Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
My vac cleaner doesn't pick up.
Have replaced filters but still no suction
  • Dyson Master
  • 18,424 Answers
There could be a few things that would cause your Dyson to have no suction. I will give you detailed step by step instructions along with pictures on how you can diagnose this.
Possible Problem #1. The first problem is extremely common. In fact, we probably see between 2-3 of these problems every week. It mostly happens after people take the bottom plate off the vacuum in order to clean the roller brush. What happens is when they reinstall the bottom plate, they put it on on incorrectly. It's actually very easy to do. When the bottom plate (soleplate) is installed wrong, there will be a gap between the bottom plate, and the agitator housing, or the purple tray the roller brush sits in. This will cause the soleplate to be a few inches higher off the ground then it should be, preventing the brushes from even hitting the carpet. This makes it seem to the user that vacuum has lost suction power because without the brushes hitting the carpet, the machine will not pick up very well on floors, but when they use the attachment hose there's plenty of suction power.
Here's a picture of the WRONG way to install the bottom plate. Notice the gap in between the two housings:
Here's another picture, that is the RIGHT way to install the soleplate:
I would say probably 6 times out of 10 this is the problem with the customers machine. If you checked the soleplate and it is installed correctly, move on to the second possible problem.
Possible Problem # 2. Turn the vacuum cleaner upside down so the brush roller is facing upwards. I found the easiest way to work on it is to put it on a counter top or work bench. On the left hand side behind the roller brush you should see a flexible transparent hose that goes from the motor to the agitator housing. This hose actually has a lot of strain on it when the vacuum cleaner is in the reclined position. When the first few series of Dyson DC07 models came out, they didn't make this hose long enough, so when the vacuum was in the reclined position, it would put too much stress on the hose, and cause the hose to actually crack, usually right where the end of the hose that goes into the agitator housing. Examine your hose and see if you have any visible cracks in this hose. If you need to you may just remove the entire hose assembly by pulling on it. It will easily come right out of the machine so you can inspect it better. Here's a picture of where the hose usually crackmy vac cleaner doesn't pick up. - 54cb5e5.jpgbr>54cb5e5.jpg
This would also explain why the vacuum works fine when using the attachments, but not on the floors. The attachment hose uses a different suction channel, and when the machine is in the upright position, no suction goes through this hose. If you do find a crack in this hose, the this hose needs to be replaced. Here's a direct link to that hose on our GoVacuum website.
Dyson DC-07 & DC-14 Upright Replacement Internal Hose Part # 904219
Possible Problem #3. I would suspect that this may not be the problem, but if neither of the solutions above worked, then try this one. Dyson's in general are prone to clogging. There are a few clog ports throughout the vacuum cleaner that were added there due to Dyson prototypes becoming clogged at these points. Here are pictures of how and where to check for these clogs. Simply remove the suction my vac cleaner doesn't pick up. - 8b33cd4.jpgs at both of these locations:
Possible Problem #4. If none of the above solutions worked for you, try this last one. The Dyson DC07 models use a clutch mechanism that stops the roller brush from spinning when changed from carpet mode to bare floor mode. This clutch mechanism is a notorious problem with all Dyson models, in fact they were such a problem that Dyson had to redesign the DC07 model to a non-clutch system. Even if yours is one of the newer ones that don't use a clutch, yours still has a belt inside. You can tell if your model uses a clutch or not by the shape of the roller brush. If your brush is a perfect cylinder shape, yours does NOT have a clutch. To check and see if the clutch or the belt have gone bad, first release the handle on the vacuum as if you were vacuuming carpets. Make sure the machine is set to carpet mode. Now while the handle has been released, turn the machine upside down and see if the brushes are spinning. If the brushes are spinning then turn the vacuum right side up and put the brushes on the floor. Can you still hear the brushes spinning when they are hitting the carpet? If yes, then this is not the problem. If the brushes however are NOT spinning, this indicates either your brush roll, clutch, or belt have gone bad.
