Question about Technics SA-AX540 Receiver
Technics SA-AX730 Everytime I turn the power on the stereo clicks on and off repeatidly, and when I push the help/reset button it says that everything is operating correctly, and there is no sound coming out the speakers. It worked one day and then not the next. I have checked all the fuses and the filaments are still intact.
  • 20 Answers
The very FIRST thing to check is to make certain ALL of your speakers have an IMPEDENCE of 8 OHMS. Virtually all speakers of even modest quality will include this specification on a label on the back of the speaker. You CANNOT run more than (2) TWO speakers with 4 OHMs impedence on ANY amplifier (technical discussion too long!) [NOTE: Even though fused, your receiver has internal overload protection systems to prevent permanent damage. However, you cannot re-set these systems yourself. Your dealer or authorized service center must do this.] But, before you take it in for service, there is one more "test": check for shorted and/or mis-connected/disconnected speaker cables/wires. Visually inspect connections at the receiver and speakers first. You might find something obvious! If everything looks okay, then disconnect ALL of the speakers; and reconnect and test them one at a time (at relatively low volume.) For example, reconnect the left front speaker, test the system; THEN add the right front, test the system,and so on, ADDING one more speaker each time - FIRST MAKING SURE EACH OF THEM HAS AN IMPEDENCE OF AT LEAST 8 OHMS! IF there is a short (or bad speaker) this will help isolate it. Hopefully one of these "fixes" will work for you. GOOD LUCK!
Posted on Jul 18, 2007
What are the functions of the impedance button on the Technics SA-AX730
This allows you to select the correct amplifier output impedance for the particular speakers you have connected, Proper selection insures the best efficiency, response and prevents potential damage to speakers or the amplifier, Refer to page 17 of this manual:
http://audio.manualsonline.com/manuals/mfg/technics/technics_sa_saax730.html
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Nov 20, 2014 | Technics Audio Players & Recorders
How should I connect my Technics SA-AX730 receiver to my Panasonic TC-40A420U that uses HDMI?
I assume the Panasonic is a TV. I have never heard of green audio outputs. Audio outputs should be red and white (for RCA plugs). There are adapters available that convert the yellow, red and white component outputs to HDMI. You can get them at GameStop (I bought one recently to connect a game system for my daughter). If you have a TV converter box from your cable or satellite provider you might be able to connect the audio out on the cable box to your Technics receiver and run a HDMI to the TV (be sure to turn off the TV's internal speakers through the TV's menu) for video.
Oct 15, 2014 | Technics SA-AX730 Receiver
Why is my centre speaker not working on my stereo setting on phono?
Records are binaural only. There are only two channels of information, left and right. There is no signal available for a center channel.
Aug 29, 2014 | Technics SA-AX730 Receiver
Fan is not working?
are u sure the fan is not working because on my ax730 the fan will only come on if im booting over half volume
Jul 27, 2010 | Technics SA-AX730 Receiver
I want to buy a Technics SA-DX940 reciever
ebay cheap as chips just keep your eye out for them there always about look for the sa-ax730 aswell more or less the same
Jul 23, 2010 | Technics SA-DX940
Power surge blew internal fuse
the guide have the fuse you need an looking for !
Jun 09, 2010 | Technics SA-AX730 Receiver
"OVERLOAD" message-Technics SA-AX730
You can't do it yourself only a good technician or repair center.I don't know the fix it cost.
Jul 07, 2008 | Technics SA-AX730 Receiver
Video Problem
You most likely have either bad connections from the jacks to the main PC board or the video switching chip has an internal problem. Try resoldering all of the input jacks first and update this with your results.
Dan
May 12, 2008 | Technics SA-AX730 Receiver
Technics SA-AX730 Receiver PLAYS FINE AT A VERY LOW VOLUME.
Your speakers are way tp powerful you should only use speakers just over what the amp is rated at the most and check your impedance is not lower then 6 ohms and turn the bass to half way i am using 60 watt bookcase psb speakers and they work just fine and they pound no problem
Aug 24, 2007 | Technics SA-AX730 Receiver
Technics SA-AX540 Receiver Logo
279 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
