's, should be used to check it. (1K)
"It looks like the fuse element is going across okay"
Not always true. May be present, but not actually be touching one of the ends, and fool you.
Going with the premise that you KNOW;
A) The fuse to be good
B) The power cord TO Power Supply is good.
C) THE receptacle in the surge protector, that you have the power cord plugged into; is good.
Reasoning on the last statement?
I have had Many surge protectors, where just THAT receptacle was bad.
"Hmmm, power LED light is on, so surge protector is on,
router has power, monitor has power, and so does the printer.
Let me plug a table lamp into THAT receptacle, the computer is plugged into........"
Nope! NADA!
Power is KNOWN to be getting TO Power Supply?
Okay. Suggest a simple test now.
This test determines if the problem is the Power Supply; Or the Power On switch.......
The test is to use a jumper wire, on the ATX main power cable's connector.
Do Not know which one the Medion has.
It is either a 20-pin ATX main power cable, or a 24-pin ATX main power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
[NOTE* Color of connectors does NOT matter ]
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
Whichever one your Power Supply has, look for the GREEN wire.
The Green wire is the Soft Power On wire. (Abbreviated as PS_ON)
The Green wire is Temporarily jumped to ANY Black wire.
ALL Black wires are Ground wires.
The preferred jumper wire is a straightened out paperclip, bent into a U-shape.
Turn the U-shape over.
The top of the U is wrapped a few times with black plastic electrical tape. (Color doesn't matter. It's just that Black is more common)
This taped area is for your fingers, and thumb to hold onto.
The 'Legs' coming down, are what is used.
Power Supply plugged into power, and 20 or 24-pin ATX main power cable; plugged into motherboard.
The BACK of the ATX main power cable's connector, is where the wires go in.
It is the Back of the ATX main power cable's connector, where the U-shaped jumper wire is to be used.
One leg slides down into a socket hole, that has the Green wire in it.
Slides RIGHT NEXT TO the green insulation of the wire, and down into the socket hole.
MUST slide down into the socket hole far enough, that the U-shaped jumper wire touches a female metal terminal; that is on the end of the Green wire.
This is an example of what the female metal terminal connector, looks like,
http://www.mcmelectronics.com/product/28-9420&utm_medium=Affiliate&ref=cj&utm_campaign=CommissionJunction&utm_source=CommissionJunction?utm_expid=8634549-14
Looking back at the Playtool link, look at the middle photo.
There you see the ATX main power cable, unplugged from the motherboard, and you see a FRONT view of the connector.
Here you can make out the open end, of the metal terminal connectors mentioned above.
The jumper wire must touch the Back of this connector.
(Jumper wire has to go Approximately 3/8ths of an inch, down into the socket hole.
.375 inches)
Moving on........
The other leg of the U-shaped jumper wire, goes down into ANY socket hole with a Black wire in it.
ALL Black wires are Ground wires. (Negative)
[This is a DC circuit. There is a Positive, and a Negative.
ALL power wires are Positive wires. ALL Black wires are negative wires. { Ground ]
The Soft Power On circuit uses 5 Volts DC.
In comparison two D cell flashlight batteries produce 3 Volts DC.
NOT stating there may be a small spark!
It's just the way electricity works.
For this reason you may wish to wear a glove, on the jumper wire hand.
The contact period made is no more than 2 seconds.
The Power On switch is a Momentary Contact Switch.
IF, the Power Supply turns on you have a bad Power On switch.
IF, the Power Supply does NOT turn on, you have a bad Power Supply.
The Power Supply in your computer is a Converter.
It converts HIGH AC voltage down to 3 LOW DC voltages;
3.3 Volts DC
5 Volts DC
12 Volts DC
EACH one is a Voltage Power Rail.
Orange wires are 3.3 Volt wires
Red wires are 5 Volts
Yellow wires are 12 Volts
(ALL Black wires are Ground/Negative wires)
EVERY wire that is Orange, is a 3.3 Volt (DC) wire.
ALL Orange wires go back TO the Power Supply.
They all connect TO the 3.3 Volt power rail, in the Power Supply.
EVERY wire that is Red, is a 5 Volt wire.
ALL Red wires connect to the 5 Volt power rail, in the Power Supply.
The same can be said for All Yellow wires.
ALL Yellow wires are 12 Volt wires.
ALL Yellow 12 Volt wires connect to the 12 Volt power rail, in the Power Supply.
IF, just one voltage power rail is weak, the computer will NOT work.
