Question about Baby Lock Sewing Machines
How to open machine
Thread keeps locking up or breaking after threading in "tension" section of machine. Will be sewing fine and then begans to "lock up" or "draw up" on fabric...almost like when you create ruffles. I know there is some broken thread in machine and want to open up the end section for cleaning as I think this would resolve my problem but can't seem to get end section of machine off to see inside.
  • Baby Lock Master
  • 1,564 Answers
Wait, before you do that... check to make sure that your thread isn't wrapped around the spool spindle. I've had mine do that when I had the little thread catch on the spool pointing the wrong way.. and it caught and jerked and threw some loops... nightmare.
Since your machine is a Babylock. I do not recommend taking it apart yourself. Take it in and have a pro work on it.... while there have them check the timing and do some lubing too.
Posted on Jan 14, 2013
SOURCE: I have a Kenmore 385 (12116690) the thread keeps breaking
I have this same machine, it belonged to my husbands grandmother and was given to me after she passed. I let it sit for a few years before I got it out to use it, it was just too emotional. I had this same problem, and after cleaning, it worked fine. I followed the instructions in the manual for taking out the bobbin, bobbin case and metal parts that hold it in the machine. (there are pictures in the manual to help you take it out, take it apart, and put it back in... sounds hard but it's really not). I used a tooth brush to get all of the dust bunnies out (you could go over with a vacuum hose too, after the toothbrush cleaning). After I did this it worked fine. You may want to look in the manual about oiling the machine, if it's been years since it's been done, that might help to. Hope you get it working! I love this machine, it works well and is good quality. (they don't make sewing machines like they used to, the only one I'll buy is a Kenmore!)
Posted on Feb 27, 2009
SOURCE: Baby Lock Serger Thread keeps breaking
Mmmm...., maybe NOT the solution, maybe, just a key.
I have a copy of theBaby LKock EA-605 instruction booklet in English, Germann, French and Spanish. NO ideas how it casme into my orbit, but happy to pass it on.
Posted on Mar 06, 2009
  • 3 Answers
SOURCE: Not picking up the Bobbin thread
Sounds like you have to take off the throat plate and clean out threads under it.  Sometime they ball up and prevent the needle from going down and catching the bobbin thread. You can't see themuntil you take off the plate.  Follow the directions.  It is easy.
Posted on Mar 07, 2009
SOURCE: Bicor vx1005 ...thread keeps bunching
Try a different bobbin. Look for one that is a little narrower. I had the same problem and changing to a narrower bobbin fixed it.
Posted on Mar 29, 2009
SOURCE: Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Posted on Apr 07, 2009
Why does the thread on my sewing machine keep breaking?
Several possibilities. It could be the needle, the tension too tight, mis-threading, the thread weight, brand, poor quality, or fabric incompatibility with needle & thread.
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
Why Does My Thread Keep Breaking While Sew
All About Needles
Nov 09, 2016 | Sewing Machines
Kenmore mini ultra The top thread breaks off from needle after a few stitches. The bobbin seems to Be catching the top thread. Thank you. ??
If the top thread sews a few inches and then breaks, something is catching the top thread and holding it until it breaks. Usually, this will happen when using the old style thread cones with the slit in the edge to keep the thread from raveling off the spool. To prevent the thread from hanging up, turn the thread spool over so the slit is at the top instead of the bottom. Sometimes top thread breaks will happen if the thread becomes looped around the thread spool pin.
Remove the thread, ALWAYS RAISE the presser foot and then rethread the upper thread. Verify that the thread path is correct and that the thread has not looped around a guide.
If the thread is fraying at the needle eye, the needle/thread are not compatible. Also, the tension may be too high.
Check that the upper tension disk is clean--no gunk buildup or thread pieces stuck.
If the thread is actually breaking when it penetrates the needle plate hole, there may be a burr or nick somewhere below that is catching the upper thread. You can wrap your finger with a piece of fine fabric, like an old pair of hosier, fine knit fabric, etc. and running your finger around in the bobbin area, under the needle plate. If you get snags, then you have a burr or nick. If it is small, you can sometimes smooth it with a fine emery board. If it is a large burr, you may need to purchase a replacement part.
Why Does My Top Thread Keep Breaking Sewing Machine
Sep 05, 2016 | Kenmore Sewing Machines
Thread keeps breaking when I sew.
one of three issues: top tension too tight, bottom tension too tight, needle timing off.
Oct 21, 2015 | Elna 2005 Mechanical Sewing Machine
How do I fix a White sewing machine #445 that keeps breaking the upper thread
Check the thread spool to make certain the thread is not getting snagged on the edge of the spool (or the little slit where you pull out the thread from the spool); then check your tension paths and settings (I once found broken, tangled metallic thread in the needle 'uptake' loop that was snagging the thread and making it break).
Canned air is excellent for cleaning out older models as well as the new electronic machines.
Feb 03, 2015 | White Sewing Sewing Machines
Top thread keeps breaking. Adjusting the tension does absolutely nothing. It seems as though the thread is getting caught on something inside the machine between the thread guide and thread take-up lever....
these are suggestion, if they don't help then the machine needs to be checked at a sewing machine shop
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Sep 27, 2013 | Euro-Pro Sewing Machines
My thread keeps breaking and the bobbin tension is too loose
adjust the top thread tension one number or letter higher at a time
and sew on a scrap piece of fabric till the stitches look normal
The needle thread breaks
Jan 15, 2013 | Sewing Machines
Top thread pulls and breaks while sewing.
Oct 24, 2012 | Sewing Machines
Juki DDL 227 top needle keeps breaking
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
Oct 08, 2012 | Juki Sewing Machines
Aug 17, 2012 | Singer Confidence 7469 Mechanical Sewing...
Sewing Machines Logo
99 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
