Question about Grundig Televison & Video
How do i set up my Grundig GU37HD1080p 37 Inch Full HD 1080p LCD TV.
  • 15 Answers
SOURCE: want to change my sharp hd tv from 480i to 1080p
You Can Not Change. The TV Recognize the signal on the INPUT.
If the signal is 480i than the tv shows 480i
If the signal is 1080p than the tv shows 1080p (if supported)
If you try with your areal antenna (for now digital broadcast is maximum 1080i (in USA) The TV itself doesnt "upconvert" lower resolution signals.
Posted on Mar 14, 2009
  • 458 Answers
SOURCE: 37 inch LG LCD won't turn on due to power failure
Power failures can cause all types of problems, have you firstly checked the fuse in the mains plug? If that is ok then it may have blown an internal fuse in the power supply board, these are there to protect the rest of the circuit from power surges.
Posted on Mar 24, 2009
dsacco86
  • 1077 Answers
SOURCE: What kind of HD output does Emerson LCD HDTV have?
The TV resolution is 720p
Posted on May 10, 2009
SOURCE: 37 INCH LCD HD NO PICTURE GREEN LIGHT ON, BUT NO SOUND
Unplug and replug it...it should work eventually.
I have the same problem with my 32".
But it eventually goes on when i try it a couple of times (the number of times is completely random...sometimes none, and sometimes like, 3).
Posted on Jul 07, 2009
  • 1274 Answers
SOURCE: Techwood 37 Inch LCD HD
Hi joachi, my name is John. Welcome to FixYa. You can get it here. www.manualsonline.com . Thanks for choosing FixYa....John
Posted on Dec 03, 2010
Vizio e371va screen NOT TURNING ON
Sorry to hear that...now a days it,s cheaper to replace then to fix...I had that problem on my first HD TV..a element brand...No hope....trash it went
Aug 13, 2016 | Vizio E371va 37-inch Full Hd 1080p 120 Hz...
WHY I HAVE GOT HARITONZAL LINES ON TOP OF SCREEN ON TOSHIBA LCD 37RV635D
sounds like the same problem as with most screens. it could well be the screen as gone
Apr 26, 2014 | Toshiba 37RV635DB Regza 37-inch Widescreen...
Power goes down suddenly
If it is out of warranty, write down the model of boards inside
replace the power board, once installed power it up, and see if this
does solved your previous issues, good luck
Mar 18, 2014 | Hitachi Gst Hitachi L37X01A 37 inch Full...
No picture on TV screen
Check its back light inverter board. Check its supply voltage. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1000 posts to different brand TVs now. Pull up older posts there.
Oct 19, 2012 | Toshiba 37RV635DB Regza 37-inch Widescreen...
Flashing green power indicator
It is a indication the set is not going to come on---usually a standby power supply problem in the set.
May 19, 2012 | Sharp Lc42d65u 42 Inch Full Hd 1080p Aquos...
Is the integral Freeview on my 32 inch Full HD TV HD or Not
Simple answer. No. But please read on . . .
Full HD Freeview, i.e 1080p does not exist. The four HD channels currently available on Freeview all transmit at 720p resolution. There is insufficient bandwidth in the TV transmission range for the HD channels to transmit at 1080p. It could be done, but it would be at the expense of other channels.
Your TV, however, is Full HD, as indicated by the 1080p in the specifications. This means it can display a full HD picture from a device which outputs at 1080p resolution. Devices which generally output at 1080p resolution include Blu-ray DVD players, games systems and PCs.
When viewing a Freeview HD channel, your TV will display the picture in 1080i (interlace) resolution. This is not true/full HD. The transmitted picture comprises of 720 horizontal lines and the software inside the TV is creating the additional 360 lines and interlacing them between the 720 lines from the original transmission in order to create a 1080 line picture which fills the entire screen.This process is commonly known as 'upscaling' and can cause deterioration in the overall picture quality, most noticably on poor quality, cheap TVs.
Hope that explains it for you sufficiently!
Nov 10, 2011 | Televison & Video
Can you please supply a manual for my Philips 37" flat screen full HD 5000 series TV
The manual is available as a PDF at the Philips UK site: http://www.philips.co.uk/c/televisions/5000-series-philips-37-inch-full-hd-1080p-digital-tv-37pfl5604h_12/prd/;jsessionid=4BA4C9751BF63901AEE428BC6CC05A13.app102-drp2?t=support . The link for the User's Manual is on the right in the section marked Support Highlights.
I hope this helps .
Nov 18, 2010 | Televison & Video
Buy Samsung LN32A550 32 in. 1080p LCD HDTV Free shipping Order Today! [Click Here!] Samsung LE32B650T2 32-inch Widescreen Full HD 1080p Samsung LE32B650T2 32-inch Widescreen Full HD 1080p Save On "Buy...
SPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMv
Jul 02, 2009 | Samsung LN32A550 32 in. LCD TV
Televison & Video Logo
46 people viewed this question
Top Grundig Televison & Video Experts
Henry  Thomas
Henry Thomas
Raj Patel
Are you a Grundig Televison and Video Expert? Answer questions, earn points and help others
