Question about Kenmore 83142 Electric Dryer
No power??? Yesterday no power in the dryer. The breaker is fine and yes, the dryer is plugged in. Today, the light was on in the dryer, loaded laundry into the dryer, then nothing. No power, no light. Possibly a short somewhere, or a fuse in the dryer. Any suggestions? Thanks!
  • sondra Theurer Mar 21, 2009
    OK I have light,but when I turn knob it just buzzes and wont start up any ideas?
    OK I have light but when I turn knob all I get is buzzing and drum won't start turning. It's not froze up (I can rotate in manually)any ideas?
    Novelist:
  • 159 Answers
Try the thermal fuse. Its a white part with 2 wires on top and it is on the blower housing. Some are oval shapped and some are a narrow rectangle. Unplug the dryer and remove one wire and check for continuity with a ohm meter. On electric dryers if this part is blown the dryer will not run. On gas modeld it will run but no heat.
Posted on Jul 12, 2007
SOURCE:
Dryer will not start
It is possible the cord/pigtail connections were not tightened enough and have burnt off.
May 01, 2014 | Dryers
Dryer wont start
Did you flip the breaker to the dryer and flip it back on
That has worked for me
Apr 04, 2014 | Dryers
Maytag MED5700TQ Electric Dryer lost all power
Hopefully you still have your manual-if not dwn load this one and go to page 23
Download 20W10150608A.pdf initiated. If download did not start, click here to try again.
Dec 29, 2012 | Maytag MED5700TQ Electric Dryer
Maytag 3000 Series front load gas dryer (Whirlpool) - No lights, no digital display, not able to turn on or start. Yes, unit is plugged in to AC outlet. Yes, AC voltage is good at 120V. Yes, circuit...
OK everyone, my ears are red. Over the weekend, I gave this another shot, since my warranty repair appointment isn't until next week.
I opened the dryer door (the drum light is off, indicating no power at all) and went to the circuit breaker box, and flipped the washer/dryer breaker back to off and then re-set the breaker again.
When I got to the laundry room - the drum light was on!
So I powered up the unit, and ran the machine. It ran for about one minute, and then went off. So I went back and re-set the breaker again.
Visually, the breakers did NOT LOOK tripped - but flipping the thing off and then on to re-set the breaker worked.
This time, the dryer is working fine. The bad part is: I need to replace the breaker for the second time. So this is NOT a defective dryer, it is a bad electrical supply. I will call the electrician back to make him fix this right. . . . .
Thanks again for all who responded. This is a new unit, purchased on 7/7/2009.
Sep 12, 2009 | Maytag Dryers
LER4634E WHIRLPOOL FRONTLOAD ELECTRIC DRYER WORKED GREAT
If you have a access to an AC voltmeter, measure the two slanted connections in the wall socket for ~220 volts. If near zero, measure at the load side of the dual breakers for the same voltage. If still at or near zero, one of the breakers has gone south. Replace the pair of breakers.
If you measured 220 volts as above, then the problem is within the dryer--probably a burned out heating element or open thermal fuse. Major tear-down to find and fix as the heating element is behind the drum.
Jul 17, 2009 | Whirlpool LER4634J Electric Dryer
Kenmore Dryer 62802 Doesn't Heat
sounds like the heating element has gone south
if you open up the dryer you can check continuity across the element but make sure power is unplugged
Apr 13, 2009 | Kenmore 62802 Electric Dryer
Kenmore Elite HE3 front load dryer no power
Yes. Remove the kickplate and check the continuity of the thermal fuse located on the blower housing.
Feb 23, 2009 | Kenmore Dryers
NO POWER TO DRYER???
Hi there, you are experiencing a power supply board failure. this board may have used all its life up and unfortunately, it will have to be rebuilt or replaced.
Feb 05, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Kenmore 83142 Electric Dryer Logo
75 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