Posted on Jan 13, 2013
2 Suggested Answers
small6363
  • 18424 Answers
SOURCE: dyson 14 suction low when using footplate
Possible Problem # 2. Turn the vacuum cleaner upside down so the brush roller is facing upwards. I found the easiest way to work on it is to put it on a counter top or work bench. On the left hand side behind the roller brush you should see a flexible transparent hose that goes from the motor to the agitator housing. This hose actually has a lot of strain on it when the vacuum cleaner is in the reclined position. When the first few series of Dyson DC07 models came out, they didn't make this hose long enough, so when the vacuum was in the reclined position, it would put too much stress on the hose, and cause the hose to actually crack, usually right where the end of the hose that goes into the agitator housing. Examine your hose and see if you have any visible cracks in this hose. If you need to you may just remove the entire hose assembly by pulling on it. It will easily come right out of the machine so you can inspect it better. Here's a picture of where the hose usually cracks:
Possible Problem #3. I would suspect that this may not be the problem, but if neither of the solutions above worked, then try this one. Dyson's in general are prone to clogging. There are a few clog ports throughout the vacuum cleaner that were added there due to Dyson prototypes becoming clogged at these points. Here are pictures of how and where to check for these clogs. Simply remove the suction port covers at both of these locations:
If these solutions still didn't fix your problem, I'd be happy to try and help you further. Just use the Clarification Request, or comment section here on the Fixya repair page.
If this repair was helpful to you, please be sure to rate this repair as helpful by clicking the thumbs up icons in the top right hand corner of the repair. Thanks so much!
Posted on Jan 04, 2013
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 | Vacuums
My dyson ball dc24 the bar will spin but will not create suction
I'm sorry to hear you're having difficulty with your DC24. If the machine doesn't seem to be picking up as well as usual, there may be a blockage somewhere in the machine. The filters may also need a wash.
To locate and remove any blockages, please follow the steps shown in our online Support guide:
http://www.dyson.co.uk/support/dc24/dc24-multi-floor/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/check-suction
In normal use, both filters need to be washed at least once a month, as shown in the video below. Use cold water without detergent, and allow the filters to dry completely somewhere warm before replacing them.
This should resolve the issue, but if you'd like any further assistance or advice, please give our customer Helpline a call on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Apr 30, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
Dyson vacuum cleaner model DC08 lost it's suction
Hi Noel,
I'm sorry to hear you're having difficulties with your DC08. If the machine doesn't seem to be picking up as well as usual, there may be a blockage somewhere - the filter may also need a wash.
The easiest way to locate and remove any blockages is to follow the steps shown in our online support guide:
http://support.dyson.co.uk/support/dc08/dc08-standard/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/check-the-floor-tool
In normal use, the filter needs to be washed at least once every 3-6 months, as shown in the video below. Use cold water without detergent, and allow at least 12 hours for it to dry completely before replacing it.
This should resolve the issue, but for any further assistance or advice, please call us free on 0800 298 0298. Our Helpline is available from 7am until 10pm, 7 days a week.
Best wishes,
Jack
Jan 06, 2012 | Vacuums
No suction is the hose of the dyson absolute
Hi Teresa,
I'm sorry to hear you're having difficulties with your DC17. If the cleaner picks up via the cleaner head, but there's no suction through the wand, it's likely that there's a blockage in your wand or hose. I note you've already checked the U-bend, but it may help to follow the steps shown in our online support guide, to make sure everything is correct with the machine:
http://www.dyson.com/support/help.asp?article=954&product=DC17-ANIMAL
It may also help to wash the filter - in normal use, this should be done at least once every 3-6 months, as shown in the video below. Use cold water without detergent, and allow at least 24 hours for the filter to dry completely before replacing it.
This should resolve your issue, but if you're still concerned after trying this, please get in touch with us directly so we can help. You can call free on 1866MYDYSON, or email askdysonUS@dyson.com.
Kind regards,
Jack
Nov 17, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
Loss of suction,when used in upright Hose blocks suction does not take dust into the clear cylinder
Hi Jean,
I'm sorry to hear you're having difficulties with your DC03. If it doesn't seem to be picking up as well as usual, it sounds as if the cleaner may have a blockage, and the filter may need a wash. The easiest way to locate and clear any blockages is to follow the steps shown in our online Support guide:
http://www.dyson.co.uk/support/help.asp?article=314&product=DC03-SY-STD
In normal use, the filter should be washed at least once every 3-6 months, as shown in the video below. Use cold water without detergent, and allow at least 12 hours for the filter to dry completely before replacing it.
