Question about Freud FT2000E 3 Router
Removing bearing shaft nut on freud router
How to remove shaft bearing nut
2 Suggested Answers
  • 142 Answers
SOURCE: Collet on Freud router won't release bit
a new collet won't hurt, but you may try sanding down the inside of your existing collet with 120 - 180 grit sandpaper. also, buff down the router bits
any condensation or moisture that may have gotten on these items can cause almost invisible oxidation that you can remove easily by sanding. DO NOT USE WD40!!!
Posted on Dec 05, 2009
Testimonial: "Tks! Will try sandpaper inside collet. Not sure buffing bits will help, since likelihood of ALL of them having a surface problem is pretty low."
How do I replace the bearings on the mower deck spindle housing on my toro mx 5060
To replace spindle bearings: Remove deck and either rest on two saw horses or similar mounts, or stand on its side and fix to make safe and secure. Photograph the belt layout and also the grease nipple so you can easily refit.The object is to access the top and bottom of the spindle. Remove cutting blade. Remove pulley on top side. I reccomend that you also remove the spindle housing from the deck. You can remove bearings while still fitted but it is not so easy. Clean the shaft and remove any circlips or retaining nuts from spindle. Take the unit and clean shaft as clean as new. Use emery paper if necessary. Use light oil or CRC to lube the shaft to slide bearings off. Do not hold shaft in vise as this will cause deformation of the shaft surface and jam the bearing. Place lower side of housing on vise which should be open slightly more than bearing outer diameter. Take hardwood or industrial nylon [to protect the thread from bruising,] after refitting nut on shaft thread, and ensuring there is space between nut and bearing, tap down firmly with hammer. The shaft will move more easily after the initial freeing up. When it moves easily remove nut and tap down with wood between hammer and thread end. To remove the top bearing use a wooden shaft, a broom handle is ideal. The replacement bearings should have no seals on the inside. Remove if necessary. Make sure to scrub clean both housing end and deck where the housing fits. Any rubbish there will cause lines in the mowing as it can tilt the blades. The thickness of paper can mean 3mm at the end of the blades!
Sep 26, 2014 | Garden
Removal steering
LOOSEN the the bolts that clamp the fork legs to the tree. Remove the fork legs along with the front wheel by pulling down on them. Be careful that the brake hoses and the speedometer aren't damaged. Remove the center nut. Bend the lock washer tang so that the bearing retainer nut can be removed and remove the nut and washer from the center shaft. the tree should slide out from the bottom. Don't remove the bearings from the center shaft unless you are going to replace them. When re-installing the center shaft, tighten the bearing retainer nut just enough so the shaft doesn't shake but not so tight that there is a bind when turning the tree. this can be re-adjusted after all assembly is complete.
Good Luck
Apr 18, 2014 | 1997 Honda VT 750 C2 Shadow
I have a Freud 2000E plunge router. It is about 10 years old, but I've never changed the router bit I have in it before. Now I want to remove the bit I have in, but cannot turn the bolt to remove it....
Hello Davis gr,My name is larry I am an auth Freud service tech.
The first thing to do before you attempt any repairs is of course to unplug.In the full plunged position make sure the router is locked in position out of the table on its side.You twist to loosen the bit nut
and tap gently on the side of the bit with a rubber hammer
turning it slowly and it will come loose to remove.
second--If the router will not spring up to its top position it is because
the posts that are spring loaded are dry.again you must remove the router from the table clean the postd with a dry cloth and while still locked lubricate with lite oil using a clean cloth the metel posts.
after that with the same rubber hammer tap the base plate and it will come loose
I hope this is some help
Larry in Canada larry_boccioletti@yahoo.ca
Sep 11, 2011 | Freud FT3000VCE Router
1998 ford explorer 2 wheel drive rear wheel bearing replacement
what about it?
conventional axle or limited slip? Get axle code off door sticker.
SECTION 205-02: Rear Drive Axle/Differential - Ford 8.8-Inch Ring Gear 1998 Explorer/Mountaineer Workshop Manual
IN-VEHICLE REPAIR Rear Wheel Bearing and Axle Shaft Oil Seal -4.0L SOHC and 4.0L EI, Conventional
Special Tool(s) swn~us~en~file=st1514a.gif~gen~ref.gif Axle Seal Replacer
T83T-1175-A swn~us~en~file=st1283a.gif~gen~ref.gif Axle Wheel Bearing Puller
T83T-1225-A swn~us~en~file=st1322a.gif~gen~ref.gif Axle Wheel Bearing Replacer
T83T-1225-B swn~us~en~file=st1326a.gif~gen~ref.gif Driver Handle
T80T-4000-W swn~us~en~file=st1185a.gif~gen~ref.gif Impact Slide Hammer
T50T-100-A
Removal
  1. Remove the axle shaft; refer to Axle Shaft in this section.
Axle Shaft Removal
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not use heat to loosen a seized lug nut. Heat can damage the wheel (1007) and the rear wheel bearings (1225).
    Loosen the lug nuts (1012).
    1. Remove the center cap.
    1. With the weight of the vehicle on the wheels, loosen the lug nuts.
  1. Raise and support the vehicle.
  1. Remove the wheel and tire assembly.
    1. Remove the lug nuts.
  1. Remove the axle housing cover (4033).
    1. Loosen the axle housing cover bolts (4346) and drain the rear axle (4001).
    1. Remove the axle housing cover bolts.
    1. Remove the axle housing cover.
  1. Remove the rear disc brake rotors (2C026); refer to Section 206-04 .
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Once the differential pinion shaft (4211) has been removed, turning the differential case (4204) or an axle shaft (4234) will cause the differential pinion gears (4215) to fall out of the assembly. This could result in chipped or damaged components.