A) If ALL of the LED's were on at once, they would use less than 1 Watt of power.
B) EACH fan uses 2 to 3 Watts of power.
C) A typical Processor (CPU) can use 51 to 130 Watts of power.
Just depends on what CPU (Processor) it is.
[LED = Light Emitting Diode. It is redundant to refer to it as an LED light. That is saying it is a Light Emitting Diode light ]
That is why you may see LED's light, and maybe fans spin, but no computer working.
NOT enough power to turn the Processor (CPU) on...........
[Just in case you get this far, and this happens]
http://www.directron.com/atxswitch.html
The above ATX power on switch, is used in a LOT of desktop computers.
The Power On button is an assembly. it has the Power On switch, inside it.
For additional questions please post in a Comment.
Or click on Reply at end of solution.
Regards,
joecoolvette
May 11, 2013 | Computers & Internet
HOW TO CONNECT POWER LED HDD LED RESET SW POWER SW IN BIOSTAR AMD N68S+ MOTHERBOARD
You can find the manual here: http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=498#dl The board is usually marked, also, although it is very tough to read the small print.
Oct 31, 2012 | Biostar N68S3+ AM3 NVIDIA MCP68S Micro ATX...
CASE WIRES TO PANEL1 CONNECTIONS
The hdd red wire gooes to pin #1 the hdd white wire goes to pin #3 the power sw orange wire goes to pin #6 the power sw white wire goes to pin #8 The reset sw blue wire goes to pin #7 the reset sw white wire goes to pin #5 the power led green wire goes to pin #2 the power led white wire goes to pin #4.
Now the layout of the pins is the long row (5) pins are the odd number pins 9 being the odd one and 1 is the other end of the row. 2 through 8 start at the pin accross from 1 : : : : . I hope this helps you.
Aug 22, 2009 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
Dell dimension 2400 blinking amber light
1. Remove All External Devices
2. Check the Computer's Power LED
3. If the power LED has not changed unplug the Power Cable From the Computer Disconnect All Hard Drive Power and Data Cables and power on the computer. If still no go.
4. Remove All PCI, PCI-E, and AGP Expansion Cards .
5. Remove All Memory From the Computer
6. Reseat the ATX and 12-Volt Connections . The ATX connector will be a 4 pin square connector connecting to the motherboard from the power supply and the 12-Volt Connection would be the biggest connector with a lot of colored wires.
7. If still no go.
8. Disconnect the Power Connection to the Chassis Fan
9. If the light still flashes then it could be a power supply or motherboard failure. Try a good know power supply first and if that does not fix the problem it is the motherboard. Also check the back of the tower for 4 lights lables ABCD or 1234.
Rate if useful.
Aug 11, 2009 | Dell Dimension 2400 PC Desktop
Need picture of mother board for Emachine C2825
I've built a PC myself, each connector had text on it to say what it was and one arrow on it in relief, don't know wether that indicated plus or minus anymore.
Anyway, I recommend you just plug them in, and try to boot the PC. If it doesn't boot, switch the Power SW connector around, then it should boot. Do the same with the LED connectors, and it should work just fine!
Good luck,
Yannick.
Jul 13, 2009 | Intel D845GVSR Motherboard
TRYING TO HOOK UP MU POWER BUTTON NEED TO KNOW
Hi there
The front panel connectors are mainly,
  • harddisk activity connector
  • power switch connector
  • reset switch connector
  • power LED connector
  • speakers connector
  • USB connector
Harddisk activity connector
This normally comes red in colour and is labeled as HDD-LED
Power switch connector
This comes green in colour and is labeled as POWER-SW
Reset switch connector
This usually comes grey in colour and is labeled as RST-SW
Power LED connector
This is usually green in colour and is labled as PWR-LED
Speakers connector
This speaker will give different beep sounds during boot to tell the user if there is any errors. It occupies 4 pins, however only 2 is important for the function. Be sure to connect the red coloured cable to the positive polarity and the black to the negative.
front_panel_connectors.jpg Front panel connectors pins on the motherboard
front_panel.jpg Front panel connectors from the casing
Good luck and thanks for using FixYa!!
May 13, 2009 | eMachines T6420 PC Desktop
Atx power swtich replacement
Either way will work! No worries, it is just a switch. Just think about it. A jumper wire would work as well, right?
Oct 20, 2008 | ASUS Terminator PC Desktop
Computers & Internet Logo
189 people viewed this question
David Payne
David Payne
