Question about Cosco Juvenile Baby Gear
Cosco model #22-260-hou
Need help loosening the 3 point harness
I have a cosco alpha omega elite car seat that i bought yesterday and i figured out how to put in in my car but i can't figure out how to take the base off for front facing.
Specs Released 3 years ago Restraint System 5-Point Safety Harness
Adjustable Harness Height Adjustable Harness Height
Car Seat Type Convertible
Additional Features Latch System
Adjustable Recline Positions Adjustable Recline Positions
Carry handle No Carry Handle
Head Protection With Headrest
MPN 22155HMR
Seating Direction Rear / Forward Facing
Stay-in Car Base No Detachable Base
UPC 044681223853
Weight Limit 5 - 100 lbs
Sep 08, 2010 | Cosco Alpha Omega Elite 5-Point 22-155
I dissasembled the car seat so I need get manual in order to re-assebly the belts in the correct way , can you help me
I just noticed my car seat had a safety recall back in 2007 and noticed you had the same recall on the 22150. I just ordered a new kit from Cosco (which was free) to replace the faulty parts. Here's the recall notice ans website to go to: http://www.safety1st.com/usa/eng/News/Detail/309-
Click on "Harness Adjustment Strap Inspection" and give your info. to order the kit.
News 8/30/2007 12:00:00 AM
Dorel Juvenile Group Announces a Voluntary Safety Recall of the Harness Adjustment ******** Certain Cosco®, Safety 1st® and Eddie Bauer® Brand Child Restraint Systems
Columbus, IN August 30, 2007- Dorel Juvenile Group (DJG) is issuing a voluntary safety recall for certain Cosco®, Safety 1st® and Eddie Bauer® brand child restraint systems manufactured during November 2003 through December 2005. Although no injuries have been reported, there is a potential for the harness adjustment strap to loosen during use. If this were to occur, the harness may be loose around the child, possibly increasing the risk of injury in a crash. We feel that it is important to replace the harness adjustment strap.
Model numbers affected are:
Cosco®: Alpha Omega®, Alpha Omega EliteTM: 22150, 22155, 22180, 22269; Eddie Bauer®: 3-in-1, Deluxe 3-in-1, Deluxe Convertible: 22740, 22750, 22755, 22756, 22757, 22770; Safety 1st® : Alpha EliteTM, Alpha Omega®, Alpha Omega EliteTM, Alpha SportTM, InteraTM, EnspiraTM: 22151, 22450, 22451, 22452, 22453, 22455, 22460, 22480, 22481
The model number and date of manufacture may be found on a sticker located on the side or back of the child restraint system.
DJG will contact all registered owners and provide them with information on how to obtain a free repair kit to replace the harness adjustment strap. Those consumers who have not registered their product should visit www.djgusa.com or call 800-219-0509 to order a free repair kit. The affected seats should not be returned to the retailer.
DJG encourages parents to obtain and install the repair kit as soon as possible. Parents may continue to use the child restraint system as directed in their instruction manual. Parents should be sure to adjust the harness adjuster strap snugly each time they put their child in the child restraint system. If there is any difficulty adjusting the harness adjustment strap, or it does not remain tight, DJG suggests using a different child restraint system until the repair kit has been installed.
To check for harness slippage:
(1) Fully tighten the harness, (2) pull on the harness straps without pressing or lifting the harness adjustment lever. If movement occurs, the harness is experiencing slippage.
Jul 04, 2010 | Cosco Alpha Omega Convertible 22-150
I have a car seat and need to find out if its been recalled.. its cosco model # 22-120-pol lisence number # 15c052768
I don't see that your car seat was recalled (I checked on their website, http://www.coscojuvenile.com/usa/eng/Safety-Notices?lookuperror=22120), but here's what I did find on the SafetyBeltSafe USA web page:
Problem with your carseat:
Harness webbing may be damaged if it slides over pointed guides on bottom of pastic shell. Keep webbing behind guides.
Solution:
If damaged, call Dorel for replacement harness and instruction for keeping webbing in correct position.
Here's the website I referred to: http://www.carseat.org/Recalls/recall.shtml#IsYourCssSafe
I would call the company (DorelJuvenile Group) if you have further concerns. Their number is: (800) 544-1108
GOOD LUCK!
May 15, 2010 | Cosco Alpha Omega Convertible 22-150
Cosco Alpha Omega Elite can't get straps back on right!
replace harness: 1) take **** harness and place metel bracket through the base of the seat(slot in shell) make sure buckle is facing out and not inwards. slide metal clip under small tab and push down on clip until it snaps in and locks into place... 2) thread harness without latch plate or harness retainer down through slot on one side of shell, under seat and up through slot on other side. 3) thread latch plate(clip that goes into ****clip)harness retainer onto the harness making sure they are correct. 4) thread harness end through other slot 5) make sure the harness goes over the barbut under the plastic bar, then fit loops on harness ends onto the harness bracket that looks like a triangle(kind of) 6) from the front even up harness to fit properly. And there you go the rest is pretty straight forward the base is pretty sraight forward to attach...
Aug 17, 2009 | Cosco Alpha Omega Elite 5-Point 22-155
Harness straps off cosco car seat to wash cover, help reattaching
I need help putting the straps back on a Cosco 5-point car seat. Took it apart to wash and can't get it back together
Mar 08, 2009 | Century Encore 5-point Harness
Cosco Alpha Omega
You can call the manufacturer, Dorel Juvenile Group, at (800) 219-0509, and they will advise you what to do. A carseat with twisted straps is not safe, especiallyif they involve the harness.
Make sure you also check www.carseat.org/recalls to see if your AOE is one of the ones recalled for harness issues; if so, the Dorel Juvenile Group will send you a free repair kit.
Apr 26, 2008 | Cosco Alpha Omega Elite 5-Point 22-155
Unable to install harness after washing
You might be able to contact Cosco for a manual or diagrams of where everything goes, there info is: Consumer Relations Department at 1-800-544-1108 Hours of operation Monday ? Thursday 7:00 AM to 6:00 PM EST and 7:00 AM to 4:30 PM EST on Friday.
Jul 08, 2007 | Cosco Alpha Omega Elite 5-Point 22-155
Lost Manual need help converting to Booster
I called Cosco at 1-800-544-1108 with my model number and manufacture date and they were happy to email the instructions to me in PDF format. I assume they would have sent them US Postal if I'd asked.
May 09, 2007 | Cosco Alpha Omega Elite 5-Point 22-155
Baby Gear Logo
60 people viewed this question
Top Cosco Juvenile Baby Gear Experts
Dorel UK
Dorel UK
Tom Chichester
Marc Cohen CPSTI
Are you a Cosco Juvenile Baby Gear Expert? Answer questions, earn points and help others