    Remove the differential pinion shaft.
    1. Remove the differential pinion shaft lock bolt.
    1. Remove the differential pinion shaft.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the rubber O-rings in the U-washer grooves.
    Remove the U-washers (4N237).
    1. Push the axle shafts inboard.
    1. Remove the U-washers.
  1. Reinstall the differential pinion shaft.
    1. Install the differential pinion shaft.
    1. Install the differential pinion shaft lock bolt finger-tight.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the inner wheel bearing oil seal (1177).
    Remove the two axle shafts.
Installation
  1. Lubricate the lip of the inner wheel bearing oil seal.
    • Use Premium Long-Life Grease XG-1-C or equivalent meeting Ford specification ESA-M1C75-B.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Once the differential pinion shaft has been removed, turning the differential case or an axle shaft will cause the differential pinion gears to fall out of the assembly. This could result in chipped or damaged components.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the inner wheel bearing oil seal.
    Install the two axle shafts.
    Install the U-washers.
    1. Position the two U-washers on the button end of the axle shafts.
    1. Pull the axle shafts outward.
    1. Align the hole in the differential pinion shaft with the differential pinion shaft lock bolt hole.
    1. Install the differential pinion shaft lock bolt.
  1. Install the rear disc brake rotors; refer to Section 206-04 .
  1. Install the axle housing cover and fill the rear axle housing (4010) with 2.4 liters (5.5 pints) of specified lubricant; refer to Axle Housing Cover in this section.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif WARNING: Always remove any corrosion, dirt or foreign material that may be present on the mounting surfaces of the wheel or the surface of the wheel hub or rear disc brake rotor that contacts the wheel. Installing wheels without proper metal-to-metal contact at the wheel mounting surfaces can cause the lug nut to loosen and the wheel to come off while the vehicle is in motion, causing loss of control.
    Clean the wheel hub and mounting surfaces.
  1. Install the tire and wheel assembly.
    1. Position the tire and wheel assembly.
    1. Install the lug nuts and lower the vehicle.
    1. Tighten the lug nuts.
    1. Install the center cap.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Never remove the axle shaft oil seal by itself. Always remove the rear wheel bearing and the axle shaft oil seal at the same time.
    NOTE: If the axle shaft oil seal is leaking, the axle housing vent may be plugged with debris.
    Use Impact Slide Hammer and Axle Wheel Bearing Puller to remove the rear wheel bearing and the axle shaft oil seal.
Installation
  1. Lubricate the new rear wheel bearing.
    1. Use Thermally Stable Rear Axle Lubricant XY-80W90-QL or equivalent meeting Ford specification WSP-M2C197-A.
  1. Use Axle Wheel Bearing Replacer with Driver Handle to install the rear wheel bearing.
  1. Lubricate the lip of the new axle shaft oil seal.
  1. Use Axle Seal Replacer with Driver Handle to install the axle shaft oil seal.
  1. Install the axle shaft; refer to Axle Shaft in this section.
May 18, 2011 | Ford Explorer Cars & Trucks
How do I remove the base of a Freud FT2000e router so that I can remove the plunge springs? GeneSimm7@aol.com
Hi There, My name is Larry --I am a FREUD DEALER IN CANADA
To answer your question about the router springs.You must first remove the cap carefully to prevent any damage to the speed module. Under the cap you will find two nuts first lock the base and leave about 2 inches for a socket to go over the nut .Remove normally and be careful when you release the base do it slowly it will spring up fast and hard --
Nov 13, 2010 | Freud FT2000E 3 Router
Dec 05, 2009 | Freud FT2000E 3 Router
How does one change from one collet size to another size. My Freud router came with the 1/2" collet installed and I need to change to the 1/4" size supplied with the router to fit a bit I want to use....
I just did this on my black and decker router. You need to unscrew the nut that holds the collet and remove it altogether. Then slip out the collet in there and replace it with the new size. Take care to notice how it goes in when you take the old one out. Then rescrew the nut that holds it in place and tighten. My router had three collets and only one of them works for each size, so if it doesn't tighten properly, it may be the wrong size. Good luck.
Apr 28, 2009 | Freud FT1702VCEK Router
Replacing front wheel ujoint on 2001 ram dodge 1500
HUB BEARING AND AXLE SHAFT REMOVAL
  2. Remove the wheel and tire assembly.
  3. Remove the brake components from the axle, Refer toBrakes.
  4. Remove the cotter pin and axle hub nut.
  5. Remove the hub to knuckle bolts Hub and Knuckle Remove the hub bearing from the steering knuckle and axle shaft
  6. Remove the brake dust shield.
  7. Remove the axle shaft from the housing. Avoid damaging the axle shaft oil seal.
INSTALLATION
  1. Clean the axle shaft and apply a thin film of Mopar Wheel Bearing Grease to the shaft splines, seal contact surface, hub bore. Install the axle shaft into the housing and differential side gears. Avoid damaging the axle shaft oil seals in the differential.
  2. Install dust shield and hub bearing on knuckle.
  3. Install the hub bearing to knuckle bolts and tighten to 170 N·m (125 ft. lbs.) torque.
  4. Install the axle washer and nut, tighten nut to 237 N·m (175 ft. lbs.) torque. Align nut to next cotter pin hole and install new cotter pin.
  5. Install the brake components, Refer toBrakes.
  6. Install the wheel and tire assembly.
Feb 26, 2009 | 1996 Dodge Ram 1500 Club Cab
Freud FT2000E 3 Router Logo
47 people viewed this question
Top Freud Tools & Hardware - Others Experts
Jim Goldsmith
Jim Goldsmith
Tom Chichester
Are you a Freud Tool and Hardware - Other Expert? Answer questions, earn points and help others
