Question about Canon ImageRUNNER 330s Copier
What does a hard drive cost for a cannon 330s
  • Canon Expert
  • 1,326 Answers
A new hard drive is about $100.00..... The problem is getting some one to flash the drive with the correct software. The copier is about ten years old or soo.
Posted on Jan 14, 2013
Replace removed hard drive ,cost?
The hard drive is on the back side of the copier behind the rear panel. The hard drive is not expensive, the problem is getting the hard drive flashed with the correct software. Also, it is a older copier... It may not be worth repairing????? Good Luck
Jan 13, 2013 | Canon ImageRUNNER 330s Copier
E 603- 0002
Needs a new Hard Drive......
May 23, 2011 | Canon ImageRUNNER 330s Copier
Our cannon ir has the error code E002... what does that mean? The model is 330s. And how can we fix it? Thanking you in advance.
that is mean problem with thermistor.
you must replace a new.
position is inside near exit paper place.
May 18, 2011 | Canon ImageRUNNER 330s Copier
We have a Canon Image Runner 330S and we are getting a new copier. Since we are a Correctional Facility I am being told by the 'powers-that-be' that I need to remove the Hard Drive so that any sensative...
there is a hard drive on the printer board. open the back cover, on the down right side there is big vertical printer board(where u connect printer or lan cable).detach mounting screws and detach its connectors,then open the board cover u"ll find hadr drive there.
Jan 24, 2011 | Canon ImageRUNNER 330s Copier
Our Canon Image Runner 330S shows error message E014....
is there an error code appear on panel display?
if there a error appear try to reset you may press * key,press 2&8 simultaneously, the select copier then select fuction then clear then error then ok then turn off& on
Jan 04, 2010 | Canon imageRUNNER 400S Copier
Feeder not working, need spare part kit for Cannon copier ImageRUNNER 330S
I would try www.precisionroller.com or perhaps www.katun.com for aftermarket parts for the doc feeder.
If all else fails you can find your local Canon dealer and buy parts directly.
Hope this helps
TankMurdock
Feb 18, 2009 | Canon imageRUNNER 210S Copier
Adding Staples Image Runner 330S
depednding on sorter im guessing its the small sorter with one tray the stapler is in the rear of the sorter green handle pull it out uses L 1 staples
Jul 24, 2008 | Canon ImageRUNNER 330s Copier
Canon imagerunner 330S
Did you need to connect the machine for printing? Sounds like you have installed an incorrect driver. You can go to canonusa.com and find the correct driver. Make sure you specify for the correct machine.
Feb 20, 2008 | Canon ImageRUNNER 330s Copier
Copier Harddrive
Remove the rear cover. The hard drive is at the top, near centre. Disconnect the connector and remove the four screws. The hard drive can then be removed from the mounting plate. New system software needs to be installed if a new hard drive is fitted to the machine in order for it to operate. It will not function without a hard drive or the system software.
Nov 16, 2007 | Canon imageRUNNER 400S Copier
Cannon Image Runner 330s
There is nothing wrong with the solenoid. The fuse cleaning web is similar to a roll of paper towels. For each copy made the copier fires the solenoid, advancing the web roll slightly. You can override the error but that will damage the upper fuser roller since it won't be cleaned and lubed properly. You need to replace (or have replaced) the cleaning web and reset the web counter in service mode. I am not sure on that model but when you purchase the web, $15-20, they can tell you how to reset it. Good Luck.
May 07, 2007 | Canon ImageRUNNER 330s Copier
old marine
old marine
