Question about Baofeng UV-5R 136-174/400-480 MHz Dual-Band DTMF CTCSS DCS FM Ham Two Way Radio
Baofang UV-5r will not accept vfo to memory
Cannot get memory to accept vfo information.
    Prodigy:
    An expert who has answered 500 questions.
  • 607 Answers
Hi Gary,
Yet another chinese made radio.
Maybe they will make something good, but don't hold your breath.
I'm not against the people, but the companies that make stuff, including Motorola radio under license.
All these Chinese radios are mass produced to a fixed price and dubious standards.
I bought an FDP & Oricom CB radios, only to open the packaging and find they were made in China, from there on things began failing very quickly.
Getting back to your query... I take it you don't have the user manual, is that correct? If so, your best bet is to find a friend who can communicate in Manderin, which is the most used languge in China, and have them find the Baofang website and follow the links to service/help section, and to see if a copy of the user manual in english is available for download.
If this fails, then unless you know someone with a similar model radio with manual, and if they can make a copy for you.
If that doesn't work, ooops! you've used up all your avenues for help.
Sorry if I haven't helped you.
Best wishes,
Peter
Posted on Mar 05, 2013
    Problem Solver:
  • 6 Answers
I have the BaoFeng UV-5R+ and the software will not work on Windows 8? I am Able to use the software and type in the freq and PL freq etc but when I plug in the Radio with the Programming cable the system does not see the radio. At the moment my PC is in the shop the LED backlight went out just made it under the warranty which expires the end of June
Krisy
Posted on May 04, 2014
What solar charger will work with the UV-5R ham two way radio?
Not directly. You'll need a regulator to get the output of the solar panel to the right voltage and current of the UV-5R. Even then without proper circuitry, you'll ruin the battery in the radio.
Apr 23, 2014 | Radio Communications
Baofeng uv 5ra manual
The Baofeng manuals are terrible. Look online for "Baofeng UV-5R programming" Setting up and programming your UV 5R
Apr 12, 2014 | Radio Communications
I programmed my Baofeng UV-5R to a UHF repeater frequency and entered the proper CTCSS code. I also correctly entered the correct offset which allows me to connect to the repeater. Howerver, when I
Please. Your question got truncated in the title, and was not asked in the details. So I have you asking, "However, when I..." and that this is occurring on your UV5R. Please respond with details and I will try to help you. I own the UV5R+.
There is an excellent owner's manual for the BaoFeng at Miklor.com/uv5r/userguide.
Apr 02, 2014 | Baofeng UV-5R PlusEarphone...
Baofeng uv-5r will not transmit
Sounds like you have the transmit lockout set. this radio is a bit of a pain to program, but is well worth the effort. your best bet is save your settings (backup) and do a full factory reset, and start over, making sure you did not lock out the transmit on any channel or VFO...
Oct 15, 2013 | Dual Uv-5r Baofeng Band Uhf/vhf Radio Usb...
Which is the better radio uv - 3r dsp or the uv - 5r
the uv-5r have more powre on transmit and more chanals to program uv-3 (99) AND UV-5 (128chanels)
Jun 24, 2013 | Baofeng UV-3R Plus 136-174/400-470MHz...
Need to program baofeng uv 5r
That is outside the 140-174 range of the radio. It cannot be programmed in this radio.
Apr 13, 2013 | Dual Uv-5r Baofeng Feq Uhf/vhf Radio Free...
Baofeng uv-5r will not reset
So glad you have resolved your query in a timely fashion.
Peter
Mar 09, 2013 | Dual Uv-5r Baofeng Band Uhf/vhf Radio Usb...
Program for baofeng vh 5r fails to connect to receiver
Many computer programming applications supplied to ease populating the memory locations of radios with frequencies, tones, offsets, and alpha-numeric tags are very finicky with timings on serial or COM ports. Use of USB --> COM converters generally do not work well. You should connect the radio to a computer that has a real COM port - but failing that you *may* be able to coax the radio to accept the data by turning the speed WAY down. By way down, we're talking 1200 or 2400 BAUD. 19.2K speeds make timing variables to great for the radio to accept without errors.
Try with a slower speed and you may be able to do it - otherwise, an older PC or notebook with a genuine COM port and a 16550 UART should be available for very short money on craiglist or eBay. Then, you'll be able to run 115K transfers.
I hope this helps & good luck!
Oct 12, 2012 | Dual Baofeng Uv-5r Band Uhf400-480mhz...
Baofeng UV-5R 136-174/400-480 MHz Dual-Band DTMF CTCSS DCS FM Ham Two Way Radio Logo
117 people viewed this question
Top Baofeng Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Baofeng Radio Communication Expert? Answer questions, earn points and help others