Following these steps should resolve your issue, but if you're still concerned, please get in touch with us directly by calling free on 0800 298 0298. Our Helpline is available from 7am until 10pm, 7 days a week.
Kind regards,
Jack
Nov 07, 2011 | Dyson DC03 Bagless Upright Cyclonic Vacuum
Suction issue with carpet setting
I'm sorry to hear you're having difficulties with your DC07. If the cleaner doesn't seem to be picking up as well as usual, it's a good idea to check the cleaner for blockages. The filter may also need a wash. The easiest way to check for blockages is to follow the steps shown in our online support guide:
http://www.dyson.com/support/help.asp?article=4&product=DC07-SY-HEPA_US
In normal use, the filter should be washed at least once every 3-6 months, as shown in the video below. Use cold water without detergent, and allow at least 24 hours for the filter to dry completely before replacing it.
Following these steps should resolve the issue - however, if you need any further assistance, please get in touch with us directly by calling free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Oct 22, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I have a hoover steam vac F5915-900 I bought at walmart about 4 months ago. I used it about 5 times in differnet rooms. Today when I went to use it It won;t pick up the dirty water. I cleaned the filter...
Make sure the suction area of the face plate is clear of all debris. If anything else, call the number on the machine, it's still under warrantee if the machine doesn't work from normal use.
Sep 05, 2011 | Hoover Vacuums
Hi, We have a 3 month old Dyson DC33. I have noticed a lack in suction on the baseless but when upright the wand suction seems to be fine. Base plate is correctly fitted, brush bar turns fine and there...
Dear Andy,
I'm sorry to hear you're concerned about your DC33. Please note that for high pick-up, the soleplate has to form a close seal with the floor surface, which is why you may not have detected much suction through the cleaner head when you laid the machine on it's side.
However, if the cleaner doesn't seem to be picking up as well as usual in normal use, you may need to give the filters a wash - this should be done at least once every 3 months. Use cold water without detergent, and allow up to 24 hours for the filters to dry completely before replacing them. The correct way to wash the filters is shown in the step-by-step guide linked below:
http://www.dyson.com/support/help.asp?article=1415&product=DC33-MULTIFLOOR
Hopefully this answers all of your queries, but if you feel you need further assistance, it's probably best if you get in touch with us directly. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). One of our experts will be happy to run through some troubleshooting over the phone with you recommend the best course of action.
Kind regards,
Jack
Sep 01, 2011 | Vacuums
I HAVE NO SUCTION COMMING FROM THE BOTTOM OF THE CLEANER AND THE BRUSHES DONT TURN DOES NOT PICK UP ANYTHING WHEN ITS UPRIGHT. BUT I DO HAVE SUCTION THROUGH THE HOSE. THANK YOU
Hi there, Sorry to hear you're having difficulties with your DC07. If it doesn't seem to be picking up as well as usual, it's possible that there's a blockage in the system, and you may need to give the filter a wash. The easiest way to check for and remove any blockages is to follow the steps shown in our online support guide: http://www.dyson.com/support/help.asp?article=4&product=DC07-ANIMAL_US Please note, the brushbar will never rotate when the cleaner is standing in the upright position, or if you have the brush control set to 'Off'. Under normal use, this should be done at least once every 3-6 months. Use cold water without any detergents, and ensure the filter is totally dry before replacing it - this may take up to 12 hours. Hopefully, by clearing any obstructions and washing the filter, you should be able to resolve your issue without further assistance. However, if you've tried this and are still concerned, it's probably best if you get in touch with us directly. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). One of our experts will be happy to run through some troubleshooting over the phone with you recommend the best course of action. Kind regards, Jack Dyson Online Customer Support
Aug 26, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
My vacuum isn't cleaning/suctioning very well. The hose attachment will work and pick up debris but the main part of the vacuum (where the brush is) doesn't pick up. The brush only spins but there...
Check to see if the brush is turning when you have the vac on and the handel down 'of course keep your hands from that area when doing this ,you might have to lean the vac ,to see the resaults.
Jul 09, 2011 | Panasonic MC-V7582 Bagless Upright Vacuum
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
74 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
